nardenodo Posted May 1, 2013 Share Posted May 1, 2013 As i was fitting the carbs back on the viffer i realized i have 2 metal pieces that should probably go someplace. here are some pics If additional pictures of the carburetor itself or diff angles of these pieces would assist anyone in helping me identify where they should go please write it here Link to comment Share on other sites More sharing options...
BRad704 Posted May 1, 2013 Share Posted May 1, 2013 The smaller piece looks like a cable clamp. Would be used to hold the end of a cable in place. Any loose cables or hoses showing? The second, Looks like it had a washer (maybe had a linkage rod going through the large hole with a washer also). And the threaded hole obviously would have had a screw in there, but I'm not sure where exactly. Do the 2 pieces fit together? It looks to me like there could be a screw to pass through the small piece, and thread into the larger piece. the small nub on the smaller piece would fit in the square-spot beside the threaded hole to prevent it from rotating around the screw. Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted May 1, 2013 Member Contributer Share Posted May 1, 2013 It almost looks like the two pieces fit together. The small piece has that little tab and the large piece has a notch right next to a threaded hole. Although the way your are holding both pieces, the whole doesn't match up with the notch, but from the bottom of the larger piece, it looks like it would. I'm just guessing here though. Link to comment Share on other sites More sharing options...
NakedViffer Posted May 1, 2013 Share Posted May 1, 2013 Those two pieces definitely fit together, its the bracketry to hold your choke cable in place, go take your carbs back apart. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 1, 2013 Member Contributer Share Posted May 1, 2013 like i said in another thread.. TAKE PIX!! lots of them!! too late for this project.. but do it on your next one! Link to comment Share on other sites More sharing options...
timmythecop Posted May 1, 2013 Share Posted May 1, 2013 they are held in place by one of the carbs top screws. Link to comment Share on other sites More sharing options...
Audigier Posted May 1, 2013 Share Posted May 1, 2013 Never seen vfr carbs but I've worked in a couple of Hondas and it looks like the choke cable holder/clamp Link to comment Share on other sites More sharing options...
RCDekker Posted May 1, 2013 Share Posted May 1, 2013 Most definitely your choke cable holder. I've connected them yesterday, not too much work. Link to comment Share on other sites More sharing options...
nardenodo Posted May 1, 2013 Author Share Posted May 1, 2013 The first picture is how these two parts go together, i think. now i'm just a little confused as to how they attach to the choke cable. anybody know the page # i could look at in the VFR manual to examine this? thanks for quick response guys! Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted May 1, 2013 Member Contributer Share Posted May 1, 2013 The clamp in your hand holds the end of the cable housing where the cable exits, the cable itself then slots into the choke lever pictured in your lower pic. The bracket in your hand must be attached to the carb by one of the top screws so that it is stationary and when you move the choke lever on the bar, the cable inside slides the choke lever pictured in your lower pic. Link to comment Share on other sites More sharing options...
nardenodo Posted May 1, 2013 Author Share Posted May 1, 2013 When you mention the "top screws", are you referring to the 4 screws that hold the bottom portion of the aribox to the carbs? Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 2, 2013 Member Contributer Share Posted May 2, 2013 When you mention the "top screws", are you referring to the 4 screws that hold the bottom portion of the aribox to the carbs? the 4 that hold top of the carb next to the choke lever... Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 2, 2013 Member Contributer Share Posted May 2, 2013 Link to comment Share on other sites More sharing options...
nardenodo Posted May 3, 2013 Author Share Posted May 3, 2013 Could i possibly see another picture of the metal piece that holds that cable? What screw is used for attaching this piece? Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 4, 2013 Member Contributer Share Posted May 4, 2013 i will take pix today Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 5, 2013 Member Contributer Share Posted May 5, 2013 2nd pic.. just play with it a bit .. you will see how it fits.. Link to comment Share on other sites More sharing options...
nardenodo Posted June 10, 2013 Author Share Posted June 10, 2013 Had to tear it apart again but i finally finished it! thank you all for the help i couldn't have done it without you! Link to comment Share on other sites More sharing options...
