Member Contributer Synaptic Misfire Posted September 16, 2010 Member Contributer Share Posted September 16, 2010 Title says it all. Thanks in advance! Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted September 16, 2010 Member Contributer Share Posted September 16, 2010 I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted September 16, 2010 Member Contributer Share Posted September 16, 2010 I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. on this one...it works! Get mounts at GPScity.com, they have good photos and lots of selection, seems like prices are good too. Get new longer SSteel hex key bolts at local hardware store. Link to comment Share on other sites More sharing options...
Member Contributer Synaptic Misfire Posted September 16, 2010 Author Member Contributer Share Posted September 16, 2010 Thanks guys I will check that one out. Link to comment Share on other sites More sharing options...
ictghost Posted September 16, 2010 Share Posted September 16, 2010 I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. on this one...it works! Get mounts at GPScity.com, they have good photos and lots of selection, seems like prices are good too. Get new longer SSteel hex key bolts at local hardware store. I also use this one and it's great. Here is a pic of the GPS mount installed on it: Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted September 16, 2010 Member Contributer Share Posted September 16, 2010 I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. on this one...it works! Get mounts at GPScity.com, they have good photos and lots of selection, seems like prices are good too. Get new longer SSteel hex key bolts at local hardware store. I also use this one and it's great. Here is a pic of the GPS mount installed on it: What is that BS "Warning" sticker on your beautiful tank? I have a 2004 and haven't seen that... Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2010 Share Posted September 17, 2010 I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. I did the exact same thing. Works like a charm. Link to comment Share on other sites More sharing options...
choco Posted September 17, 2010 Share Posted September 17, 2010 Been looking at this setup too. Christmas present from my wife, better send her the links. :goofy: Link to comment Share on other sites More sharing options...
DDO-VFR Posted September 17, 2010 Share Posted September 17, 2010 I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. I did the exact same thing. Works like a charm. Same set up here. Great thing about it is that it doesn't move with your steering. I found that the center-center dimension was a tad smaller than the tank bolts, so don't be surprised if you have to file a little get the screws to line up. I actually went to the shortest arm, in order to reduce the leverage (and subsequent motion range) of the GPS unit during bumps. I live in Quebec, bumps is all I have! Brian Link to comment Share on other sites More sharing options...
Member Contributer PLCGuy Posted September 17, 2010 Member Contributer Share Posted September 17, 2010 I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. Ditto to everything. Link to comment Share on other sites More sharing options...
Member Contributer talldrinkofwater Posted September 17, 2010 Member Contributer Share Posted September 17, 2010 Here is the link for RAM mount that bolts on top of the two gas tank bolts. http://www.gpscity.com/ram-mount-steel-u-bolt-motorcycle-mount-base-ram-b-231u.html Link to comment Share on other sites More sharing options...
Member Contributer Conedodger Posted September 17, 2010 Member Contributer Share Posted September 17, 2010 What is that BS "Warning" sticker on your beautiful tank? I have a 2004 and haven't seen that... My '04 had the same stickers. I took them off the day I bought the bike. Link to comment Share on other sites More sharing options...
Member Contributer Conedodger Posted September 17, 2010 Member Contributer Share Posted September 17, 2010 I tried the tank mount, but switched to the stem mount. I can't get the right position for the GPS when I use my tank bag and the tank mount. I did have to modify the stem mount to make it fit tighter. I threw away the rubber plug that came in the kit and replaced it with a different one from the plumbing department at Lowes. Link to comment Share on other sites More sharing options...
Member Contributer VFRbeliever Posted September 17, 2010 Member Contributer Share Posted September 17, 2010 I bought the center stem mount, and like everyone else, can't get it completely tight. But i live with it that way. It's never become so loose that the GPS has fallen off or anything. I just make sure to hand tighten it again after a few hours of riding. If I every buy another one, it will definitely be the tank bolt mount. Link to comment Share on other sites More sharing options...
ictghost Posted September 17, 2010 Share Posted September 17, 2010 What is that BS "Warning" sticker on your beautiful tank? I have a 2004 and haven't seen that... My '04 had the same stickers. I took them off the day I bought the bike. Never really thought about it...maybe I do need to take them off. Link to comment Share on other sites More sharing options...
