Member Contributer FHR Posted February 16, 2011 Member Contributer Share Posted February 16, 2011 Ive only had my 06 VFR 800A for a few months and have only ridden a couple thousand miles on it when the weather has permitted on my days off work. I got a couple rides in last week. Today it snowed. I really love the bike. The only thing I have noticed that has caused me concern (not counting the looming specter raised by all the posts about electrical problems) is the suspension. First, let me say I have very little knowledge or experience wrenching. I did put a fork kit and a Fox shock on my 83 KTM dirt bike years ago, which did wonders BTW. I am only speaking from the perspective of what I feel when riding. I feel as though the bike, the front wheel actually, is not maintaining good contact with the road during turns on the less than perfect road surfaces we have in my area. I also hear a clunk sound periodically which gives me the impression (and I may be wrong) that it is on the rebound stroke in the front forks. I have read and re-read the many posts about suspension fixes in this forum including the many helpful, knowledgeable posts by members like BaileyRock, JamieDaugherty and SEBSPEED about retrofitting shocks from other bikes to accomplish results on a budget. Im trying to absorb all of that sometimes conflicting info and make sense of it. But it is coming slow (Im old and dont learn as quickly as I once did.) I weigh 225 lbs, so, from what Ive learned here so far, the factory settings are for much lighter riders than me and the stock suspension is undersprung, i.e. the spring rates of the forks and shock are not strong enough to support my weight and to adjust proper sag while keeping sufficient travel available, (not to mention valve issues.) I feel the urge to fix the suspension. When talking with my buddy, a longtime rider who has a Ducati ST3s (with OEM Ohlins front and rear) about what options I might have, (e.g. change the fork springs and re-valve or a kit and a new rear spring and revalve or a new shock) he tells me we are old men who dont push our bikes anywhere near their limits and I probably wouldnt even notice the difference. While hes right about the old part, I still think I would notice the difference in handling. The primary purpose of the suspension, after all, is to keep the wheels in contact with the road surface. Right? Better handling is also a safety feature. Right? Before I go spending a bunch of cash without consulting she who must be obeyed, I think I should do some of the minor adjustments that are available, set the sag, and then test ride the variations. I have an ABS model so there is an external preload adjuster for the rear shock. When I turned it up only one click, the only difference I noticed was the front fork seemed to dip more under heavy braking. Clearly the front forks must be adjusted in balance with the rear. Im not sure how to adjust the forks preload (anybody?) I believe it is the small screw head in the top center of each fork. I bought a service manual but I havent found info on adjusting the preload. I have a dream set up in mind. Ive checked the Ohlins website and priced a 3 way adjustable shock, compatible with a 6th generation VFR. Now I know why they call them shocks! Ive also looked at the Traxxion kit to replace essentially all the internals of the forks, which is also expensive. Does Ohlin have such a thing for our VFR front forks or will they do a set? These suspension upgrades will add 35-40% cost to my bike, which of course does not translate into an equal amount of resale value (although the originals can be reinstalled if I sell it and the new units can be sold separately.) Am I out of my mind obsessing over this? My thinking is, I can ride with a smile on my face or I can ride with a BIG smile on my face. Thanks for taking the time to read this, Any helpful suggestions will be gratefully considered. Link to comment Share on other sites More sharing options...
Monk Posted February 16, 2011 Share Posted February 16, 2011 Here's some links that might help..... I'd 1st want to set my sag correctly before going to after market parts.(the 1st one is the best, anything this guy has to say is right-on). http://www.fireblades.org/forums/articles-general/47915-setting-suspension-sag-your-motorcycle-yourself.html http://www.motorcyclistonline.com/howto/122_0508_motorcycle_suspension_setup/index.html http://www.ehow.com/how_4602262_setup-suspension-sportbike-motorcycle.html http://www.dynobike.com/motorcycle_suspension.htm Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted February 16, 2011 Member Contributer Share Posted February 16, 2011 @225lb your suspension is in over its head if you want to do more sport-type of riding. Since you are a novice to all things suspension, and since I've been/am in the same shoes, I would recommend finding a reputable local suspension shop, bring the bike to them and have them do all the work. You will pay more, but it's worth it. For more reasons than one. If you feel adventurous, you can try doing it on the cheap. I went this route and to this day I wonder if what I have accomplished (with the help of others on here) is the best it can be or if there is large room for improvement. Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 16, 2011 Author Member Contributer Share Posted February 16, 2011 Thanks, John, for the links and the good advice. I appreciate the time it took for you to attach those links. I've watched a lot of Dave Moss videos and the concepts are beginning to sink in. Setting the sag and testing will definitely come before I spend any money. Rice, I'll check for a reputable local suspension shop and seek their advice. Thanks Link to comment Share on other sites More sharing options...
