Suitcase Posted September 26, 2013 Share Posted September 26, 2013 Around 2500 kms ago I replaced the worn out Bstone Batlxs with Mich PR2s front and rear. Today while riding up 95 from.home to Golden I noticed a pulsing vibration at +/- 6k rpm in 6th gear. Felt it in the grips and saw it shake the mirrors. Pulse of the vibe lasted about one second while I maintained throttle. At lower rpm/speed it was just beinning to be noticeable at 5700+/-rpm Never encountered this before with old skins or with new..that is up until tdays ride. I think.I found the source..but just tossing this one out to make you think....it sure made me wonder while buzzing along. Whatcha all thinking is cause.?? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 27, 2013 Member Contributer Share Posted September 27, 2013 Loose wheel weights's ? Link to comment Share on other sites More sharing options...
VFR4Lee Posted September 27, 2013 Share Posted September 27, 2013 Wheel(s) not balanced? Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted September 27, 2013 Member Contributer Share Posted September 27, 2013 The front tire I just had mounted and balanced had a (unknown to me) a loose weight. When I washed the rim just before leaving for Hog Tie my rag moved the weight. I do not know where it was originally so I put it in the middle between the spokes but had some high speed vibration throughout the trip. I called the dealer to suggest they get a better "clamper" tool to use to postition the weights. Link to comment Share on other sites More sharing options...
Suitcase Posted September 27, 2013 Author Share Posted September 27, 2013 Surenuff...when I got to Golden and started looking the bike over in the McDs parking lot. ..I saw that 1 of 2 weighs on the front rim was gone. Crimped on weights were not my choice..but both new tires were balanced with them. Well...happy that it was an easy diagnosis...and respectfull of the wisdom of the folks on the forums at VFRD. Link to comment Share on other sites More sharing options...
Suitcase Posted October 26, 2013 Author Share Posted October 26, 2013 WTF....after replacing the missing weight. ..and testing. ..the vibe/pulse is still present. So back to the think tank Amigos. Ideas are welcome! !! Link to comment Share on other sites More sharing options...
Baileyrock Posted October 26, 2013 Share Posted October 26, 2013 Did you rebalanced or just reinstall the weight? Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted October 26, 2013 Member Contributer Share Posted October 26, 2013 Lift the front end and check for loose/worn bearings in both the wheel/axle and steering head. Regardless of how she use to run, there's obviously something not right now, so make sure it's not either of these two, then re-balance the wheel. Link to comment Share on other sites More sharing options...
