How frequently are you adjusting your chain?
wagzhp
I've had my bike for about 2 months now ('99 VFR800FI) and have had to adjust the chain twice already. (I bought the bike used, with about 58k miles on it, and no idea when the chain/sprockets were last replaced.) Everything I have read indicates that their should be .75 - 1.5 inches of deflection in the chain while on the center stand. Does that sound correct?
The first time I adjusted it to .75 inches and withing a few days (~200 miles) the deflection had gone to 1.5 inches. I let it go for a while, until the chain started hitting the center stand while in the up position, and adjusted it to 1 inch of deflection. Well, after just a couple of days, the chain is already hitting the center stand when in the up position and has enough free play to touch the bottom chain slide on the swing arm.
The chain and sprockets look fine, no visible signs of wear or distortion. Am I performing the adjustments incorrectly, measuring incorrectly, or am I just due for a new chain (and possibly sprockets)?
If you haven't been overtightening it, i.e. it doesn't have much deflection at some point in the chain travel with the bike on the centerstand, then it's time to replace the chain.
After I put on a new, quality (DID or RK) chain it will need to be adjusted after a couple hundred miles or less. After that adjustment, maybe after a few thousand miles it may need to be snugged up a touch. If I have to adjust more than once in a couple thousand miles then I figure the chain is on its way out. A well lubed chain will last around 20,000 miles, or more depending how well lubed it is.
BTW, and I'm sure you know this, it's better to be a bit too loose than a little too tight.
I put mine on the centerstand and push up on the chain. If it is close to underside of the swingarm with a minimum of force, I figure it's good. I may be going about it wrong, but that's the way I do it. I also rotate the wheel and check in multiple places and go by the area with the least amount of slack.
Hmm, OK. I need to more thoroughly check that I don't have any tight spots as i rotate the chain all the way around a full rotation. (I did spot check it, but I think I need to double-check it at more closely measured intervals.) I can very easily push the chain up to touch the bottom of the swing arm, and like I said, it has enough slack to touch the center stand when hanging slack. That seems way too loose to me... Given that a chain is good, I would think that as long as I don't have an out of round condition in the sprockets causing a tight spot, even if I did over tighten a little, the chain would stretch to the slack it needs and stop.
Note that I can't fit my torque wrench on the bearing holder pinch bold so don't know if I'm tightening to exactly 54 lbs-ft, but I'm nearly certain that I'm getting it tight enough to not slip. I'm using the factory supplied tool kit wrench with the extension and putting nearly all the force I can manage (and would guess that if anything, I am over tightening it). (I've been wrenching on cars for many years and have a pretty good feel for approximate torque values when a torque wrench just won't fit.) But just to be sure, I'm going to mark things the next time I adjust it and make sure that's not the problem.
cheap chain will stretch fast, Good chain hardly ever need to adjust, maybe one to 3 times in its life span
Thats a bolt you really should torque and use a quality tool on, generally if a chain developes tight spots, will will not show stetch, cause the kinking prevents full stetch out of the chain.
58,000 miles, more than likely its atleast had two chains and that one is on the way out.
You may notice when you sit on the bike that the chain no longer hits the center stand. As long as it isn't slapping against the C-stand when riding it should be ok. I keep mine just tight enough to touch the bottom of the swingarm. I've only had to adjust it about once a year.
If the chain is worn, it will need more adjusting.
Clean the chain very good and don't lube it.
Take the bike for a ride.
If there is a lot of clicking and clunking from the chain, it should be replaced.
Thanks for that tip. I'll check and see how close to the c-stand the chain is with weight on the suspension.
Say, if you are in Rocklin we might be neighbors. I live near the Rocklin Thunder HS, how about you?
Thanks. I'll give that a try and see what things sound like.
Sitting on the patio hearing whatever is going on at the HS stadium tonight as I type. Will send PM.
I'll have to see if I can get creative with a socket, a flexible extension, and the torque wrench...