Member Contributer doubled Posted September 23, 2010 Member Contributer Share Posted September 23, 2010 I bought the center stem mount, and like everyone else, can't get it completely tight. But i live with it that way. It's never become so loose that the GPS has fallen off or anything. I just make sure to hand tighten it again after a few hours of riding. If I every buy another one, it will definitely be the tank bolt mount. Like you and many others I had the same problem. Instead of using the rubber stopper that came with the kit, I used a rubber cork that comes with some bottled wines. The diameter is almost perfect for the stem. I cut the rubber cork to size, drilled a hole through the middle (be careful to keep a straight line as you drill through it) and followed the directions that came with the mount. Worked pretty well and it's tight. FWIW Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted September 23, 2010 Member Contributer Share Posted September 23, 2010 What is that BS "Warning" sticker on your beautiful tank? I have a 2004 and haven't seen that... My '04 had the same stickers. I took them off the day I bought the bike. Never really thought about it...maybe I do need to take them off. Not saying you should or shouldn't, I just haven't seen those stickers before and thought maybe it was a Canadian bike or something. I bought my 04 second hand so didn't know it came with stickers on the tank. Love the color of your bike btw... Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted September 23, 2010 Member Contributer Share Posted September 23, 2010 I bought the center stem mount, and like everyone else, can't get it completely tight. But i live with it that way. It's never become so loose that the GPS has fallen off or anything. I just make sure to hand tighten it again after a few hours of riding. If I every buy another one, it will definitely be the tank bolt mount. I've had a stem mount rubber plug on my '99 and it worked great. Never loose at all. Perhaps my GPS was light enough not to be a problem? In any case, I believe there is a mount that runs a bolt through the stem to mount it more solidly than a plug. If not sold that way, it's certainly an easy mod! I like the tank bolt mount, too. Link to comment Share on other sites More sharing options...
Guest Posted December 13, 2010 Share Posted December 13, 2010 I would like to mount my Escort 8500 radar detector to my 2007 Interceptor. Can anyone tell me what parts that I need? I've seen the link to the ball that could be mounted to the tank bolts (with longer bolts) and that looks pretty good. But I don't know what type of arms or length to use or what type of plate to mount on top of the arm. I'm experiencing option paralysis for all that I see on the RAM mounts website. Help a new guy? Thank. Title says it all. Thanks in advance! Link to comment Share on other sites More sharing options...
Member Contributer MuddDawg Posted December 13, 2010 Member Contributer Share Posted December 13, 2010 I have been using this set up for a few years and works great. I have a screen mount for my Radar which is great in the summer when I know its not going to rain. http://www.legalspeeding.com/AWM.htm Wanting to do a different mount, but I like being able to see it without looking down while riding. On day I will figure out a better way. Link to comment Share on other sites More sharing options...
timmythecop Posted December 13, 2010 Share Posted December 13, 2010 the clutch/brake perch mount will work there as well (at least on 5th gens) Link to comment Share on other sites More sharing options...
Member Contributer MuddDawg Posted December 13, 2010 Member Contributer Share Posted December 13, 2010 the clutch/brake perch mount will work there as well (at least on 5th gens) Are talking the magnetic mount or the mount and a arm? Link to comment Share on other sites More sharing options...
Guest Posted April 12, 2011 Share Posted April 12, 2011 I've just got my VFR. As I will be putting in a powerlet outlet in the steering head, this looks like the best option for me. What tank bolts do I need? Can the be obtined from a Honda dealer or else where? (particularly for us retail challenged Canadians). I tried the one that fits in the steering stem and has the rubber expansion plugs but I never could keep it tight so I bought this one that mounts in front of the tank. You just need to get longer tank bolts. The medium length arm was just a little short for me so I switched to the longer arm on my 6th gen.. Link to comment Share on other sites More sharing options...
Member Contributer Gerrys02800 Posted April 12, 2011 Member Contributer Share Posted April 12, 2011 Man, I just replaced mine a while ago when I installed the mount on my bike, but I am not near the bike to check. I know the bolt is a M6 and stock length is 30. I went to Can Tire and bought a M6x35 and M6x40 just in case. edit: I went and checked and its the M6X40 Link to comment Share on other sites More sharing options...
Guest Posted April 12, 2011 Share Posted April 12, 2011 Thanks, I grabbed 2 M6x40 from Home Depot...not sure I like the "look" of the, but they will do until I find some "pretty" bolts ;-). I got the desired RAM mount (RAM 231) from Radio World (North of Toronto), not the cheapest place, but I could physically go there real quick and satisfy my "farkle shopping urge". Man, I just replaced mine a while ago when I installed the mount on my bike, but I am not near the bike to check. I know the bolt is a M6 and stock length is 30. I went to Can Tire and bought a M6x35 and M6x40 just in case. edit: I went and checked and its the M6X40 Link to comment Share on other sites More sharing options...
