neptech Posted September 8, 2014 Share Posted September 8, 2014 I am attempting to install a PCV on an 02 the instructions shows two connectors, I can only find one am I missing something?? Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted September 9, 2014 Member Contributer Share Posted September 9, 2014 There should be one connection to take apart and the PCV links to the two ends you took apart and there should also be a power and ground connection if I remember correctly. Link to comment Share on other sites More sharing options...
Member Contributer expvet Posted September 9, 2014 Member Contributer Share Posted September 9, 2014 Basically you unplug the stock throttle body connector on the bike and then plug in the PCV connector, then disconnect the 2 oxygen sensors and plug in the 2 connectors from PCV, then connect the power wire to the negative terminal of the battery. Where are you having difficulty connecting? Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted September 9, 2014 Member Contributer Share Posted September 9, 2014 Unless they changed things, the O2 oxygen sensors leads are plugged with terminators and do not connection to the PCV. Link to comment Share on other sites More sharing options...
neptech Posted September 9, 2014 Author Share Posted September 9, 2014 MY problem is, I have two plugs on the PCV and can only find one plug on the bike, according to the instructions there should be two. I am at a loss where the other plug is located on the bike.... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 9, 2014 Member Contributer Share Posted September 9, 2014 You insert in series right . This one ? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 9, 2014 Member Contributer Share Posted September 9, 2014 Here I found this , mite be some help. http://www.powercommander.com/downloads/101/install/111/eng101-111.pdf Link to comment Share on other sites More sharing options...
Member Contributer jim v Posted September 9, 2014 Member Contributer Share Posted September 9, 2014 I'm interested in installing a PCV on my '02. Please let us know how it goes...... Link to comment Share on other sites More sharing options...
Member Contributer dawson Posted September 9, 2014 Member Contributer Share Posted September 9, 2014 It's easier if you lift the tank and pull the airbox lid. On the right side of the bike, between the airbox and the frame, about halfway down the airbox there's a large grey junction connector with one of the sliding plastic shields over it. Undo that connector and you have two sides, a male and a female. Put the power commander connectors in the appropriate spots and route the cable back to the PCV. Now the signals from the ECU pass through the front harness, into the PCV, out of the PCV and into the rear harness. You'll also need to run wires to the speed sensor and thermometer to get the most out of the power commander. They're on the left side of the bike, one is in the bundle with the O2 sensors and one is in the connector under the rad. Link to comment Share on other sites More sharing options...
ciprinakos Posted September 9, 2014 Share Posted September 9, 2014 You should check this: http://www.vfrdiscussion.com/forum/index.php/topic/58306-experiences-of-a-pcv-with-autotune-on-a-2004-vfr800/ This what I followed for my '03 and all went well. Link to comment Share on other sites More sharing options...
neptech Posted September 9, 2014 Author Share Posted September 9, 2014 There should be one connection to take apart and the PCV links to the two ends you took apart and there should also be a power and ground connection if I remember correctly. There should be one connection to take apart and the PCV links to the two ends you took apart and there should also be a power and ground connection if I remember correctly. Thanks m8 so much, it was so simple... Link to comment Share on other sites More sharing options...
neptech Posted September 9, 2014 Author Share Posted September 9, 2014 Just got back from a ride....all I can say is wow, very nice, like a new bike runs like the Devil Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2014 Share Posted September 17, 2014 That was my first reaction. CRAZY improvement. Link to comment Share on other sites More sharing options...
Question
neptech
12 answers to this question
