Michael32 Posted February 8, 2016 Share Posted February 8, 2016 Working on a deal that will put an 02 VFR in my garage next week. Bike has: 2 previous owners 36k miles A few scratches One small crack in fairing Sitting outside for at least a year Sargent seat Zero shield New fluids-all Fairly new pads Chain and sprocket 5k ago Bike needs: front tire Battery Lots of wax? Lube all controls? Check for recall To be rode Everything else is stock Am I missing anything? Link to comment Share on other sites More sharing options...
GigemVFR Posted February 8, 2016 Share Posted February 8, 2016 Check charging system and quick check of all nuts/bolts to make sure tight while your at it. Link to comment Share on other sites More sharing options...
Michael32 Posted February 8, 2016 Author Share Posted February 8, 2016 Thanks Link to comment Share on other sites More sharing options...
Baileyrock Posted February 9, 2016 Share Posted February 9, 2016 Get'er done son and welcome to VFRD! Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted February 9, 2016 Member Contributer Share Posted February 9, 2016 Have a look at the date code on the tires. No matter the tread - if they're getting on in years and have been sitting outside since this time 2015 or longer, new rubber might be in order. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 9, 2016 Member Contributer Share Posted February 9, 2016 Excellent suggestion ^^^ and WELCOME ! Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted February 9, 2016 Member Contributer Share Posted February 9, 2016 Welcome to the asylum. Good luck with your new ride. Link to comment Share on other sites More sharing options...
Michael32 Posted February 11, 2016 Author Share Posted February 11, 2016 Bike is here. Needs a lot of detailing. Will post pics when finished. Sweet ride. Thanks to all. Link to comment Share on other sites More sharing options...
Michael32 Posted February 28, 2016 Author Share Posted February 28, 2016 Bike is ready to ride. Recall was done. Controls were lubed. New tire on front. Figured out that the baffles have been removed. Runs great. Ordered, but UPS ran a fork lift over the box. These plastics are fine, just a little faded. Everything works great except for the rear shock. Cannot move the adjuster. So here is my question, is the rear shock on a 2002 red? Thanks for any answers! Ordered new plastics but UPS decided I didn't need them. Link to comment Share on other sites More sharing options...
TheGuide Posted February 28, 2016 Share Posted February 28, 2016 Welcome! Bike looks beautiful, have fun! Link to comment Share on other sites More sharing options...
Knight Posted February 28, 2016 Share Posted February 28, 2016 Were you provided service records? Depending on those, check the thermostat for stuck open position. Tune the starter valves. Make sure the brakes are not binding. A long freeway run being gentle on the throttle, then check the mileage. While mileages vary, this one piece of data can catch problems or validate that everything is in the green. You should put the VFR at the top of your bike list in your profile, because it is clearly the most awesome bike that you own. Link to comment Share on other sites More sharing options...
Michael32 Posted March 3, 2016 Author Share Posted March 3, 2016 No service records. Will check on thermostat and starter valves. Brake pads were slapped on by po and were not wearing in an even pattern. That was corrected when the new front tire was put on the bike. As far as moving the bike up on the totem pole, I like your idea. Thanks for the heads up! Such a sweet ride. Now I know why I have always wanted a VFR. Link to comment Share on other sites More sharing options...
