Forum CEO HispanicSlammer Posted October 11, 2011 Forum CEO Posted October 11, 2011 You old tymers may have noticed that when starting a new topic the "topic description" line no longer exists, replaced with "topic tags" this is not the same, its been adopted from popular blogging software to aide in searching. Topic tags are simple one or two word descriptions of the content you are adding, not a line paragraph or sentence to describe the topic anymore. The tags all get shown together or can be searched to create a list of similar topics pertaing to that tag. Some of you have already adopted this approach some are still adding sentences as a topic description to the topic. I would still like to make topic tags open, but as an admin I can just post up a list of tags for you to choose from and well I am not that creative so the tags would be limited to my feeble list of tags. So please I hope I have explained what tags are - and on the homepage you will see a new block, and on the forum index page there is also a block with popular tags - click on the tag that interest you and see a list of topics tagged that way. for example I tagged this topic with "topics" "tags" "description" and "search" you can add up to 10 tags to a topic, and you can go back and edit them if you want to later on the topics you created. Quote
Member Contributer TexOz Posted October 11, 2011 Member Contributer Posted October 11, 2011 Thx HS - I thought it looked a bit different but didn't take much notice Quote
Member Contributer Dutchy Posted October 11, 2011 Member Contributer Posted October 11, 2011 I will use the tag "redslut" so search engines can find my topics easily Quote
Member Contributer Muff Posted October 11, 2011 Member Contributer Posted October 11, 2011 I will use the tag "redslut" so search engines can find my topics easily I've been called that many times Quote
SEBSPEED Posted October 11, 2011 Posted October 11, 2011 Tagging away. Wonder how much our traffic will increase with this in place? Search engines will pull these tags more often, correct? Or does the tagging work for searches within the site only? Quote
Forum CEO HispanicSlammer Posted October 11, 2011 Author Forum CEO Posted October 11, 2011 Its all a part of search engine optimization seo tagging Quote
Forum CEO HispanicSlammer Posted October 18, 2011 Author Forum CEO Posted October 18, 2011 Make sure to hit the return key after each tag so that it registers it singlely, or it will lop them all together as one tag. you will see a blue box form around the tag each time it registers. Quote
Forum CEO HispanicSlammer Posted January 30, 2012 Author Forum CEO Posted January 30, 2012 New topics will require an input of at least one tag now, one word that best describes the topic, you can use more then one, as long as you separate each new tag with a comma and not one long string of words as one tag. Sometimes a tag will require a string of words just use common sense please! Tagging is the way the forum software is now going forward in the future makes sense to use it wisely, makes searching topics so much easier. (I.E. the redslut tag our friend in Holland uses for his topics - that's the name of his bike not about a person!) Quote
marriedman Posted June 19, 2012 Posted June 19, 2012 Hmm, sorry to resurrect an old thread, but I don't see a button nor field to tag my new thread. Am I just blind or has this been removed? Quote
Forum CEO HispanicSlammer Posted June 19, 2012 Author Forum CEO Posted June 19, 2012 Topic tags are added when starting the topic, an input box is just below the thread title box. You can also edit the topic tags by editing the top post with the full editor. Quote
Member Contributer Dutchy Posted June 19, 2012 Member Contributer Posted June 19, 2012 I'm dutyfully tagging my topics...... I may lure some new members......... Quote