Chaz06i Posted February 16, 2011 Share Posted February 16, 2011 I would definalty talk the 3 Boys listed above. They know there stuff. I took there advice and many others, (same readings as you) and had my suspension re-done. I only did step 1 & 2 in my 3 step process. I put in new springs in front (step 1, $100) for my weight and then went to step 2. Step 2 was to have Jaime re-build and revalve a CBR600 F4I Shock. Shock I got off ebay for $35 and Jaime was $300. Step 3 will be to get CBR600 F4I fork intenals and then have Jaime re-built and re-valve them. I think that I could have all that done for less than an Elka 3-way rear shock. This of course is just the route I am choosing to run. Good luck with what ever you choose. :fing02: Link to comment Share on other sites More sharing options...
Member Contributer Polarbear Posted February 16, 2011 Member Contributer Share Posted February 16, 2011 Oh! :blink: Something I definitely need to do, I know my suspension is all wonky... :blush: I'll have to go see my friend mechanic this summer (after I do all the usual maintenance--engine/brake oil, replace lost fairing bolts, install illuminating turn signals, warm grips, etc... it may take a while to do all this) and we'll set it properly, or in the ballpark anyway. Should be safer to ride that way. Thanks for reminding me to do that, and thanks for the videos Monk and others. :fing02: C Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 16, 2011 Author Member Contributer Share Posted February 16, 2011 I would definalty talk the 3 Boys listed above. They know there stuff. I took there advice and many others, (same readings as you) and had my suspension re-done. I only did step 1 & 2 in my 3 step process. I put in new springs in front (step 1, $100) for my weight and then went to step 2. Step 2 was to have Jaime re-build and revalve a CBR600 F4I Shock. Shock I got off ebay for $35 and Jaime was $300. Step 3 will be to get CBR600 F4I fork intenals and then have Jaime re-built and re-valve them. I think that I could have all that done for less than an Elka 3-way rear shock. This of course is just the route I am choosing to run. Good luck with what ever you choose. :fing02: Chaz, Thanks for your comments. when you have completed your project would you tell us about how the modifications affected the feel and handling of your bike? BTW I picked mine (also a 2006) up from a seller a little north of you in Anacortes, WA. Link to comment Share on other sites More sharing options...
Baileyrock Posted February 16, 2011 Share Posted February 16, 2011 Hello, and welcome if I haven't mentioned that before! :biggrin: Yes 225 is over what the stock bikes springs were ideally designed for, but I have to ask What Tires are you running and what pressures? While the the suspension will be soft for your weight the VFR is more than capable of running a Rapid pace with a 225lb guy and stock suspension IMO, your issues sounds more TIRE related at the moment unless you are really pushing the bike! :blush: Of course the bike will work Better with the proper spring rates and proper damping for those springs and by all means if you have to funds to upgrade the suspension, Do It now! But first slap on a set of Michelin Pilot Powers(or similar), set sag & pressures and you should be able to haul pretty quick AZZ on that thing w/o any lack of grip issues IMO. :fing02: BR Link to comment Share on other sites More sharing options...
