Nelso90 Posted June 25, 2015 Share Posted June 25, 2015 (edited) Hey guys, guess 40k miles is time for me to get on the electrical gremlin bandwagon here with my 2002 non ABS. The issues began about a month ago, at work. Key on, hit starter, and she was dead. I tried to jump start the bike, but the second I removed the auxiliary battery, it died. Went to Interstate (In a 52hp Diesel Jetta) to get another battery, installed it, ran great. I figured the battery was sulfated and it had an internal short. Fast forward another month and it did the exact same thing. I knew about the R/R and stator issues, so I figured I would tear her down and see what was up. Lo and behold...whoa So the R/R to stator connection was bad. I assume this means the R/R is bad also. I ohmed the stator out per sec. 17 of the shop manual, and everything was within spec. All I have read on the R/R is that I cannot test it at home. I figure it's bad though since the connector was fried. Really fried. I checked voltage through the battery negative as I did in the first place to determine if there was still a current drain and there was, I calculated it to approximately 0.4 amps, more than enough to kill a battery in a night. This being the case I made my way through the wiring diagram, looking over all the fuses, and I ran across a couple of items. The first was the red connector over the green starter relay. It was melted on the terminal that takes the RED wire. I pulled the fuse (30 amp, main fuse A), which caused the current draw from the battery to stop. I also noticed the holder for main fuse A was slightly discolored, but I do not view it as a contributing issue yet. Disconnecting that fuse did nothing to my current draw. Once I isolated the current draw to that circuit, I followed the red wire to the keyswitch, which tested good per sec. 20-21 of the manual. I then followed the red/green wire to the instrument panel and unplugged that 20 pin connector, which stopped the current draw. To summarize, This bike keeps killing batteries I found a totally destroyed R/R to stator connection Stator ohmed out OK Battery still is being drained whilst R/R is NOT connected (0.43A @ 12.7V battery voltage) 30 amp Fuse A connector is melted at green connector (red wire) 30 amp Fuse B connector is beginning to discolor. Current draw ceases once Fuse A is pulled Current draw ceases if instrument panel (20 pin) plug is disconnected (no discoloration on this connector) I am pretty stumped as to why this is happening as it seems nobody mentions instrument panel, nor the fuse on the starter solenoid. Any suggestions on what I should test/replace? I figure I am in it for a new Rectifier and fuse holder, but I fear it could be more. Edited June 25, 2015 by Nelso90 1 Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 25, 2015 Member Contributer Share Posted June 25, 2015 Here's what you need. http://www.wiremybike.com/ Roll On . 1 Quote Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted June 25, 2015 Member Contributer Share Posted June 25, 2015 And a tube of this . . . Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 25, 2015 Member Contributer Share Posted June 25, 2015 Some of theses also. Quote Link to comment Share on other sites More sharing options...
Nelso90 Posted June 25, 2015 Share Posted June 25, 2015 Thanks for the fast responses guys. I will get a standard VFRNess on order today. Should I go ahead and replace my rectifier? The current draw from the battery at key off is worrisome, but as long as the VFRness fixes it, we should be good. Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 26, 2015 Member Contributer Share Posted June 26, 2015 Thanks for the fast responses guys. I will get a standard VFRNess on order today. Should I go ahead and replace my rectifier? The current draw from the battery at key off is worrisome, but as long as the VFRness fixes it, we should be good. I would just for the piece of mind . Roll On .. Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted July 13, 2015 Share Posted July 13, 2015 I have to do for sure the 30 amp mods , i would like to do the blue harness connector mod too , but my harness is different from yours. (see the pics) !! no ground on the fwd side of the blue connector !! problems encounted : engine die while running the highway, my dashboard was like a christmas tree, i don't know for the headlight lamp it happens during the day. What solution or mods should I do? thank you in advance guys Quote Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted July 13, 2015 Member Contributer Share Posted July 13, 2015 Has the wiring harness recall been done? Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted July 13, 2015 Share Posted July 13, 2015 yes ,I just call honda this morning, they said they can't see my vin number , so they think its done Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 13, 2015 Member Contributer Share Posted July 13, 2015 Should be a mark on the VIN plate if recall was completed . Install the VFRness harness . Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted July 14, 2015 Share Posted July 14, 2015 do you talk about the sticker on the left side of the frame . what should I look for? Quote Link to comment Share on other sites More sharing options...
