timmythecop Posted August 14, 2013 Share Posted August 14, 2013 You stopping at Chez Willie? I did. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 15, 2013 Author Member Contributer Share Posted August 15, 2013 BUMP on my question ^ How wide is your azz? 6th gen with cases? Any other year with say GIVI? At the absolote widest point, mine is some 105cm Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 16, 2013 Author Member Contributer Share Posted August 16, 2013 Loaded the bags up and rode down to Luxemburg today. Solid as a rock :-) And not a single weave, all the way up to 215KMH Without panniersI get up to 235KMH (on GPS), drag and wind resistance the price to pay for creature comforts..... Would anyone know the partnumbers for the OEM pannier bags from Honda? Link to comment Share on other sites More sharing options...
V4 Rosso Posted August 16, 2013 Share Posted August 16, 2013 Check http://www.honda-access.com for part numbers. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 17, 2013 Author Member Contributer Share Posted August 17, 2013 Cheers Jeroen, found them. Eur 78 at cmsnl. ouch...... Link to comment Share on other sites More sharing options...
Member Contributer rdguy Posted August 17, 2013 Member Contributer Share Posted August 17, 2013 BUMP on my question ^ How wide is your azz? 6th gen with cases? Any other year with say GIVI? At the absolote widest point, mine is some 105cm 6th gen with Givi's = 40.46 Amsterdamse duim. HTH, Glenn Link to comment Share on other sites More sharing options...
Auspanglish Posted August 17, 2013 Share Posted August 17, 2013 Cheers guys! I considered moving them forward as much as possible. Limiting factor is my seat lock/ latch. I now have just enugh clearance for the key. Ideally I would use a set of 6th gen passenger pegs. They have the mounting point/lug high up. But they are kinda pricy. And I would need to do the "Beck" mod for the seat latch.... I already have a small bicycle brake lever in the shed ;-) So I will give the bags a test next weekend. Riding to Luxemburg and do Piesport. Nice work Mr Lion!! I should mention I have a pair of 6th gen passenger footrest mounts I neither want nor need... they are a little on the fugly side where the hardbag brackets hook up from the brackets rubbing and also the actual footpegs are rashed from slides but otherwise they are decent and I' d be willing to part with them at mate's rates... just let me know!! Will you be painting the bags red?? Link to comment Share on other sites More sharing options...
Auspanglish Posted August 17, 2013 Share Posted August 17, 2013 BUMP on my question ^ How wide is your azz? 6th gen with cases? Any other year with say GIVI? At the absolote widest point, mine is some 105cm Basically the same I believe Dutchy!! IMSMR Link to comment Share on other sites More sharing options...
timmythecop Posted August 23, 2013 Share Posted August 23, 2013 with the E28 bags (my most common rig) it measures 38 inches or 96.52cm at the widest point. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 23, 2013 Author Member Contributer Share Posted August 23, 2013 Cheers Timmy!!! Right! Post up more sizes of yer azzes please. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 30, 2013 Author Member Contributer Share Posted September 30, 2013 Bigger boys want bigger toys........... Red pearl a very tricky color to photograph in sunlight..... Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted September 30, 2013 Member Contributer Share Posted September 30, 2013 I measured the width of Givi V41 s on a fifth gen. Approx. 42" (107 cm). My riding buddy describes the view from the back as "looking at a pregnant cow from the rear". Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 30, 2013 Author Member Contributer Share Posted September 30, 2013 Thanks you sir Terry; we can call our bikes "The Fat Slags" cos me red slut's erse measures about the same... Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted September 30, 2013 Member Contributer Share Posted September 30, 2013 Okay as pregnant cow seems udderly ridiculous. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted March 7, 2014 Author Member Contributer Share Posted March 7, 2014 What about blue Vtec cases on my redslut? w/o the red reflectors since they are illegal here.... Link to comment Share on other sites More sharing options...
timmythecop Posted March 7, 2014 Share Posted March 7, 2014 Nee, helle nee ! enorme NEE!!!! Link to comment Share on other sites More sharing options...
Auspanglish Posted March 19, 2014 Share Posted March 19, 2014 A bit like red sidecases on my blue VTECker. Stuck out like bull's balls. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted March 20, 2014 Author Member Contributer Share Posted March 20, 2014 Cheers guys! I was considering swapping mine (cases not balls) but indeed thought the better of it. Link to comment Share on other sites More sharing options...
Member Contributer DFerrell Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 Here's a trick for limited access to the seat lock tumbler when running bags. I went to my local locksmith and asked for a new key that I could cut down the back side to make it easier to get the key in with out taking off the luggage mounts. He told me since the seat lock was much more shallow then the ignition tumbler he could cut it on a key with the same profile all the way back to the back or shank of the key. Here's what he came up with. Hope this helps. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 8, 2015 Author Member Contributer Share Posted May 8, 2015 Well, I picked up The Viking from the airport last week and he noted that the bracket to the right footrest was interfering with the back of his boot. So I adressed that, as well as modifying the top bracket so that the right case is more level. Link to comment Share on other sites More sharing options...