Member Contributer Gerrys02800 Posted February 16, 2011 Member Contributer Share Posted February 16, 2011 My bike is a 2002 and I am at 215lbs. I read a lot of posts and spent a lot of time in the suspension section of the forum. I lucked and found a fellow VFR member who sold me his stock shock for $30.00 and then was kind enough to send it to Jamie for me. Jamie put on a heavier spring and upgraded the valving. Also bought new fork springs. I have the GIVI 3 pce luggage set up. It is now getting warm enuff to work on the bike. Springs are in and the rear shock next week. Still........ I have a few weeks to go before all the snow is gone.:angry: Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted February 16, 2011 Member Contributer Share Posted February 16, 2011 Unless you're really pushing the bike that hard, you won't need the AK fork cartridges. Stiffer springs and the race tech valves should be a good start for the front without breaking the bank. Rear is up to you. Can't remember if the 929 shock works, but if it does, getting it resprung will be good as well. No need to drop $2000+ on suspension. Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 16, 2011 Author Member Contributer Share Posted February 16, 2011 Hello, and welcome if I haven't mentioned that before! :biggrin: Yes 225 is over what the stock bikes springs were ideally designed for, but I have to ask What Tires are you running and what pressures? While the the suspension will be soft for your weight the VFR is more than capable of running a Rapid pace with a 225lb guy and stock suspension IMO, your issues sounds more TIRE related at the moment unless you are really pushing the bike! :blush: Of course the bike will work Better with the proper spring rates and proper damping for those springs and by all means if you have to funds to upgrade the suspension, Do It now! But first slap on a set of Michelin Pilot Powers(or similar), set sag & pressures and you should be able to haul pretty quick AZZ on that thing w/o any lack of grip issues IMO. :fing02: BR Hi BR.! You kindly welcomed me in the official welcome section. Tires are original stock. I can't remember which brand; but they had about 1900 miles on them when I got the bike a few months ago. Tire pressure was initially an issue but I corrected that and they are now at what is recommended in the specs of the service manual as set by the local Honda dealer service shop. With all respect for your superior knowledge and experience, I'm pretty sure it is not a tire issue. I'm not pushing the bike's limits as far as I know, but I am trying to force myself up to the outer edges of my personal comfort zone. Maybe my limitations are the problem! :huh: Ironically, today my wife emailed me to tell me my set of Michelin Pilot Road 2's were delivered at home. I'm planning to save them until I get more wear on the current tires. "by all means if you have to funds to upgrade the suspension, Do It now!" Well that is a problem. There are many responsibilities and it is always :lobby: Thanks for your insight. Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 16, 2011 Author Member Contributer Share Posted February 16, 2011 My bike is a 2002 and I am at 215lbs. I read a lot of posts and spent a lot of time in the suspension section of the forum. I lucked and found a fellow VFR member who sold me his stock shock for $30.00 and then was kind enough to send it to Jamie for me. Jamie put on a heavier spring and upgraded the valving. Also bought new fork springs. I have the GIVI 3 pce luggage set up. It is now getting warm enuff to work on the bike. Springs are in and the rear shock next week. Still........ I have a few weeks to go before all the snow is gone.:angry: Thanks, Gerry. I can't wait to hear what you think of the results you get from those changes. That is certainly more economical than my dream scheme and may be all (or more than) I need! :biggrin: Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 16, 2011 Author Member Contributer Share Posted February 16, 2011 Unless you're really pushing the bike that hard, you won't need the AK fork cartridges. Stiffer springs and the race tech valves should be a good start for the front without breaking the bank. Rear is up to you. Can't remember if the 929 shock works, but if it does, getting it resprung will be good as well. No need to drop $2000+ on suspension. You are probably correct,Yoshi, and I thank you for helping save me from myself! That's why entitled this thread "obsession." I've got to get a grip! Still, I have this feeling in my gut. . . . No wait. I'm okay, I'm okay, now. Link to comment Share on other sites More sharing options...
