Forum CEO HispanicSlammer Posted October 16, 2002 Forum CEO Posted October 16, 2002 Procedure for Fuel Injected VFR models VTEC follows below on a reply post To diagnose a fuel injection problem on a 5th generation vfr with the ECM self diagnosis feature, Begin by removing the seat, locate the ?service check connector? and you will have to find a ?jumper wire? not provided. 1. With the ignition key to off and the engine stop switch on RUN 2. Short the ?Service Check Connector? 3. Turn the ignition key to on, do not start the bike though 4. If the ?FI? lights up and stays on with the ignition key on then there is no memory data 5. If the ?FI? BLINKS then there is data! Long blink = 10 short blinks VIDEO here is a short video on the procedure look for the blue connector on the left hand side of the rear subframe zoomed out I am indicating it with my finger my FI light blinked 12 times, number 1 injector, I found the connector was loose, I pulled it apart cleaned it and reconnected, fixed! VTEC PROCEDURE essentially the procedure is the same however the connector you need to short is up front on the right side near the fuse box. Quote
Member Contributer kaldek Posted July 6, 2011 Member Contributer Posted July 6, 2011 Hey folks, I made a video on reading the FI error codes on a VTEC. Quote
dogman Posted July 7, 2011 Posted July 7, 2011 Very good Kal. I must get around to clearing mine as I have done several starter synchs and not checked. Quote
Member Contributer Ryanme17 Posted July 7, 2011 Member Contributer Posted July 7, 2011 Thanks guys, this is great! P.S. Either you need to set your bike clock, Kaldek, or you make VFR videos WAY too early in the morning! :) Quote
Member Contributer kaldek Posted July 7, 2011 Member Contributer Posted July 7, 2011 Thanks guys, this is great! P.S. Either you need to set your bike clock, Kaldek, or you make VFR videos WAY too early in the morning! :) Heh true - clock needs to be set. I was more worried you'd say "185KM and less than half a tank???!" Quote
?art West-VL. Posted June 18, 2012 Posted June 18, 2012 Hey guys, Not experienced with working on my bike but want to try before going to the dealer. My light gave two long and three short blinks, I think 'code 23' Can I just reset the memory or should I search for the problem immediately? This started after riding for 6 hours in the rain... The bike has 42000km. Quote
?art West-VL. Posted June 18, 2012 Posted June 18, 2012 Update: Sometimes when I start the bike, the light doesn't come on, mostly it does. Also, when I'm engine braking, I hear some ticking noise. I'm pretty sure the valve for the coolant is stuck open too, temperature doesn't rise fast. Thoughts anyone? Quote
Member Contributer ecn Posted June 25, 2012 Member Contributer Posted June 25, 2012 (edited) My 98 still ran well, but the FI light intermittently goes on (9 blinks, IAT). It used to stay off for days at a time but started to go on more often. I replaced the sensor without effect. I flushed out the sensor contacts with solvent and a toothpick and it was a tiny bit better. I next tried some electrical contact cleaner and lubricant from home depot. I completely flushed the sensor plug with the spray and then let the lube dry for a few hours and the problem seemed to diminish about 75%. Figuring it might be a problem on the other end of the sensor wire, I pulled the 2 plugs from the computer and used the contact cleaner on all of those pins and blew it out with compressed air. So far after 2 days and 200 miles of testing I have no error lights. Edited July 16, 2012 by ecn Quote
?art West-VL. Posted June 25, 2012 Posted June 25, 2012 My light doesn't come on all the time, I suspect it could be a bad connection because I ride in the rain a lot. If I find the time, I would like to check all connectors, this could solve a lot of things with a lot of bikes I guess. 1 Quote
samboss260 Posted February 9, 2015 Posted February 9, 2015 Reviving an old thread..... 98 5th Gen VFR800. Bike is charging correctly (have Voltmeter installed) and bike starts and rides fine. On a ride about a month ago, the FI light came on about 20 minutes into the ride and stayed on. We stopped for coffee after about 45 minutes and when I started the bike no FI light came on the entire way home, so I thought nothing of it. Then yesterday, went for a ride. Went for about an hour and stopped for coffee, no issues. After we left from coffee, about 5 minutes into it the light came on and remained on for the hour ride home. Got home, turned bike off and started again, no light came on. Will do the Read Error codes this week, but any ideas? Like I said, bike starts and rides fine. Quote
