Oil Change Interval...8K?
WGREGT
oil analysis, dropped a full grade by 1100 miles,
Don't fear the shear... because the difference in viscosity between
the grades is only 3 cSt and thats not 3 cSt thinner or thicker... the
measurement is 3 cSt in more flow... 3 cSt in more flow doesn't risk
increase wear... our modern engines protected by modern oils don't
operate with in a narrow 3 cSt range of risk...
Blackstone graded your oil by cSt testor... that means a quantity of
oil was heated to a standard temp and the rate of flow was recorded by
a stop watch... this flow-rate is governed by resistance of the oil
flowing under gravity through the capillary tube, this test actually
measures an oil’s kinematic viscosity. The viscosity is typically
reported in centistokes (cSt), and is calculated from the time it
takes oil to flow from the starting point to the stopping point using
a calibration constant supplied for each tube... so a drop of one
grade which is only a 3 cSt difference in flow is nothing to fear...
Got an answer for everything, don't you BLS... always educational.
Thanks... :cool:
  • Replies 62
Managed 130k on my 5th Gen with regular 8k changes using Castrol. Engine still running very strong the last time I rode her.
Anecdotal I know but it worked for me.
Thanks... :cool:
A lot of theory atleast
Not theory... fact...
I choose 0W30 because it gives the right flow at the normal operating temperature of
212ºF of the engine and that would be the viscosity of 10 at operating temps... so that
means for every 1000 rpms increase Mr.RC45's oil pressure increases another 10 psi... a
30w flows more oil at higher rpms which flows more oil between the critical bearings
which carries away more heat and I'm not wasting HP just pumping oil through the blow off valve...
0w30 psi
1000 10
2000 20
3000 30
4000 40
5000 50
6000 60
7000 70
8000 80
9000 90
10000 99
11000 99 blow off by the pressure relief valve
0w40
1000 12
2000 24
3000 36
4000 48
5000 72
6000 84
7000 96
8000 99 blow off by the pressure relief valve
9000 99
10000 99
11000 99
15W50 psi
1000 15
2000 30
3000 45
4000 60
5000 75
6000 90
7000 99 blow off by the pressure relief valve
8000 99
9000 99
10000 99
11000 99
Mr.RC45 Oil Press Gauge shows the problem with oil... it doesn't want to flow when its cold this is 0w30 at 112º resisting at 18 psi
The same 0w30 at 203F Oil flowing 10 psi perfect
You see I just don't talk... I went to trouble to installed a digital
oil pressure gauge on MrRC45 to know... 0w30 at 8000 rpms 82 Psi close
enough to perfect...
End result , you believe lower oil pressure and more oil flow is better, and it probably is for fuel mileage,
For real wear protection , I prefer thicker film strength and good oil pressure.
How many miles on your 0w30 car oil, any uoa more than 700 miles, like a UOA with 2000 miles that's been Hammer headed and not used for church social events?
How are you judging thicker film strength???
Mr.RC45 has over 59,000 miles and those are miles not in moderation
either... since 98 I've been running mostly Mobil 1 10W30 Energy Conserving
oil 365 days a year... 0w30 is new and improved 30 weight...
I can pretty much guarantee, my 2 quarts of 10w40 and 1 quart 20w50(for longevity) is running thicker than your 0w30, Through out the motor including the transmission
I just wanted to see a UOA of a Hard ridden bike with significant mileage more than 2000 mile on the oci, with the 0w30 car oil.
The only thing a grade guarantees is flow measured in centistrokes cSt
its not a measurement of thickness... you're not alone thinking in
terms of thickness but its not how oils are graded...
It is time to introduce the concept of lubrication. Most believe that
pressure = lubrication. This is false. Flow = lubrication. If pressure
was the thing that somehow lubricated your engine then we would all be
using 90 weight oil. Lubrication is used to separate moving parts, to
keep them from touching. There is a one to one relationship between
flow and separation. If you double the flow you will double the
separation pressure in a bearing. The pressure at the bearing entrance
is irrelevant.
In fact the relationship between pressure and flow is in opposition.
If you change your oil to a thicker formula the pressure will go up.
It goes up because the resistance to flow is greater and in fact the
flow must go down in order for the pressure to go up. They are
inversely related. Conversely if you choose a thinner oil then the
pressure will go down. This can only occur if the flow has increased.
is irrelevant.
I'm not sure I totally buy into this flow/pressure explanation.
I know that on some pressurized oil fed engines with plain bearings that develop excessive bearing clearance, will then show lower oil pressure and shortly after that have problems with spun bearings. The oil pump is pumping the same volume of oil, but one or more of the bearings will fail. I've always been told that it is because the oil pump volume is the same but the pressure has decreased and allowed the oil film separating the plain bearings from the crank to fail and that leads to metal-to-metal contact and subsequent failure. That's what I've always been told.
I have owned bikes with roller bearing cranks and realize that they run very, very low oil pressure but a very high volume due to point contact of the roller balls which benefit in no way to oil pressure.
Blackstone reports at 10 paces! :goofy: BLS did you use the honda tool that mounts to the oil filter to get the pressure or did you tap in elsewhere? Also where did you get the display?
I started my own thread that out lines the mod...
http://www.vfrdiscussion.com/forum/index.php/topic/80193-mr-rc45-digital-oil-pressure-gauge-mod/?p=984074
is irrelevant.
I think in both cases the measured pressure has dropped because resistance to flow has decreased... this does not prove or require that flow has increased. At a given pump speed the flow should be relatively defined... shouldn't it? Resistance to flow would cause an increase in measured pressure to maintain the flow rate (e.g. increased viscosity); conversely, a decrease in resistance to flow (e.g. excessive bearing clearance) would result in a decrease in pressure with the same flow rate.
