timmythecop Posted November 12, 2017 Posted November 12, 2017 You may have asked (I realize nobody asked) why I have a 1980 Moto Guzzi 1000sp. Well, I'll tell you. Because Guzzis are very groovy and collectable. The model I have was introduced to compete with the first real (argueably)sport-touring bike, the BMW R100RS. It is in my opinion, the VFR of its day. Quick, but not a world beater, comfy, great handling and good at what it does. You can ride this bike to Alaska and since it is 90% the same As a LeMans, it can scratch too. So if you will allow, I thought I would chronicle my time with this Italian bird. I rescued it from a cafe conversion, and I am almost done putting it back to stock. Let me know your thoughts. Quote
timmythecop Posted November 12, 2017 Author Posted November 12, 2017 It won't always be red....... 1 Quote
VFRpwr Posted November 12, 2017 Posted November 12, 2017 Has your desire for espresso or cappuccino increased since owning it? OK, now I get it: ...you may not want Matt's help with the front calipers. Quote
Member Contributer Dutchy Posted November 12, 2017 Member Contributer Posted November 12, 2017 Aye, wouldn't mind getting my leg over... And Guzzis are groovy, even borroewed ones.. Had a custom painted helmet back in the days.... :-) Quote
Sweeper Posted November 12, 2017 Posted November 12, 2017 Was that a cafe conversion that you started Timmy? Seriously, it looks pretty cool and will be truly badass when it is all black. Quote
timmythecop Posted November 15, 2017 Author Posted November 15, 2017 No, a fella in Baltimore started the conversion, but at least he saved 99% of the stock bits. I got a groovy Ducati 900SS half fairing thrown in also. These bikes, as I said, share almost all of their DNA with the mighty LeMans, in fact the frame is identical. A good example of a Mk I LeMans will cost you way north of 10,000 bucks. So people got to taking an SP1000 and cutting it up and putting LeMans bodywork on them and now we have a ton of LeMans clones. BUT...... The SP1000 was designed in a wind tunnel and is 1000cc as apposed to the LeMans 850cc. In fact, the Mark II looked very similar to the SP. It isnt faster, because LeMans had bigger valves, higher compression and gigantic pumper carbs, but an SP is less busy and is described as "Long Legged". An added benefit is that following the carving up of all the SPs, they are now, unintentionally getting rare, especially with all the stock stuff on it. One can turn any ol Tonti frame Guzzi into a cafe bike, but I wanted the mighty SP. The riders compartment is cocooned in an envelope of still air, while the V-twin rumbles along. It is so fun. Also, in case anyone is alarmed at the rotors, they are cast iron Brembo and they rust overnight, and it is part of the design. The linked brakes: When you pull the brake lever, you get the right front rotor. When You hit the pedal, you get the front left rotor and the rear rotor. Sounds wacky, but when you use both front and rear together it stops rapidly. This example also had stainless lines already fitted, so boom. It also has unobtainium BUB exhaust, Koni shocks, SP-NT footrest hangers, groovy Metzelers, and electronic ignition. I added the period correct Krauser bags, the fork boots and the solo seat. Nothing is cut, and the stock seat can go back on with 4 bolts. Quote
timmythecop Posted November 15, 2017 Author Posted November 15, 2017 MkI LeMans ...and the MKII Quote
Member Contributer Dutchy Posted November 15, 2017 Member Contributer Posted November 15, 2017 Mark I, calipers in front of forks, check!! Overnight rusted rotors, check! Even on the LMV Quote
timmythecop Posted November 21, 2017 Author Posted November 21, 2017 In the 70's and 80's, Guzzi was owned by DeTomaso of Pantera fame. He also owned Benelli and Masarati. The part sharing was on. If you look at any Benelli from the time, you will see Guzzi forks, wheels, switchgear and lights. The gauges were always Veglia like Norton-Villers-Triumph were always made by Smith's. If you really do your research, other oddities come up like the starter motor having the same part number as a Fiat Brava and the key blanks being the same as a Yugo. But the best part was that the brakes were always Brembo, and mirrored what Ducati was equipping at the moment. So after some research, I took a chance on some period plastic brake and clutch levers. No idea what they are like, but thanks to the popularity of Brembo, they exist. I'll let you know if they are garbage or cool. Quote
