jagdoc Posted March 21, 2014 Share Posted March 21, 2014 I use a front stand from Handy that has pins that fit into the bottom of the forks. I also remove the front fender and there is plenty of room to roll the wheel out. Only have to remove one caliper this way, I think the right one. Link to comment Share on other sites More sharing options...
keny Posted April 7, 2014 Share Posted April 7, 2014 Put on center stand and stuff a paint can under the header. Floor jack works too, BTW So this gives enough clearance to get tire out from under fender? It will just clear the tire, if I recall right , all dipends on rear tires wear and also suspension setup. But if the clarens is tight, its just 4 scruves to take off the fender anyway, at least on a 5th gen. Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted June 30, 2015 Member Contributer Share Posted June 30, 2015 Put on center stand and stuff a paint can under the header. Floor jack works too, BTW Do the side panels need to be removed to do this? And can the wheel be removed without messing with the caliper? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 30, 2015 Member Contributer Share Posted June 30, 2015 1. No 2. Yes but only one side . Roll On .. Link to comment Share on other sites More sharing options...
Member Contributer zupatun Posted July 1, 2015 Member Contributer Share Posted July 1, 2015 One thing to watch out for on the VFR with suspending the bike from the ceiling or a front end lift (Pitbull with a pin) under or through the steering head. The Steering head is a pivot! If you have the bike on the rear tire (not balanced on the center stand) the bike can twist around the steering head (on the stand or supported from a ceiling joist) and fall over! This could be very disconcerting...and dent your wallet. If the bike is supported by the center stand and you llift the bike with a jack under the headers--you will be balanced until you compress the rear tire enough to lever the bike up off the center stand...at this point you can also have the bike tilt and fall over as well. Bike weighs nigh 500+ pounds. Be careful--make sure your load is not only balanced, but secure. Matt Make sure you are hanging it off a strong/deep enough joist or truss in your garage too. I've seen enough garages and houses in my Architectural career that did not have adequate roof/ceiling structure to support a 200+ pound point load like a hanging VFR might exert.... If not sure, try to hang the bike not at mid-span of the ceiling/roof structure, but closer to one wall if possible....... Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 31, 2015 Member Contributer Share Posted August 31, 2015 Simple jack still works fine.... Link to comment Share on other sites More sharing options...
