Member Contributer Rice Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Just looking for reinforcement here and some advise. My dash light indicated to me that something's amiss the other day by going off in the middle of a ride. So, I charged the battery and started the bike. Measuring voltage across the bat. terminals at idle indicates slow voltage drop and no gain, going from 12+V into 11V territory as the bike idles. Checked voltage across the three yellow wires coming from the stator (RR unplugged, bike running). ZERO. Between all three wires there is zero voltage. So, before I ask the next question, it IS the stator, right? Been checking DC voltage... Readings: Next steps: 1 - Buy a new stator. Question - Where? Which one? 2 - Anything else I should buy, like gaskets, etc... 3 - Will the oil leak out when I open the stator cover or will it be a few drops? Thanks in advance! Oh, and I do solemnly swear to stop smirking every time I see another electrical thread. Going forward. Link to comment Share on other sites More sharing options...
Member Contributer Chuckster Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Your stator voltage output seems lower than would be expected (should be 60+?). Also, I would expect the same output between all wiring combinations when testing (your results of 32 vs. 42?) Chuck Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Stator volts look low and you have continuity to ground. Um -- its toast. Link to comment Share on other sites More sharing options...
spud786 Posted October 7, 2011 Share Posted October 7, 2011 Just looking for reinforcement here and some advise. My dash light indicated to me that something's amiss the other day by going off in the middle of a ride. So, I charged the battery and started the bike. Measuring voltage across the bat. terminals at idle indicates slow voltage drop and no gain, going from 12+V into 11V territory as the bike idles. Checked voltage across the three yellow wires coming from the stator (RR unplugged, bike running). ZERO. Between all three wires there is zero voltage. So, before I ask the next question, it IS the stator, right? Been checking DC voltage... Readings: Next steps: 1 - Buy a new stator. Question - Where? Which one? 2 - Anything else I should buy, like gaskets, etc... 3 - Will the oil leak out when I open the stator cover or will it be a few drops? Thanks in advance! Oh, and I do solemnly swear to stop smirking every time I see another electrical thread. Going forward. Stator is fried, how many miles on your 06? OEM are the best, longevity wise, yeah they will fail well over 50,000 mile average, but still alot better than Aftermarket, which typically never see that much. Once the stator is repaired, you then have to test out your RR, but 6th gen RR's rarely fail, its a good product. Link to comment Share on other sites More sharing options...
SEBSPEED Posted October 7, 2011 Share Posted October 7, 2011 If it were my bike, I would put an oem stator in it. Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted October 7, 2011 Author Member Contributer Share Posted October 7, 2011 OEM stator it is. Thanks a bunch gents! Do I need to buy a new gasket and drain oil to change it out? P.S. About 35K on the bike. Link to comment Share on other sites More sharing options...
SEBSPEED Posted October 7, 2011 Share Posted October 7, 2011 I would order a gasket just in case. Cheap enough to have on hand. Not sure if you'll need to drain the oil if you put the bike on the centerstand. Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Hey Rice, I just did this on my 2004...get a new gasket and you will need some gasket in a tube to seal just the two small areas where the crakcase halves mate. Oil loss is almost none...I mean just a couple of drips, so no worries there. You will need some patience to scrape off the old gasket if it is cooked on to the cover the way mine was...used gasket remover and a utility razor blade (carefully). Maybe someone else will chime in where I might have made it more difficult than it needed to be. I'm a self-proclaimed mechanical pygmy. I went with the OEM stator btw... Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted October 7, 2011 Author Member Contributer Share Posted October 7, 2011 Thanks for the advise, doc. Just looked up stator and gasket on Bike Bandit. $237 for the stator??? That bites. Anyone know a cheaper source? Link to comment Share on other sites More sharing options...
Tightwad Posted October 7, 2011 Share Posted October 7, 2011 For an OEM stator call Keith at Mason City Honda. Tell him you are from VFRD. Aftermarket stator are wound differently than OEM btw...that is why they perform differently. I can never keep them straight, but one is WYE wound and the other is DELTA wound. Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Thanks for the advise, doc. Just looked up stator and gasket on Bike Bandit. $237 for the stator??? That bites. Anyone know a cheaper source? Ron Ayers.com for sure Rice...they are time and time again the cheapest I find for OEM parts. Shipping should be pretty quick to you. I looked and in June I paid $195 for the stator and $121 for the R/R, $10.23 for the gasket. Link to comment Share on other sites More sharing options...
Member Contributer sa1713 Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Find Custom Rewind in Alabama. $100 shipped and mine works wonderfully. Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Find Custom Rewind in Alabama. $100 shipped and mine works wonderfully. Did you have to wait for yours to be reconditioned or did they just require you to send your old one in exchange? Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted October 7, 2011 Author Member Contributer Share Posted October 7, 2011 Here is what I have so far: Gasket | Stator Bike Bandit | 13.47 | 237.95 Ron Ayers | 10.23 | 194.11 Service Honda | 10.52 | 182.34 Mason City H. Keith is off. Will update tomorrow. Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Shipping cost may be your determining factor if you opt for an OEM part instead of the rewind... Link to comment Share on other sites More sharing options...
Member Contributer sa1713 Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Find Custom Rewind in Alabama. $100 shipped and mine works wonderfully. Did you have to wait for yours to be reconditioned or did they just require you to send your old one in exchange? I had Gary recondition mine. Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted October 7, 2011 Member Contributer Share Posted October 7, 2011 Find Custom Rewind in Alabama. $100 shipped and mine works wonderfully. Did you have to wait for yours to be reconditioned or did they just require you to send your old one in exchange? I had Gary recondition mine. Thanks, that's great to know. Link to comment Share on other sites More sharing options...
spud786 Posted October 7, 2011 Share Posted October 7, 2011 OEM stator it is. Thanks a bunch gents! Do I need to buy a new gasket and drain oil to change it out? P.S. About 35K on the bike. Early failure, what kind of oil was ran in the bike the majority of the time , any wiring damage, corroded or burnt contacts ect, ever on the bike? Yeah you want a gasket, Id probably just change the oil verses fiquring out how much too readd. But should be less than a quart. Link to comment Share on other sites More sharing options...
Tightwad Posted October 7, 2011 Share Posted October 7, 2011 Unless some corrosive material was in the oil, the oil type should have very little to do with a failure. Link to comment Share on other sites More sharing options...
spud786 Posted October 7, 2011 Share Posted October 7, 2011 Unless some corrosive material was in the oil, the oil type should have very little to do with a failure. It depends if a certain oils cleaning ability is so strong it weakens the epoxy. I want that info for research, to rule out. There are numberous additional reasons though How well the stator left the factory, heat and vibration subjected to, ect. Link to comment Share on other sites More sharing options...
