UKBIker Posted June 3, 2013 Share Posted June 3, 2013 Have a noise coming from the engine, sounds like the rear cylinders area. Anybody heard this type of noise ??? Both cam chain tensioners have been replaced. Hope this link works- http://youtu.be/NHPcF7KNPOM// Link to comment Share on other sites More sharing options...
V4 Rosso Posted June 3, 2013 Share Posted June 3, 2013 Hope this link works- It doesn't Link to comment Share on other sites More sharing options...
UKBIker Posted June 4, 2013 Author Share Posted June 4, 2013 Ok try this link, Link to comment Share on other sites More sharing options...
superfunkomatic Posted June 4, 2013 Share Posted June 4, 2013 ? There's no sound in the video. Is it clicking sound when your bike idles? That's CCT noise. Mine has it. Sometimes a change of oil will keep it quiet for a while. Haven't had the time or inclination to fix mine yet. Link to comment Share on other sites More sharing options...
UKBIker Posted June 4, 2013 Author Share Posted June 4, 2013 Just rechecked the link, I get video and sound. Is there a format I can upload to gallery. Tried .mov and .avi Im thinking this is internal so I started removing parts. I was hoping someone here might have heard this sound so I wouldn't have to remove the engine. Link to comment Share on other sites More sharing options...
Member Contributer CasualSwede Posted June 4, 2013 Member Contributer Share Posted June 4, 2013 It sounds kinda like an exhaust leak, but maybe a bit more metallic than I'm used to. Did the noise start immediately after you replaced the CCT? Have the headers been removed and reinstalled recently? A bit more background could be helpful. Link to comment Share on other sites More sharing options...
Member Contributer hondalover Posted June 4, 2013 Member Contributer Share Posted June 4, 2013 To me, it sounds too metalic for an exhaust leak. Of course different speakers can change the sound. But I'd lean towards something in the cam chain/valve train area. The engine does not have to be removed for that inspection. Maybe a broken valve spring, because I think ours are double sprung. Link to comment Share on other sites More sharing options...
UKBIker Posted June 4, 2013 Author Share Posted June 4, 2013 The noise started during my ride home, I felt some power loss, i thought it sounded like a cam chain tensioner but maybe louder, so i replaced both. noise didnt change at all. compression in all cylinders is within 10psi of each other, vacuum is steady on all cylinders. To remove the valve springs on the rear cylinder i think the engine has to be removed. I also wondering if it is big eng bearings. Link to comment Share on other sites More sharing options...
Member Contributer Yokel Posted June 4, 2013 Member Contributer Share Posted June 4, 2013 Your link sent me to the mobile site, here's a link for those on a PC, sound works fine for me. Unfortunately, i'm not good for insight on this... but I do fix links! Link to comment Share on other sites More sharing options...
UKBIker Posted June 5, 2013 Author Share Posted June 5, 2013 Thanks for the update link Yoke . Have the day off tomorrow so going to start the tear down. Hoping someone has a easier solution . Thanks for the posts Link to comment Share on other sites More sharing options...
UKBIker Posted June 6, 2013 Author Share Posted June 6, 2013 Didnt get as far as i wanted to but its a start. I forgot how working on the floor sucks ! Link to comment Share on other sites More sharing options...
UKBIker Posted June 9, 2013 Author Share Posted June 9, 2013 Got it out this morning, rear head off. Need a valve spring compressor small enough to work on these valves, anyone in the Jacksonville Florida area have one or give me a idea on which one to buy? Link to comment Share on other sites More sharing options...
UKBIker Posted June 13, 2013 Author Share Posted June 13, 2013 After some modification to a spring compressor the springs and valves are out of the rear head, look ok. Took the sump off, found this stuck hard to the surface !! Link to comment Share on other sites More sharing options...
UKBIker Posted August 1, 2013 Author Share Posted August 1, 2013 UPDATE After a complete teardown the problem was found, the bigend bearing on cylinder 3 had spun damaging both rod and crank. I was surprized to see that the main bearings were also worn and would need replacing, Only 70000 miles on this engine and the oil/filter is changed every 3000 miles!! Its taken up untill now for all but one part to get to me from honda (almost two months), the engine case main bolts are on gallatic back order. Link to comment Share on other sites More sharing options...
Member Contributer Yokel Posted August 2, 2013 Member Contributer Share Posted August 2, 2013 Wow, that's a surprise... Not a happy sight. I feel for ya. Link to comment Share on other sites More sharing options...
VFR4Lee Posted August 2, 2013 Share Posted August 2, 2013 Wow, a rarely seen VFR engine major breakdown. Sorry to see it, hope the last parts come in soon for ya. Link to comment Share on other sites More sharing options...
Member Contributer MBrane Posted August 2, 2013 Member Contributer Share Posted August 2, 2013 Blocked oil passage due to metal trash from a defective bearing? Very interesting. Link to comment Share on other sites More sharing options...