Monk Posted February 17, 2011 Share Posted February 17, 2011 Hello, and welcome if I haven't mentioned that before! :biggrin: Yes 225 is over what the stock bikes springs were ideally designed for, but I have to ask What Tires are you running and what pressures? While the the suspension will be soft for your weight the VFR is more than capable of running a Rapid pace with a 225lb guy and stock suspension IMO, your issues sounds more TIRE related at the moment unless you are really pushing the bike! :blush: Of course the bike will work Better with the proper spring rates and proper damping for those springs and by all means if you have to funds to upgrade the suspension, Do It now! But first slap on a set of Michelin Pilot Powers(or similar), set sag & pressures and you should be able to haul pretty quick AZZ on that thing w/o any lack of grip issues IMO. :fing02: BR Hi BR.! You kindly welcomed me in the official welcome section. Tires are original stock. I can't remember which brand; but they had about 1900 miles on them when I got the bike a few months ago. Tire pressure was initially an issue but I corrected that and they are now at what is recommended in the specs of the service manual as set by the local Honda dealer service shop. With all respect for your superior knowledge and experience, I'm pretty sure it is not a tire issue. I'm not pushing the bike's limits as far as I know, but I am trying to force myself up to the outer edges of my personal comfort zone. Maybe my limitations are the problem! :huh: Ironically, today my wife emailed me to tell me my set of Michelin Pilot Road 2's were delivered at home. I'm planning to save them until I get more wear on the current tires. "by all means if you have to funds to upgrade the suspension, Do It now!" Well that is a problem. There are many responsibilities and it is always :lobby: Thanks for your insight. Just picking apart some of what you said about tyres...... You said you had the pressure adjusted by the mc service shop.... That brings to my mind, how often are you checking the pressure ( f36 / r42 cold ) I'd say not to go any more than 3 days without checking....... Get a bicycle floor pump( about 5 pumps a pound for the rear / 3 for the front) $20/30..... I'd also check to see if you've developed edges being that it's not that curvy for the most part where you live(it's not that curvy here either,as far as keeping my tyre round). Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 17, 2011 Author Member Contributer Share Posted February 17, 2011 That's sound advice, John. I have a good bicycle pump and will check the pressure regularly. I have not developed edges, if I understand what you are saying. I'm assuming you mean running on the flat land so much the tires wear only where the rubber has hit the road, i.e. not on the sides at all; so they get squared off. I've been looking for that but it hasn't happened yet. We actually seek out the curves and there are an abundance of them in our area; although the weather has kept us at relatively lower elevations. Last week I rode from Reno to through Virginia City on state route 341 to Carson City and back on Friday and again on Saturday. Check that on Google Earth or the like. Took a left coming out of V.C. to stay on old 341 in order to travel a more curvy canyon before rejoining SR 342 to Hiway 50. It is grin inducing fun. I'll bet you'd enjoy it (even though there were a shitpile of Harley's in V.C., some wave back, some don't) !. That has been where I've gotten my feedback on the handling recently. Thanks for your help. Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted February 17, 2011 Member Contributer Share Posted February 17, 2011 Clearly the front forks must be adjusted in balance with the rear. I’m not sure how to adjust the forks’ preload (anybody?) I believe it is the small screw head in the top center of each fork. This is correct. Link to comment Share on other sites More sharing options...
Baileyrock Posted February 17, 2011 Share Posted February 17, 2011 Tires are original stock. I can't remember which brand; but they had about 1900 miles on them when I got the bike a few months ago. Tire pressure was initially an issue but I corrected Ironically, today my wife emailed me to tell me my set of Michelin Pilot Road 2's were delivered at home. I'm planning to save them until I get more wear on the current tires. I can just about guarantee that just slapping on those Road 2's will easily double your confidence with the bike in the turns over any OEM tire that comes on a VFR and that's w/o touching anything else on the bike.! :fing02: I say Don't Save them, Mount them!!!! :goofy: It could save you lots of time and money until you have the boot to buy some good pieces! :fing02: BR Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 17, 2011 Author Member Contributer Share Posted February 17, 2011 Can anyone give me a quick answer about how to adjust the preload on the forks? Thanks. Link to comment Share on other sites More sharing options...
