Guest mipom Posted March 24, 2013 Share Posted March 24, 2013 Hi, now i start a new topic for my project. This is my VF1000 when i bought it.CBX 1000 is my friend's old bikeThe previous owner has started to modify the VF but only remove the front end and leave the original mechanical.My project is leave original the chassis and engine but change front and rear suspension, brakes and wheels, install an handle bar and a new cockpit Link to comment Share on other sites More sharing options...
Guest Posted March 24, 2013 Share Posted March 24, 2013 The first hard work that i've started is the new front end. I bought a complete forks set from a Ducati multistrada 1000 with a couple of Brembo calipers, a front 16'' wheel from a CBR. The first step in this photos:If someone has advices....... Link to comment Share on other sites More sharing options...
NakedViffer Posted March 24, 2013 Share Posted March 24, 2013 Nice! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted March 24, 2013 Member Contributer Share Posted March 24, 2013 Isle of Man !!!! Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted March 24, 2013 Member Contributer Share Posted March 24, 2013 Good start. Should that radiator be moved out away from the rocks coming off the front tire? Link to comment Share on other sites More sharing options...
SEBSPEED Posted March 24, 2013 Share Posted March 24, 2013 I have loved the look of a naked VF since the first time I saw one. If I had a 1000F, I would do exactly what you are doing! Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted March 29, 2013 Member Contributer Share Posted March 29, 2013 Those Multistrada forks have a lot of travel. My suggestion would be to limit the travel to 120mm and make sure to setup the springs and valving for the VF1000F and you should be all set. Don't forget to check your clearances! Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2013 Share Posted April 3, 2013 yes, i see that are too soft for the weight of VF!!! i think i need 2 new hard spring.... Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted April 3, 2013 Member Contributer Share Posted April 3, 2013 How about some pazzo knock off levers? That fork / wheel / bar combo looks great. Link to comment Share on other sites More sharing options...