RobertDe Posted July 4, 2015 Posted July 4, 2015 Hi. Could you help mi to interpretate this? Is it one blink or more? I'm really confused. The engine runs unevenly at constant revolutions 3000-4000 RPM . Gently accelerates or slows down. Where to find the cause? Is it one blink and means MAP sensor problem? Robert Quote
Member Contributer Switchblade Posted July 4, 2015 Member Contributer Posted July 4, 2015 I think you need to the let the sequence complete . Video does not show the complete cycle. Roll On .. Quote
RobertDe Posted July 4, 2015 Posted July 4, 2015 OK thanks. Tell me please how do we know that the sequence is over ? Robert Quote
Member Contributer Switchblade Posted July 4, 2015 Member Contributer Posted July 4, 2015 It should stop , now on yours you have to put a jumper in . Check the video's. Roll On .. Quote
RobertDe Posted July 6, 2015 Posted July 6, 2015 OK it's MAP sensor problem. Can this affect at rough running an engine? Quote
Member Contributer Switchblade Posted July 6, 2015 Member Contributer Posted July 6, 2015 OK it's MAP sensor problem. Can this affect at rough running an engine? Yeah Fleebay is your friend . Roll On .. Quote
Member Contributer Terry Posted July 7, 2015 Member Contributer Posted July 7, 2015 A MAP sensor problem could be just a bad/loose connector or damaged wire. The MAP sensor on the 5th gen is on the back of the airbox, before launching into parts replacement I'd suggest you just try unplugging and reconnecting the wire. The service manual shows a procedure for diagnosing whether the sensor is faulty. When the FI system detects a fault in a sensor like this, it defaults into a "limp home" mode that ignores the sensor. That will mean that the FI system won't be running at its optimum setting, so might run rich and make less power than usual. The MAP sensor is detecting the air pressure/vacuum in the intake system, so I would think when this malfunctions there would be significant effects. 1 Quote
RobertDe Posted July 7, 2015 Posted July 7, 2015 Thanks. I have read service manual there and back and I know almost everything about MAP sensor ;) I'll replace it for test from my friend's bike. I've reconetted it with no effect. Tell me please if repleacing r/r may affect rough running an engine? I've bought r/r with 7 wires whereas my bike has 8 bundle and this 8th wire isn't now connected. Charging battery is OK. 14,2V. I hope you can understand me. My English isn't impressive :) Quote
Member Contributer Switchblade Posted July 7, 2015 Member Contributer Posted July 7, 2015 Un hook it and see if you can tell any change or if it remains the same . Good troubleshooting ! Roll On .. Quote
Member Contributer Terry Posted July 7, 2015 Member Contributer Posted July 7, 2015 Have you checked continuity in the wires to the ECU? Sent from my iPhone using Tapatalk Quote
RobertDe Posted July 8, 2015 Posted July 8, 2015 Terry yes I have checked. It is OK. It has 4,8V in plugin checking with service manual. Tell me please if ECU find problem with e.g. MAP sensor it ignores it at all and waiting for reset procedure or testing it at every engine start and only records error in Memory? Quote
Moose Posted July 29, 2015 Posted July 29, 2015 Sorry to butt in but I also have 2 long and 3 short blinks, is this 10 10 and 3, 10 and 13 or 23? please help Quote
Searmonkey2k18 Posted June 21, 2020 Posted June 21, 2020 I have an 02 cbr600f4i. It blinks "F1" 6 times. And the blinks are long blinks. Any ideas? Quote
Member Contributer Terry Posted June 21, 2020 Member Contributer Posted June 21, 2020 20 minutes ago, Searmonkey2k18 said: I have an 02 cbr600f4i. It blinks "F1" 6 times. And the blinks are long blinks. Any ideas? I've got the manual for that and there is no code for 6 blinks (nothing for 3, 4 5 or 6). A long blink (1.3 seconds) is equal to a value of 10, and if there is more than one fault then it blinks for the lowest number fault first, then second etc. My guess is you have more than one fault. You could clear the fault register and run the bike and see what new fault occurs. If you started the bike with any sensor disconnected during maintenance then it will record that as a fault. I can give you a link to the manual if you don't have it. 1 Quote
Frankly40 Posted October 23, 2021 Posted October 23, 2021 This is excellent resource on F1 bit is for VTEC models. Does anyone knows where I can find similar information on Honda vfr800 1999? Many thanks Frank Ferich Quote