Member Contributer FHR Posted February 17, 2011 Author Member Contributer Share Posted February 17, 2011 I can just about guarantee that just slapping on those Road 2's will easily double your confidence with the bike in the turns over any OEM tire that comes on a VFR and that's w/o touching anything else on the bike.! :fing02: I say Don't Save them, Mount them!!!! :goofy: It could save you lots of time and money until you have the boot to buy some good pieces! :fing02: BR Forgive my ignorance but should I add those balancing beads when I put on the new tires? Do they work? Remember, "ignorance" is curable; it is merely the absence of information. "Stupid" on the other hand. . . Well, I think comedian, Ron White, said, "you can't fix stupid." So I'm hoping I'm only ignorant. Link to comment Share on other sites More sharing options...
Baileyrock Posted February 17, 2011 Share Posted February 17, 2011 Can anyone give me a quick answer about how to adjust the preload on the forks? Thanks. If you haven't yet download the Factory Shop Manual here: http://www.vfrdiscussion.com/forum/index.php/files/file/9-vtec-service-manual/ Fork preload is as simple as a screw driver turning of the only adjustment on the top of the fork tube, clockwise being tighter. :fing02: Link to comment Share on other sites More sharing options...
VFR4Lee Posted February 17, 2011 Share Posted February 17, 2011 The tires are 5 years old and have about 4,000 miles or so. Apparently it hasn't been ridden too hard or I'd expect at least the rear to be completely toasted. Even if they're not quite dead, I bet swapping them out will make a noticeable (and good) difference. :fing02: Link to comment Share on other sites More sharing options...
Monk Posted February 17, 2011 Share Posted February 17, 2011 Can anyone give me a quick answer about how to adjust the preload on the forks? Thanks. If you haven't yet download the Factory Shop Manual here: http://www.vfrdiscussion.com/forum/index.php/files/file/9-vtec-service-manual/ Fork preload is as simple as a screw driver turning of the only adjustment on the top of the fork tube, clockwise being tighter. :fing02: And use a screwdriver that fits the slot(the metal is soft). Link to comment Share on other sites More sharing options...
Member Contributer SAFE-T Posted February 17, 2011 Member Contributer Share Posted February 17, 2011 The VFR800A has the remote preload adjuster. You would lose that going to the CBR929 shock. Since you are on a bit of a budget, and maybe not experienced enough to deal with multiple-adjustability on your bike anyway, I would look at a heavier rear spring out back and heavier fork springs up front to start. Link to comment Share on other sites More sharing options...
Chaz06i Posted February 17, 2011 Share Posted February 17, 2011 I would definalty talk the 3 Boys listed above. They know there stuff. I took there advice and many others, (same readings as you) and had my suspension re-done. I only did step 1 & 2 in my 3 step process. I put in new springs in front (step 1, $100) for my weight and then went to step 2. Step 2 was to have Jaime re-build and revalve a CBR600 F4I Shock. Shock I got off ebay for $35 and Jaime was $300. Step 3 will be to get CBR600 F4I fork intenals and then have Jaime re-built and re-valve them. I think that I could have all that done for less than an Elka 3-way rear shock. This of course is just the route I am choosing to run. Good luck with what ever you choose. :fing02: Chaz, Thanks for your comments. when you have completed your project would you tell us about how the modifications affected the feel and handling of your bike? BTW I picked mine (also a 2006) up from a seller a little north of you in Anacortes, WA. FHR, I can tell you now, as most will, that doing the rear shock and replacing the front springs is a good way to start. I have noticed a huge improvement so far with just the 2 items done. I have set my sag to 32f/30r without gear. The bike turns in quicker and feels more confident in the turns. It doesn't seeem to me like the bike wants to wash out as bad. Front end feels more planted and the rear stick like glue. Of course, I know the handling could feel better with a set of pilot powers. However, tire life is important and I decided to try a new set of Pirelli Angels. So, I sacrifice a little grip in that regard. The next tire I will run is the PRoad 2 and see how those change things. :biggrin: Link to comment Share on other sites More sharing options...
y2kRC46 Posted February 17, 2011 Share Posted February 17, 2011 Welcome and nice VFR. When you do adjust the front fork spring preload I would suggest making those adjustments on the center stand, it will keep the damage to the adjuster to a low as they will be somewhat unloaded. good luck! Link to comment Share on other sites More sharing options...
