adamv Posted April 21, 2014 Share Posted April 21, 2014 Hi, Reading the manual for the VFR 800 the Pre-Ride inspection says (amongst other things) to check the coolant level, and to check for leaks. However according to the manual, it appears as though I have to remove the left front cowl to access this to check it. Are we expected to remove our fender before every ride? Is there another way to check coolant levels? What do you guys do? Cheers Adam. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted April 21, 2014 Member Contributer Share Posted April 21, 2014 actually you can... flash a light on the opposite side i,e. gear lever and should be able to see the level from the front gap where the coolant is. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 21, 2014 Member Contributer Share Posted April 21, 2014 Kick the tires and light the fires. And check the chain !!!! Link to comment Share on other sites More sharing options...
spud786 Posted April 21, 2014 Share Posted April 21, 2014 Isnt there a modified version, that is when you walk out to the bike and if coolant is on the ground, check it, otherwise keep riding and check the res every year or 2, when you have the cover off. Its really a non issue to check that bottle unless the bike has some weird issue, it doesn't eat coolant, on a good functioning bike. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted April 21, 2014 Member Contributer Share Posted April 21, 2014 On the 4th gen, one has to remove the side panel so I check this maybe once a year or when I take the panel off for another reason. Pre ride check I do is tyre thread, chain slack and fule level. Every 3rd stop for fuel I check tyre pressure. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted April 21, 2014 Member Contributer Share Posted April 21, 2014 I would check once in a while or after a long stop and go ride. Or if the bike is heating up. thanks Anik Link to comment Share on other sites More sharing options...
adamv Posted April 22, 2014 Author Share Posted April 22, 2014 OK - thanks guys. I won't get to paranoid over not checking it then. :) Link to comment Share on other sites More sharing options...
nearfreezing Posted April 27, 2014 Share Posted April 27, 2014 The fairing doesn't have to be removed to check the coolant level. Just peek behind the fairing--the coolant bottle/markings and coolant level will be visible. Link to comment Share on other sites More sharing options...
Member Contributer vfrurknee Posted April 27, 2014 Member Contributer Share Posted April 27, 2014 I usually have that side off for an oil/filter change. That is often enough to check the coolant reservoir and adjust if necessary. Link to comment Share on other sites More sharing options...