Another way to check the condition of the chain is to grasp a link at the 3 o'clock position on the rear sprocket. If you can pull the chain any significant amount away from the sprocket - esp if you can see daylight between chain and sprocket, it's due for replacement.
I've been finding out by going though chains as I learn, that it comes down to when I get a new chain I'll run it about a hundred and check & adjust, then about a 1000m later readjust, and it's good for muti K miles........ and when it start needing adjustment again then it's starting to get to the point of replacement again...........
Lesson learned is loose is better than tight(as mentioned above)...........I stay between 1" to 1 and a quarter inches.......... I check on cs when chain is cool.....
You dont need an extension, just a 3/8ths torgue wrench and a regular socket, preferably a 6 pointer.
OK, I cleaned the chain really well and gave it a whirl and it's relatively quiet. No tight spots as it rotates all the way around. I lubed it up, readjusted it, marked the adjustment point, managed to get my torque wrench on the pinch bolt and tightened it down to spec. I also checked the free play at the 3 o'clock position on the rear sprocket and it does have about 3/16" play, but no daylight between the chain and sprocket. Looks like I'm just about due for a new chain.
Now comes the quandary of changing up the gearing... I use the bike for commuting during the week and pleasure on the weekends, and while I like getting the 45-48 mpg I'm seeing, I would also like a little more low end punch. I'm thinking stock on the front (17t) and plus 2 on the rear (45t)
530 Steel Sprocket Set w/ Your Choice of Premium D.I.D. 530 X'ring Chain - HONDA VFR 800F1 98-01
##*D1080001 DID 530 CHAIN OPTIONS:DID 530 VX Gold X'ring FRONT SPROCKET SIZE:17 - Stock REAR SPROCKET SIZE:45 US $207.95 1 US $207.95
Anyone else running this combo and able to provide insight/feed-back?
I have the 17-45 gearing on my "99 and really like it. It does turn a bit faster at highway speeds: about 5900 rpm vs about 5500 rpm at around 70 mph. But the trade-off is worth it IMO. I've changed a few other things so I don't know if the mileage changed any.
You really think the DID VX chain won't be fine for the VFR? I don't know that I would classify any DID chain as "crap". :tour:
I have the DID but don't remember which one I bought. I'm pretty sure I bought the VX and have a little over 16,000 miles on it. I haven't been as good as I should have been with oiling it so another 4,000 miles or so and it will be time to replace it. The stock chain went 19,300 miles, also with less than perfect maintenance.
Thanks FJ12Ryder, That's about the change I was hoping for.
spud786, I thougth all of the DID chains were supposed to be pretty high quality. Is there really a noticable difference bewteen the 3 grades?
Some DID chains are no better than any one elses, Thats why I mentioned the specific chain , either zvm, VM, or Zvmx grade of DID chain. The VX line is a Budget chain, smaller ect. I would not get that myself.
I've had DID chains that got tight links and didn't last long.......but the
http://www.sprocketc...reet-chain.html
chain has made me a happy rider. It does what I want from a chain.....
Yep, that is the chain I have and it hasn't needed any adjustment with the first 1000 miles. I'm guessing this beast won't stretch much if it is designed for a Hayabusa, ZX14, etc..
Been using a prooiler since I replaced the chain last time and I haven't had to adjust in the 8500 miles since I installed them. I do run it on the loose side if that makes any differance. One of the vey few things that I have found to be better loose than tight...
OK, The recently adjusted chain is already way beyond loose and the pinch bolt/adjustment point didn't budge. It's stretching like there's no tomorrow... So i bit the bullet and ordered a new chain and sprocket set.
-FRONT SPROCKET SIZE: 17 - Stock
-DID 530 CHAIN OPTIONS: DID 530 ZVMX Gold X'ring ($39.00)
-REAR SPROCKET SIZE: 45 ($13.00)
It should be here mid-week and I've already got Friday off work and penciled in as a maintenance day. :-)