VFR4Lee Posted November 21, 2017 Posted November 21, 2017 Old Guzzis are cool in their own Lurch from the Adams family kind of way. Especially in red. Quote
Member Contributer Dutchy Posted November 21, 2017 Member Contributer Posted November 21, 2017 Seen In Passing Quote
Member Contributer SamW Posted November 21, 2017 Member Contributer Posted November 21, 2017 Love it, currently have a '71 Ambassador mid restoration, then I might get a California II to replace my V11 Sport. Love the 80's Guzzi! Quote
timmythecop Posted December 17, 2017 Author Posted December 17, 2017 Well what do you know......I made a deal on a guzzi board to swap the red and black seat on my bike for a stock item. I met the dude in a parking lot after work. We made the swap, then he showed me a bunch of photos of my bike. !?!? Turns out, he sold the bike to the guy i bought it from. Very cool, no? I learned: It was a frame-off restoration with a 1980 CX100 motor installed (only 385 of those were ever made). It has all stainless brake lines, all new ferodo pads, custom repaint, a powerlet, electronic ignition, dyna coils, koni shocks, biturbo shock cartriges, telefix fork brace, Bub exhaust, SP2 footrest hangers, new metzelers and it had only gained 200 miles since he sold it. Cool to get the info, espescially since it was all good. I have added saddlebags, solo or stock twin seat, stock mirrors and fork gaiters. Now I am almost done gathering up a second set of the bodywork to have it painted..................BRG !!!!!! Happy. Quote
Member Contributer SamW Posted December 17, 2017 Member Contributer Posted December 17, 2017 Sounds like you ran across a great one! But I think we need more pictures! Quote
timmythecop Posted December 18, 2017 Author Posted December 18, 2017 Looking for interesting photos. In tbe mean time.......just look at the wacky shape on that gas tank ! Quote
KanadianKen Posted December 19, 2017 Posted December 19, 2017 Will this time machine present itself at Tmac? Very cool to see you diving soooo deep on this !! Quote
Member Contributer SamW Posted December 20, 2017 Member Contributer Posted December 20, 2017 At least it is not the typical tear drop cruiser tank, looks a little UFO inspired. Which Guzzi is that off? Quote
timmythecop Posted December 20, 2017 Author Posted December 20, 2017 Tank is same on 90% of all tonti frame guzzi. SP, Convert, G5, T3 etc. Used on 76ish to 96ish. Interestingly, guzzu would add/delete stripes and panels to fool the eye, but it was the same shape an all but the lemans. They often painted the very bottom, so some if it" dissapeared ". It is a wacky shape that has no real reason for being, and that is one of the reasons i like it so much. Another cool thing is they mount with no bolts. A tab goes under a rubber bung on each side of the front, and a rubber strap holds down the back. Quote
timmythecop Posted December 20, 2017 Author Posted December 20, 2017 Further into the boring for you, exciting for me : Hard to find stock mirrors arrived. Made by a company called PERSONAL. Quote
Member Contributer SamW Posted December 20, 2017 Member Contributer Posted December 20, 2017 Not boring at all, I will be in the market for either a California II or a Quota (or both) once my leg heals from my V11 incident, I am using my Ambassador as a sort of mental rehab until I can ride again. Quote
timmythecop Posted December 20, 2017 Author Posted December 20, 2017 Man, you just missed a quota on my lical c list. It went cheap. I always wanted one. Adventure touring bike 25 years before adventure touring bikes Quote
Member Contributer SamW Posted December 21, 2017 Member Contributer Posted December 21, 2017 That's the one, I'm a sucker for the dual headlights. A buddy bought a TDM and that would be a good equivalent. I think I remember that one in Maryland, seems it went quick, or did it end up on feebay? Quote