Member Contributer rhoderage Posted July 14, 2015 Member Contributer Share Posted July 14, 2015 Should be a punch mark on the VIN sticker on the left side of the frame. Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 14, 2015 Member Contributer Share Posted July 14, 2015 Should be a mark on the VIN plate if recall was completed . Install the VFRness harness . Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted July 14, 2015 Share Posted July 14, 2015 sorry switchblade , It was too late last night when i took my messages. i was reading your answer without realizing that was the answer Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted July 14, 2015 Share Posted July 14, 2015 i didn't saw the answer last ,,,,, too tired,,, Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted July 14, 2015 Share Posted July 14, 2015 I have tested my system this morning, I have checked : reg/rec---ok stator continuity---ok stator voltage at idle----ok (almost all the same) charging circuit--- connecting the black lead from multimeter to positive battery and red lead from multimeter to red wire coming out from reg/rec this should give 0.2 volt from the fault finding chart of electrosport. and i got 0.8 volt. the chart said more than 0.2 is : "Bad connection in the positive lead from RR to battery(+) then I touch the 30 amp holder (who is the positive wire), ouch omg that was hot so I ordered a vfrness from wiremybike. 2 to 5 days to canada. give you some news when its done Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 14, 2015 Member Contributer Share Posted July 14, 2015 Should be a mark on the VIN plate if recall was completed . Install the VFRness harness . Every time . Quote Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted July 15, 2015 Member Contributer Share Posted July 15, 2015 Get a tube of Oxgard while you're at it and treat all the connectors and grounds. It keeps 'em happy. Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted July 15, 2015 Share Posted July 15, 2015 I checked on my vin plate, theres nothing punched thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted August 3, 2015 Share Posted August 3, 2015 finally I have installed my harness BUT I don't know which connectors to use. could someone can help me with that? see my pic. which one goes with the "A" ? which one goes with the "B" ? Is it possible that I have 2 extra connectors left ? Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 3, 2015 Member Contributer Share Posted August 3, 2015 A2 and B1 they only connect one way . What you are connecting is a split of the R\R output plug. The VFRness splits the output voltage of the R\R. Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted August 4, 2015 Share Posted August 4, 2015 thank you , now I can ffinish my installation. one more thing.... in the instruction , in testing section , line 5. " retest the voltage at the accessory wire....." is this line is only for people who took the option with the vfrness.? at idle i should have 13.5 to 14.5 i have 14.2 thats good. but when I rev the bike at 5k. I still have 14.2 , the instruction says 14.3 to 14.7volts do you think my bike is ok now? Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 4, 2015 Member Contributer Share Posted August 4, 2015 thank you , now I can ffinish my installation. one more thing.... in the instruction , in testing section , line 5. " retest the voltage at the accessory wire....." is this line is only for people who took the option with the vfrness.? at idle i should have 13.5 to 14.5 i have 14.2 thats good. but when I rev the bike at 5k. I still have 14.2 , the instruction says 14.3 to 14.7volts do you think my bike is ok now? Your are good to go ! 1 Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted August 4, 2015 Share Posted August 4, 2015 thanks a lot Quote Link to comment Share on other sites More sharing options...
Matrixxcat19 Posted August 20, 2015 Share Posted August 20, 2015 I have a new problem now , I have done the vfrness mod , everythings seems to be good . I took my bike to go to work in a hot hot day!!! 38 degre C while a was riding my clock reset to 1:00am all by itself. then after a few kilometers the motor stops ,so I pull the clutch and release it to start the bike . i did it 3 times before it starts ( was riding around 90 km/h). another thing!!! my fuel tank has a fuel level problem it says its always empty or almost empty even after a refill. do you think that this problem can cause my motor to stop ( computer wise ) Quote Link to comment Share on other sites More sharing options...
