Member Contributer roadrunner Posted June 24, 2015 Member Contributer Share Posted June 24, 2015 Is the 8th Gen engine basically the same as the 6th gen? Reason I'm asking is I'm curious if they upgraded parts like the stator and rr and if those parts can be put on a 6th gen. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted June 24, 2015 Share Posted June 24, 2015 Yes the engine is basically the same. I have no idea if the charging system has been changed. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 25, 2015 Member Contributer Share Posted June 25, 2015 R\R is different for sure , the last thing I read about it was a computer control unit. Roll On .. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted June 25, 2015 Member Contributer Share Posted June 25, 2015 The stator has a different part number and the cover is visually different, tho that doesn't mean they won't fit. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted June 25, 2015 Member Contributer Share Posted June 25, 2015 How about the crank and crankcase? If those are the same, then it should all bolt up? Flywheel? If the R/R is in a different spot, and the power output wires are a different length, that would make it a new part# for sure. Maybe even a new R/R with a different plug. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted June 25, 2015 Member Contributer Share Posted June 25, 2015 Why doesn't someone look up the parts fiches and compare part numbers. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted June 26, 2015 Member Contributer Share Posted June 26, 2015 Part numbers generally only tell you if the bikes use the exact same parts; whether different parts nevertheless fit is a question that can only be answered by educated guessing, trial and error. IOW, somebody's got to step up and order some parts! (Speaking of which, whatever happened to the guy who was trying to fit an 8th-gen wheel and axle to an earlier model? I think he worked at a dealership, so could easily get the parts.) Ciao, Link to comment Share on other sites More sharing options...
