Member Contributer Dutchy Posted August 24, 2012 Member Contributer Share Posted August 24, 2012 Front tire covered in spots, rear has a little bit. Did not like the feel of the front wheel.... This may explain.... Link to comment Share on other sites More sharing options...
Baileyrock Posted August 24, 2012 Share Posted August 24, 2012 RIDE!!!! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 24, 2012 Author Member Contributer Share Posted August 24, 2012 Hmmm, just notice the dry cracks in the grooves...... Link to comment Share on other sites More sharing options...
Member Contributer Yokel Posted August 24, 2012 Member Contributer Share Posted August 24, 2012 Surely that's not the rubber failing... it looks mildly like silica? Better bet is tar, gum or some other nasty crap picked up from the road... Does it rub off? Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted August 24, 2012 Member Contributer Share Posted August 24, 2012 Riding around dikes will take care of this issue. Link to comment Share on other sites More sharing options...
Member Contributer Axel_7 Posted August 24, 2012 Member Contributer Share Posted August 24, 2012 Heat it up with a torch (carefully) and get a trowel and try to see if it will scrap off/// Not sure if i would ride with it like that? Link to comment Share on other sites More sharing options...
Member Contributer CSFS Posted August 24, 2012 Member Contributer Share Posted August 24, 2012 Looks like bitumen picked up from a melted road surface... Not sure I'd put a torch near it but a flat scraper and a little persistence should see it off the tyre... Link to comment Share on other sites More sharing options...
Member Contributer Africord Posted August 24, 2012 Member Contributer Share Posted August 24, 2012 To me, it just looks like oil and dirt, maybe ATF? I think I would just hit with dishwashing detergent and water. It should break up the oil. Link to comment Share on other sites More sharing options...
Beck Posted August 24, 2012 Share Posted August 24, 2012 Were you riding a lot at night lately??....Might be just some western european coastal snipes you've been running over......Their diet of earthworms, beach clams and juvenile red squirrels and moles results in that kind of slimey, oily stuff in their bellies.... Link to comment Share on other sites More sharing options...
Member Contributer Muff Posted August 25, 2012 Member Contributer Share Posted August 25, 2012 Looks like syphilis to me Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted August 25, 2012 Share Posted August 25, 2012 Just ride. It'll wear off. Link to comment Share on other sites More sharing options...
interceptorrider Posted August 25, 2012 Share Posted August 25, 2012 Looks like road tar from a Michigan tar & chip job. An annual hazzard after the snow/thaw/freeze/bust cycle in Southeast Michigan. I would peal/scrape as much as I could off and then have another look. I would not use any more heat than I could get out of a hair dryer. Ride safe dude. Link to comment Share on other sites More sharing options...
