fonque Posted December 31, 2015 Share Posted December 31, 2015 would this work as a steering stem tool for a VFR? http://www.ebay.com/itm/30mm-SPECIAL-SOCKET-TOOL-TO-REMOVE-TOP-STEERING-LOCK-NUT-many-HONDA-MOTORCYCLES-/201369676188?hash=item2ee291699c:m:mhPJXYMDr3MklYV-CysLuQw&item=201369676188&vxp=mtr would this work as a replacement for 07916- 3710101? Link to comment Share on other sites More sharing options...
squirrelman Posted December 31, 2015 Share Posted December 31, 2015 Useful but not really necessary to do what needs to be done to service the stem and bearings. The castellated nuts are not on very tight, and a few taps with a hammer and screwdriver will back them off. Link to comment Share on other sites More sharing options...
checksix Posted December 31, 2015 Share Posted December 31, 2015 Don't use a hammer and screw driver. Buy the right tool when you need it. I'm pretty sure the referenced ebay item is the correct size, I bought a similar one a few years ago and it fit fine. I used it exactly once, but knew that I was setting the correct torque when putting the nut back on, rather than guessing with a hammer. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted January 1, 2016 Member Contributer Share Posted January 1, 2016 would this work as a steering stem tool for a VFR? http://www.ebay.com/itm/30mm-SPECIAL-SOCKET-TOOL-TO-REMOVE-TOP-STEERING-LOCK-NUT-many-HONDA-MOTORCYCLES-/201369676188?hash=item2ee291699c:m:mhPJXYMDr3MklYV-CysLuQw&item=201369676188&vxp=mtr would this work as a replacement for 07916- 3710101? I have a 07916-3710100 here (07916-3710101 has the same dimensions), and it's 50mm OD, 42mm ID. Which one you need I don't know, but the Honda tool is not the same as the eBay one. Ciao, Link to comment Share on other sites More sharing options...
fonque Posted January 2, 2016 Author Share Posted January 2, 2016 Well I ended up buying one on ebay. I'll let you know if it works. I did the drift and hammer method many times on my cx500 for both the rear wheel bearing and the head bearing. It really does damage the part because the aluminum is so soft. I also tried using a pin lock wrench a few times, but it just doesn't bite very well. It slips out of place alot! Link to comment Share on other sites More sharing options...
VFRBert Posted January 2, 2016 Share Posted January 2, 2016 Buy a cheap socket of the right size and take youre angle grinder................................... Link to comment Share on other sites More sharing options...
fonque Posted January 2, 2016 Author Share Posted January 2, 2016 I don't own an angle or bench grinder. I should probably buy one at some point. It's the only common power tool I don't own. Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted January 2, 2016 Member Contributer Share Posted January 2, 2016 Wow, how many times do you guys adjust your steering stem nut? I've done mine once in 40,000 miles, and that was when I replaced the OEM with tapered roller bearings. A hammer and drift works for me. If I did it frequently I might use a tool designed for the job, but... Link to comment Share on other sites More sharing options...
wera803 Posted January 2, 2016 Share Posted January 2, 2016 I ended up buying the tool. Figured as much as I work on bikes it would be worth it in the long run. I've used it on my bike and my girlfriend's for sure. Also used it on a buddy's Superhawk. Might have used it on my Superhawk too, can't remember for sure though. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted January 2, 2016 Member Contributer Share Posted January 2, 2016 Wow, how many times do you guys adjust your steering stem nut? I've done mine once in 40,000 miles, and that was when I replaced the OEM with tapered roller bearings. A hammer and drift works for me. If I did it frequently I might use a tool designed for the job, but... I never pass up an opportunity to buy a new tool! Ciao, Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted January 3, 2016 Member Contributer Share Posted January 3, 2016 Wow, how many times do you guys adjust your steering stem nut? I've done mine once in 40,000 miles, and that was when I replaced the OEM with tapered roller bearings. A hammer and drift works for me. If I did it frequently I might use a tool designed for the job, but... I never pass up an opportunity to buy a new tool! Ciao, Okay, you got me there. Link to comment Share on other sites More sharing options...
VFRBert Posted January 3, 2016 Share Posted January 3, 2016 Wow, how many times do you guys adjust your steering stem nut? I've done mine once in 40,000 miles, and that was when I replaced the OEM with tapered roller bearings. A hammer and drift works for me. If I did it frequently I might use a tool designed for the job, but... I never pass up an opportunity to buy a new tool! Ciao, My barn is to damm small to store al my tools in a proper manner but i still buy tools when i need them (or think i need them :tongue2: ) Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 3, 2016 Member Contributer Share Posted January 3, 2016 Wow, how many times do you guys adjust your steering stem nut? I've done mine once in 40,000 miles, and that was when I replaced the OEM with tapered roller bearings. A hammer and drift works for me. If I did it frequently I might use a tool designed for the job, but... I never pass up an opportunity to buy a new tool! Ciao, Okay, you got me there. Check mine every other year . Done in 2015 so 2017 is next . Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted January 3, 2016 Share Posted January 3, 2016 Or just roll your own..... Link to comment Share on other sites More sharing options...
