zektiv Posted September 26, 2015 Author Share Posted September 26, 2015 https://youtu.be/ToV2VziG7vM There's a short video of my test of the starter motor. It seems to spin and work but it doesn't seem super strong. This is jumped to my battery. What do you guys think? How can I test the solenoid? Sent from my Nexus 6 using Tapatalk Link to comment Share on other sites More sharing options...
zektiv Posted September 26, 2015 Author Share Posted September 26, 2015 https://youtu.be/qO_D7hZsHuo Here's me cranking before pulling plugs. I'm in the middle of pulling plugs now to see how the compression is and what the cylinders look like. I'll record that when I get to that point. Thanks guys! Sent from my Nexus 6 using Tapatalk Link to comment Share on other sites More sharing options...
zektiv Posted September 26, 2015 Author Share Posted September 26, 2015 So I pulled the plugs, inspected the holes, cranked it, inspected, cranked some more, inspected... It's no easier to crank without plugs in. Maybe a skosh easier, but not significantly I don't think. It's hard to tell, tbh. Here's a video: https://youtu.be/w9O3EH8qEkg The inspection showed that the cylinders were dry. Here's a couple of photos... Tough to get a good shot, I apologize for that. Tried to get the shots when the pistons were near or at the top. So to recap: I've pulled the starter and tested it for function. I've pulled the plugs and checked for a hydrolock condition. I've tested the battery. That just leaves the solenoid, not sure how to test that. Oh, and the starter clutch; not sure how to test or diagnose that either. Any help or advice is much appreciated!!! Thanks to all who have thrown in so far... Sent from my Nexus 6 using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer paulmeisterpk Posted September 27, 2015 Member Contributer Share Posted September 27, 2015 I don't think the burned connector is causing your no crank problem, but it is something that needs to be addressed. From the video, it doesn't look like your starter is bad. Also, from your hand cranking, it doesn't look like your motor has much more friction than normal when turning over by hand. I'm still leaning toward starter solenoid, battery, or connections in the start circuit. Link to comment Share on other sites More sharing options...
TheDutchy Posted September 27, 2015 Share Posted September 27, 2015 Hard to tell from the vid, but is that starter motor spinning counter clockwise ?? Is that starter motor from the VFR or has it been replaced with a Magna starter ? Also weird.. When you manualy turn the crankshaft, it is also engaging the starter motor. This should remain free when rotating the crankshaft in the right direction. Has the starterclutch been rebuild ?? Link to comment Share on other sites More sharing options...
zektiv Posted September 27, 2015 Author Share Posted September 27, 2015 Hard to tell from the vid, but is that starter motor spinning counter clockwise ?? Is that starter motor from the VFR or has it been replaced with a Magna starter ? Also weird.. When you manualy turn the crankshaft, it is also engaging the starter motor. This should remain free when rotating the crankshaft in the right direction. Has the starterclutch been rebuild ?? To the best of my knowledge it's the original starter motor. The original owner might've changed it, I just don't know. The wear and patina match the rest of the motor but that doesn't mean much. It *is* really hard to tell from the video and I don't remember. The starter motor is still on the workbench so I'll check it out and let you know today. Sent from my Nexus 6 using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted September 27, 2015 Member Contributer Share Posted September 27, 2015 It's hard to tell from the two videos how different the force required is to turn it over. With the plugs out it seems like it's not much, if any different, but again, hard to tell. If you don't find anything else wrong, it may be time to remove the clutch cover and inspect the starter clutch. Link to comment Share on other sites More sharing options...
zektiv Posted September 27, 2015 Author Share Posted September 27, 2015 Ah, the sweet smell of victory... (Or is that oil burning off?) I figured out the problem and it turned out to be something that Dutchy pointed out way back at the beginning of the thread. I was doing all the tests and disassembling things, and during a break I pored over all the great replies to my issue when I really thought about what Dutchy was saying to look for... The ring #8 It must be at the rear of the cog (is a biatch to do, need thin fingers or use a pair of long pliers while you wiggle in the axle. I did as instructed, and immediately noticed a huge difference when manually cranking. I reassembled everything today and gave it a whirl... https://youtu.be/qowshjGLqlc It sounds glorious to me, but if a more experienced ear could listen to the engine in the above video, it'd be much appreciated. I feel like there's an underlying high pitched whine. Maybe I'm crazy. I want to thank all of you for your time and patience with this noob. If it wasn't for this excellent community I have no idea what I would've done. Thank you all very much. And Dutchy, I owe you several beers! Sent from my Nexus 6 using Tapatalk Link to comment Share on other sites More sharing options...
bigmalcy Posted September 28, 2015 Share Posted September 28, 2015 Hey Zektiv... sounds pretty sweet to me. The only whine that I can hear is the whine that the gear driven cams make: one of the VFR trademarks, and why some unenlightened individuals said they sounded like sewing machines Personally, I reckon it's that whine combined with the deep grumble out the other end that makes them sound so glorious. Glad you figured out your problem! Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted September 28, 2015 Member Contributer Share Posted September 28, 2015 Sounds perfect - just the way it should! The whine of the cam gears is what endear those engines to many owners. Glad you got it sorted. Give us some pics when you have it finished! Link to comment Share on other sites More sharing options...
Member Contributer paulmeisterpk Posted September 28, 2015 Member Contributer Share Posted September 28, 2015 Sounds great. Glad you got it sorted. Link to comment Share on other sites More sharing options...
Magsz Posted September 28, 2015 Share Posted September 28, 2015 Thanks again everyone for the huge amounts of assistance. We genuinely appreciate it! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 28, 2015 Member Contributer Share Posted September 28, 2015 Button up and take her for a ride!!! Link to comment Share on other sites More sharing options...
zektiv Posted September 28, 2015 Author Share Posted September 28, 2015 Button up and take her for a ride!!!Just did and omg awesome... Happy as hell. What a great bike, very very cool experience. Got a few questions now, but I'll post them in a separate thread... Sent from my Nexus 6 using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 29, 2015 Member Contributer Share Posted September 29, 2015 Link to comment Share on other sites More sharing options...
squirrelman Posted October 28, 2015 Share Posted October 28, 2015 Looked as if one piston top was excessively black, most likely too rich in that cylinder or bad oil control ring. Check after a brisk ride that the plug matches the others. A nice light tan is the proper color on the center electrode. Link to comment Share on other sites More sharing options...
