JWhelan65 Posted November 1, 2011 Share Posted November 1, 2011 Not much to look at for now, completely tore down, wheels off to the powder coater, paint and body work being done.. Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 1, 2011 Author Share Posted November 1, 2011 One more... Link to comment Share on other sites More sharing options...
Member Contributer Kel Posted November 1, 2011 Member Contributer Share Posted November 1, 2011 You call that completely torn down?? R projects are always fun. Make sure the PC guys don't bake the wheels too hot, I've heard of R wheels loosening up after getting PC'd, they're only bolted together after all. Welcome aboard, I'll be watching this one. I see an 1100F no less. Link to comment Share on other sites More sharing options...
smackdoogle Posted November 1, 2011 Share Posted November 1, 2011 Do it to it!!!! Looking forward to the progress over the winter. Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 1, 2011 Author Share Posted November 1, 2011 You call that completely torn down?? R projects are always fun. Make sure the PC guys don't bake the wheels too hot, I've heard of R wheels loosening up after getting PC'd, they're only bolted together after all. Welcome aboard, I'll be watching this one. I see an 1100F no less. Lets just say it is torn down as far as I want to take it Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 1, 2011 Author Share Posted November 1, 2011 I want to replace the rear sprocket, does the VF1100F use the same bolt pattern? Link to comment Share on other sites More sharing options...
Member Contributer VF1000RS Posted November 1, 2011 Member Contributer Share Posted November 1, 2011 Lemme look. Link to comment Share on other sites More sharing options...
Member Contributer VF1000RS Posted November 1, 2011 Member Contributer Share Posted November 1, 2011 The VF1000F looks like it uses the same sprocket. I'm sure that's what you meant. I see the CB1100F in the faster blue color... And what looks like a XN85 in the background...? Link to comment Share on other sites More sharing options...
Dmitry Posted November 1, 2011 Share Posted November 1, 2011 Can't recall what it said on the box but when I got sprockets for my 1KR there was a long list of Honda bikes that they fit. Did both sprockets and chain at same time. Check the valve clearance and cams while you have the bike apart this is what happened to my '86 with under 20K miles Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 1, 2011 Share Posted November 1, 2011 I spy a set of fancy lightweight wheels! Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 1, 2011 Author Share Posted November 1, 2011 I spy a set of fancy lightweight wheels! Yes, Marchesini Magnesium's Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 1, 2011 Author Share Posted November 1, 2011 The VF1000F looks like it uses the same sprocket. I'm sure that's what you meant. I see the CB1100F in the faster blue color... And what looks like a XN85 in the background...? Yep, this is the 1100F the other bike you see is an 85 GS700ES Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 1, 2011 Share Posted November 1, 2011 I spy a set of fancy lightweight wheels! Yes, Marchesini Magnesium's Very nice. Are they going on one of the bikes listed here? Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 1, 2011 Author Share Posted November 1, 2011 I spy a set of fancy lightweight wheels! Yes, Marchesini Magnesium's Very nice. Are they going on one of the bikes listed here? I had plans for them but I dont think they will work for what I intended, so I guess they are for sale Link to comment Share on other sites More sharing options...
Member Contributer unbalanced Posted November 2, 2011 Member Contributer Share Posted November 2, 2011 Looks like it found a good home, can't wait to see it finished. Welcome! Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 12, 2011 Author Share Posted November 12, 2011 Anyone have a good source for a set Race Tech springs? Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 12, 2011 Share Posted November 12, 2011 If you're talking about fork springs, look up Rich Desmond at www.sonicsprings.com instead. Same quality, $30 less... Link to comment Share on other sites More sharing options...
Dmitry Posted November 12, 2011 Share Posted November 12, 2011 Before you go nuts with upgrades adjust the valves and check the cams, I just got a whole new motor cause my cam was boned (posted pics earlier) the new motor has similar issue with same rear exhaust cam. Also all the used cams I found so far have similar pitting on the same lobe... I put whole lot of money and effort in to this bike, had I known the cam was bad would have just abandon the project early on before I rebuilt the rest of it. Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 13, 2011 Author Share Posted November 13, 2011 If you're talking about fork springs, look up Rich Desmond at www.sonicsprings.com instead. Same quality, $30 less... Never heard of them, any good? Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 13, 2011 Author Share Posted November 13, 2011 Picked the wheels from the powder coater and had some new rubber installed..went with a 20% gloss finish Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 13, 2011 Author Share Posted November 13, 2011 New wheel and stem bearings, filters, galfer braided lines, fork seals Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 13, 2011 Author Share Posted November 13, 2011 Before you go nuts with upgrades adjust the valves and check the cams, I just got a whole new motor cause my cam was boned (posted pics earlier) the new motor has similar issue with same rear exhaust cam. Also all the used cams I found so far have similar pitting on the same lobe... I put whole lot of money and effort in to this bike, had I known the cam was bad would have just abandon the project early on before I rebuilt the rest of it. Yep on the list.. Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 13, 2011 Author Share Posted November 13, 2011 More powder coat bling Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 13, 2011 Author Share Posted November 13, 2011 Had some new stickies made for the old tired F1r's Link to comment Share on other sites More sharing options...
JWhelan65 Posted November 13, 2011 Author Share Posted November 13, 2011 Nothing to major here, cleaned up and flushed the calipers, new pads on the way cleaned up both master cylinders and ordered kits for all including the rear, replaced the seal in the slave as well.. Link to comment Share on other sites More sharing options...
