Member Contributer Knife Posted June 7, 2010 Member Contributer Share Posted June 7, 2010 I go for a nice two-up ride this morning, and on the way back home notice my voltmeter is showing less than 12v at speed. I get home, take the rear fairing off, and this is what I find. Can't believe the bike still starts! I have a newish R/R and a VFRness (maybe 7,500 miles on both). I have to get this fixed; I have a trip planned for two weeks from now. I'll search for the topic here, but if anyone can point me to the right/best one, I'd appreciate it. Thanks! Link to comment Share on other sites More sharing options...
spud786 Posted June 7, 2010 Share Posted June 7, 2010 :mad: You gave me a Woody! Your Volt meter paid off and alerted ya to trouble, or else you'd have been on that trip and found out Link to comment Share on other sites More sharing options...
Member Contributer kaldek Posted June 7, 2010 Member Contributer Share Posted June 7, 2010 Hmmm. You have a new R/R and a VFRness, and still your connectors have melted! At this point, it's easy to become stumped. I'm thinking a good approach will be a MOSFET regulator - the FH012AA from a 2007 or later R1 for example. Follow this up with ensuring all ground connections are good and testing your stator output. This problem is becoming ridiculously common lately. :-/ Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted June 7, 2010 Member Contributer Share Posted June 7, 2010 Cut the bad wires out and splice new ones in. Mine wasn't quite that bad but close about 6 months ago, it's been fine since I patched in new. Link to comment Share on other sites More sharing options...
Member Contributer VFR Capt.Bob Posted June 7, 2010 Member Contributer Share Posted June 7, 2010 Agreed. Crimp connectors with Noalox anti oxidant as a lubricant for the wires and liquid electrical tape to seal the connections. Moisture and corrosion are the main culprits of this burning up connectors. Mine looks similar to above. I've never seen a case of burnt connectors as bad as yours. The set up above works great for me. Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2010 Share Posted June 7, 2010 Knife, Which R/R was in place? Upgraded Honda OEM? Jon Link to comment Share on other sites More sharing options...
Tightwad Posted June 7, 2010 Share Posted June 7, 2010 The R/R he has is the original style Ricks unit, not the MOSFET style. I haven't seen any burned connections with the MOSFET style yet....but then they are fairly new (barring R1 conversions). The real question is...do the connections burn because they are the problem, or is there a problem elsewhere and they are the weakspot...rather like having a fuse blow and trying to fix it with a bigger fuse...sure it might not blow but did you just move the problem to a more expensive part? I would love to know the answer to this oft asked question! Link to comment Share on other sites More sharing options...
VFR4Lee Posted June 8, 2010 Share Posted June 8, 2010 That's AFU'ed for sure. Lucky you got home with that. :blush: Link to comment Share on other sites More sharing options...
