OK, so here’s the story. This is my 1st post here and I have a real project. I just purchased a 93 750f and it’s had some case of neglect. It was low sided in 2003 and has sat since. I bought it on 7/3/10 since then I have yanked the carbs and cleaned the jets/bowls and checked the needles, (all came out well) after that she fired right up and runs STRONG!
I have De-Paired it, and removed just about ever unnecessary shield I could find. Wiring seems to be all good except the brake lights only work intermittently (I’ll open that can of worms later.) I yanked the Catalytic Converter and Canister along with the center stand and weighed them….. (31Lbs. Combined!!!!) They won’t be retuning to the bike.
Let me share my ideas
I want a free flowing under tail exhaust – Issues: I can’t seem to find a catless header to allow it. I will try to separate the existing catalytic converter from the header and weld on what I need to achieve this (That’s unless you guys have a better solution)
I need plastics, I don’t even have a gas tank. lol I’ve been running it with the tank from my lawnmower! Issues: I’m not quite sure what to use, stockers are out of the question but from what I hear 93ish cbr900 fairings seem to be the easiest to work with (again if you have a better solution please….)
The Forks are beat to shit, well... at least one, the previous owner let a backyard loser attempt to rebuild the forks and the right one has metal shavings in it somehow. I will chuck them both and replace with stock parts. Issues – I want to uses a stiffer spring and heavier oil but don’t know what springs will work.
Last – I need a tank – Issues: none
A bit about me: I’m 26yrs old, and an avid motorcyclist, Especially Canyons and Track. I have ridden Suzuki’s since 2005 and all the sudden fell in love with the V4 Honda. I don’t want to track this thing, but I know it can corner and simply want to get the most out of it. It will primarily be used as a commuter vehicle and an occasional canyon trip.
PLEASE PLEASE PLEASE! Feel free to drop any tricks of bit useful information that a newcomer to these bikes would not be aware of. I appreciate all of you input guys!!
I will continue this thread as it progresses, here’s the bike now
Question
Guest DreStyleNY
-Andre
7/3/10
7/3/10
7/3/10
7/7/10
7/7/10
7/7/10
30 answers to this question
