Posted (edited)
1998 VFR 800, previous owner said he swapped in a 2000 wiring harness
Rode fine for about 8km, got to a red light, died. Tried to start and only got a click from under the seat. Pushed it off the road onto the sidewalk, waited a few minutes, clicked the starter again and it started idled and revved fine. As soon as I moved it about 5 feet and got ready to get on the road it died again. Got a jump start a bit later from my Grandpa (his car was off), started and idled fine until moving about 5 feet again. Towed it home, when I got home I hooked it up to a multimeter which read 17.5-18.3v with the bike turned off. While cranking the starter it would drop to 15 then go back up to 17.5-18.3v. Hoping that my multimeter is not broken, ideas?
The R/R connectors were melted and the stator wires charred, re soldered all of them and taped them back up. Checked all the fuses and all were ok. Now when the starter is pressed I only get a click. Jump starting did not work, battery swap did not work (other battery starts my other bike fine). Swapped the starter relay with the one that came spare with my bike, did not help. All the lights on the bike come on no problem. Ordered a VFRness, stator hardwire kit, and new R/R connectors.
This is my only mode of transport now that insurance and plate was taken off the other bike :(
UPDATE:
Now the bike runs ok with no break light bulbs plugged in, as soon as you turn the bike off, plug them in, and turn it on, it wants to stall. Mechanic thinks it is the R/R as someone at honda canada told him that the stock one controls the fuel pump??
Edited by silverbullet132
  • Replies 73
Top Posters In This Topic
Your got some pretty funky numbers for voltage. You sure with the bike not running you got 17.5 Volts? Crazy weird. Check again.
But what obvious going on is your R/R is toast, and its been frying all the nice wires in you bike.
--Dont ride it anymore untill you replace it. In the mean time, go through al the wires and check condition. Fix anything that looks burnt.
- Check out the stator too.
- Charge battery and take it to be load tested. Chances are the R/R fried that too.
http://www.vfrdiscus...__fromsearch__1
Posted (edited)
Buying a new R/R local soon, yes I am sure it was not running the key was not even in the ignition.
-Already fixed the only ones that looked burnt, and ordered new connectors/hardwire kit/VFRness
-How do I check the stator if the bike does not run? (just read your link, grr wish i tried that before I soldered the connections)
-Canadian Tire (battery is a Motomaster Eliminator 12-BS) offered an exchange already but don't have the exact battery in stock. What other batteries will work on the vfr?
Start with getting a good battery. Generally batteries are based on size. There are a lot of options.
Stator checks - pull connector and check pin to pin. Set for resistance. Should be less than 1.0 -- Check each pin to ground. - Should be infinity.
Next you need the bike running. Pin to pin, volts VA. Should start 15ish and rise to 60ish + with revs.
If the bike wont start, you may have other problems.
Btw - dont waste your money on a Honda OEM R/R part. Check into previous links. You should look into a MOSFET style or a Compufire part.
GL
GL
Getting a SHINDENGEN FH0122AA. Will try a new multimeter, but my current one reads 1.0 on all 3 for resistance and the battery was too low to check the grounds
You don't need voltage to make sure that your grounds are good.
I meant the battery on the multimeter
Posted (edited)
Changed the battery in my multimeter, it now reads 0.7-0.8 ohms on the 3 wires coming from the stator and 0 continuity on all 3. Battery also now reads 12.5v.
Another update:
-Battery reads 12.75v
-Leak tested, meter reads 0.8mA
-The harness side of the R/R connector positives read 12.75v (positive lead on the red/white and common lead on the frame)
-Continuity between the harness side of the R/R connector negatives and the ground connector on the right side of the frame
Posted (edited)
Looks like it was, and he said it was done because the lights etc would randomly not work which is supposedly very common
Sounds like the R/R is kicking the bucket. Mine will get hot and sometimes when I pull in the clutch, the bike will just die. It'll act as if the battery is dead until it cools down enough.
Someone local has the FH0122AA, so I will add that in once my VFRness gets here. How long does wiremybike typically take to ship them out?
I hope the crook batteries in your multimeter meant the charging figures were wrong? I believe the PGM FI controller is not too fond of high voltages (not trying to panic you but it has to be considered). How many K's did the previous owner rattle up on his 'new' wiring harness before you picked it up?
Not too sure how many he put on the harness, and the multimeter was never hooked up while the bike was able to run. As so, I have no charging voltages.
Swapped the battery with a known good one, still just a click. Hopefully the new R/R fixes this, if not, what could it be? Have already swapped the starter relay.
If a know good battery won't start the bike, it cannot be the R/R (although it too nay be bad) because if it us nor running it has nothing to regulate or rectify. Sounds like it is the harness to me. BTW... My 5th gen has 43000 miles with stock everything. No failures.
I hope that it is not the f'ing harness...
If the bike has started and run with the new harness I would be checking for loose connections around your starter motor circuit, battery and all earth points. There are earth conglomeration points (generally concerned with engine control and instruments not starting circuits) taped into the harness near the RR and battery area, the replacement harness may have a corroded one of these. I think you are looking at some poor workmanship from previous owner.
Take a piece of heavy wire and touch to your battery directly to the starter motor input connection to confirm the starter will run and confirm a problem between battery and starter. Careful though this could lead to finger burning, use pliers to hold the wire.
Ah crap. So I use a piece of wire to connect the positive battery terminal to the other lead on the starter relay?
You might be able to temporarily fix the starter motor by taking it apart and cleaning it out.
Worked for me a couple times years ago with an old Yamaha before I finally got a rebuilt one and replaced it.
Lots of black dusty grunge in there. :dry:
