Riding to work without the rectifier
Guest veemexx
Guest veemexx
Just bought the '99 a couple of weeks back and last week it did not start. Charged the battery and traced the probable cause of the discharged battery to a broken rectifier-regulator (RR). So I've disconnected the RR and have ridden the '99 to work today while waiting for a replacement RR to arrive in the mail. Will there be any other problems (besides the problem of a discharged battery) riding without a RR hooked up?
ps. Commute is just 15 miles to and fro, so drain on battery is replenished with a battery tender once home.
Thanks!
I agree it's a bad idea. If I'm not mistaken, the rectify part of the equation is changing the AC coming from the stator into a DC current. The regulator part controls the voltage sent out. If you have bypassed the RR, you are probably frying several items. If you have completely disconnected the stator from the bike by unplugging the RR, you are most likely running on battery power only, which will quickly leave you stranded.
You're just running a total loss system as long as the stator is not plugged into anything. Not great for the battery. As long as you make it home, count your blessings and don't bother doing it again.
I get the feeling he just disconnected the r/r so no drama with AC issue. That distance to work w no waiting at lights etc can probably be viable 4 quite some time w tender at home and work.. no damage done provided the battery isnt critical, a low battery WILL stress the charging system components
MY RR bolts Fell off on a hard ride...
It was hanging.
I made it about 30 miles before the bike died.
Once I remounted the RR with locktite and charged the battery, it ran fine again.
Thanks for your input guys.
The consensus from everyone is that it's bad for the battery. I'll have to agree. Battery was fully charged at 12.8 v and came home 11.8v. Definitely not good.
On the upside, I now know that the RR is not completely dead. With the RR hooked up, I would come home with the battery reading 12.6 v. However, the RR isn't providing >12.8 volts at the battery terminals @ 5k rpms, so I'm thinking it is on it's way out.
Anyway, I've purchased a new RR, and will now probably consider a new battery since I've stressed the hell out of it (and besides I'm not even sure of it's history).
I'm leaning towards a Motobatt MBTX12U. Does anyone have anything negative to say about it?
Only for lead acid - Lithium batteries are fine and you can use them for total loss systems all the time with no battery damage (unless you run it DEAD flat). As always you would never run a total loss system with the headlights running as this is a full 10 amps (if you have two globes) and will flatten the battery real fast. The biggest amp draw on a total loss system will be the fuel pump.
one of my VFR's was set up as a AFM open superbike racer and it had a full loss ignition system and most races were 20 laps x 2 1/2 mile= 50miles w/ no issues. It didn't have a rotor/ stator, reg./rect. or starter and of couse had no lights.You should be fine going 15 miles, but to be on the safe side I'd throw it on a trickle charger while @ work
I depend on my Bike, I travel remote areas, ONLY the AGM st1300 battery is THE choice, you want to play guinea pig with Hard electrical parts and potential failure at the most inopertune time, by all means get one of those Unproven batteies, and there is no one on this Board who has any real milege and time on the Guinea pig batteries, many have ended up with issues.
Nuff Said
CLICK HERE This guy did a bunch of tests on several batteries including the Motobatt. I didn't read through it all but initially it appears to do well in his tests.
I fitted a Motobatt MBTX12U in May 2011 and it has operated faultlessly for me. My bike sits idle for long periods nowadays, like a month at a time, but the battery has never looked like being low on charge when starting. It is not one of the new Ubeaut lithiums but just another type of glass mat type. My only criticism would be that it is a tight fit in the battery box of the 5th Gen, even though I took careful measurements and checked these against published dimensions. It may be difficult to remove when replacement necessary, but I'm happy to put up with that on comparison to the published prices of other batteries available to us here in Oz (no Walmarts here!!)
My replacement rectifier-regulator (RR) finally arrived in the mail. Connected it up and performed a regulated voltage inspection per factory service manual with the 'headlight on Hi beam'. Surprisingly, at idle, voltage reads 14.3 V and at 5k rpm I get 14.9 V. This is with a Rick's 10-125H mosfet RR and Everstart ES12BS (of unknown history but still charges up to ~13 V with trickle charger). I'm glad that I'm getting voltages close to factory specifications at 5k rpm, but isn't it high at 14.3 V, idle?
Stator is good, <1 ohm between all three connectors, and no continuity to the ground. ~11 VAC at idle and around ~60 VAC at 5k rpm between all the connectors. So I think it's not the stator.
Ok, I found some posts from Mazeav and Cogswell that list 14.2/14.5 at idle to 14.8 V at 5k rpm. And I think this is 'normal' for the mosfet RR.
I depend on my Bike, I travel remote areas, ONLY the AGM st1300 battery is THE choice.
I've read good reviews for the Yuasa battery but at that price, it might have to wait.
Maybe if we can have someone on this forum test the Motobatt and Yuasa batteries side by side we could settle this once and for all?
Anyways, will hold off on the new battery for now since I've blown my monthly budget on the RR and a VFRness from tightwad.
Thanks guys!
Thanks guys!
You can get the st1300 yuasa for $120 online, Ive been testing the St1300 AGM Scorpion only $80, to see if it atleast matches the yuasa, otherwise the Yuasa is worth the extra $40, but so far the scorpion has Met the Grade, It did come with cheap nuts, had to transfer my yuasa's to it. I've only got about 15,000 mile on the scorpion, if it goes 40 to 45,000, its meets yuasa life.
Battery testing comes from time and milege, the lithiums are great for power tools, but Ive seen over 1/2 dosen issues from various people with them on the VFR as a Battery.
Stator is good,
Nope that is *awesome*. It means your stator is top notch and your regulator is set to regulate at 14.9 volts. Basically 14.3 volts at idle and 14.9 at revs means it's not regulating at all, just rectifying the AC to DC.
oops.. i was quoting the OP there but my message didn't come out.. what you can read is actually from the OP.
