marriedman Posted April 28, 2014 Share Posted April 28, 2014 Since I now have a 6th gen, I downloaded a copy of the service manual. However in the description there is a part that concerns me: Remember, this Factory Service Manual is far from perfect. Firstly, it presumes you have a reasonable level of mechanic/shop experience. Secondly, it contains many errors. Not just typos, but erroneous information. Some of it was fixed in errata releases in subsequent years but not all of it (trust me, I've checked). Um... should we even trust this PDF? Should I find a later printing of the guide? Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted April 28, 2014 Member Contributer Share Posted April 28, 2014 Good question, not sure where the errors are or how they are known to be errors? Link to comment Share on other sites More sharing options...
Auspanglish Posted April 28, 2014 Share Posted April 28, 2014 I have seen the odd error... for example some data in the general section which differs from that provided in the more specific chapter. Can't recall which off the top of my head. Then there is misguiding information in some procedures... which lead you to doing unnecessary extra work.. like draining all the coolant and removing throttle bodies for swapping out the front CCT... think there are also shortcuts to the stator removal/replacement... Link to comment Share on other sites More sharing options...
marriedman Posted April 29, 2014 Author Share Posted April 29, 2014 So for the easy stuff like removing wheels, oil changes, coolant flush, brake pad... normal maintenance, it's safe to use? Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted April 29, 2014 Member Contributer Share Posted April 29, 2014 So for the easy stuff like removing wheels, oil changes, coolant flush, brake pad... normal maintenance, it's safe to use?I have been using it for all of my typical maintenance, mostly for torque settings and so far so good. Link to comment Share on other sites More sharing options...
Member Contributer Havagan Posted April 29, 2014 Member Contributer Share Posted April 29, 2014 Every manual I own has errors. My FZ1 manual transposed some digits in the torque value chart and many an FZ1 owner has snapped off rear sprocket bolts as a result. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 29, 2014 Member Contributer Share Posted April 29, 2014 There's a conversion problem from Japanese to English. Link to comment Share on other sites More sharing options...
Auspanglish Posted April 29, 2014 Share Posted April 29, 2014 So for the easy stuff like removing wheels, oil changes, coolant flush, brake pad... normal maintenance, it's safe to use? Oh yeah, I use it for everything but apply common moto-wrenching sense and think critically whether certain indications don't click.. Filter it with your brain. Link to comment Share on other sites More sharing options...
Member Contributer Havagan Posted April 29, 2014 Member Contributer Share Posted April 29, 2014 Filter it with your brain. Yep. So if your manual says to torque something to 74 ft lb but the standard torque value chart says max is 50... don't do it. ;) http://www.cncexpo.com/MetricBoltTorque.aspx Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted April 29, 2014 Member Contributer Share Posted April 29, 2014 I haven't downloaded it so is it the Honda Service manual? Link to comment Share on other sites More sharing options...
marriedman Posted April 29, 2014 Author Share Posted April 29, 2014 I was more concerned with things like what mello dude & I discovered in the 5th gen front wheel removal. I followed the instructions to the letter and constantly had rubbing on the rotor after putting the wheel back on. I even posted about it on here. One day when mello was over, I told him about it and showed him the page. He said it was wrong and I did it his way - boom, no more rubbing. Of course, nothing is ever that simple with mello. We did the run-out on the disc and wheel, got out sextant and lined something up with Jupiter and sacrificed a rabbit. So, now armed with this information I can swap my wheels on my bikes. Gonna keep the 8 spoke rear and color matched front. I haven't downloaded it so is it the Honda Service manual? Yeah, that's the one. It's even had OCR text recognition for searches and bookmarks added so I won't have to do that again like I did for the 5th gen download. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted April 29, 2014 Member Contributer Share Posted April 29, 2014 I was more concerned with things like what mello dude & I discovered in the 5th gen front wheel removal. I followed the instructions to the letter and constantly had rubbing on the rotor after putting the wheel back on. I even posted about it on here. One day when mello was over, I told him about it and showed him the page. He said it was wrong and I did it his way - boom, no more rubbing. Of course, nothing is ever that simple with mello. We did the run-out on the disc and wheel, got out sextant and lined something up with Jupiter and sacrificed a rabbit. So, now armed with this information I can swap my wheels on my bikes. Gonna keep the 8 spoke rear and color matched front. He he, part of the required ritual on working on VFRs is rabbit jumping on occasion. On yours, with all the work, the rabbit definitely died and went to Jupiter. -Remember that your left rotor was bent, so I assume you are swapping rotors too. - If you got really ambitious, you could actually purchase the Factory manual for your bike..... and all the very latest updates and corrections will be included with it. Link to comment Share on other sites More sharing options...
marriedman Posted April 30, 2014 Author Share Posted April 30, 2014 - If you got really ambitious, you could actually purchase the Factory manual for your bike..... and all the very latest updates and corrections will be included with it. Yeah, I am going to buy one because I have learned that the physical copy is pretty damned convenient sometimes. Do you recommend buying the Honda Service manual or the Haynes? Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted April 30, 2014 Member Contributer Share Posted April 30, 2014 - If you got really ambitious, you could actually purchase the Factory manual for your bike..... and all the very latest updates and corrections will be included with it. Yeah, I am going to buy one because I have learned that the physical copy is pretty damned convenient sometimes. Do you recommend buying the Honda Service manual or the Haynes? Buy the Honda manual. Go to www.helminc.com they are the authorized reseller for Honda manuals. I bought my 5 Gen owner's manual and 'Common Service Manual' from them. They were out of stock on the 6 Gen Service Manual back when I bought the other two but I may look into getting one now though. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted April 30, 2014 Member Contributer Share Posted April 30, 2014 - If you got really ambitious, you could actually purchase the Factory manual for your bike..... and all the very latest updates and corrections will be included with it. Yeah, I am going to buy one because I have learned that the physical copy is pretty damned convenient sometimes. Do you recommend buying the Honda Service manual or the Haynes? Buy the Factory manual from the dealer or online. Specify your model year of your bike. - -Haynes is good fire starter. A thought on the wheels...... just get the 8 spoke painted like the new color and leave well enuff alone already on the front? Link to comment Share on other sites More sharing options...
