Member Contributer jay-d Posted March 1, 2012 Member Contributer Posted March 1, 2012 Found this video from a local site describing how important it is to setup the ergonomics of your bike to fit you! Riding season is approaching for some and I thought this would be a great refresh for some new rides and old alike! I now remember that my clutch and brake levers definitely required me to lift my wrist up to wrap my fingers around the lever.. will definitely take some time to make all my adjustments! Quote
Member Contributer MaxSwell Posted March 1, 2012 Member Contributer Posted March 1, 2012 I am not famous for my memory, but I have a strong recollection of discussing this with my local dealers service tech because my wrists are bent when addressing the levers. I was told that my 5th gen levers are not adjustable in that direction. There is a notch which locates them and is not adjustable. If I am wrong I'd love to hear that! My wrists would love to lower the levers. Quote
Monk Posted March 1, 2012 Posted March 1, 2012 It's not that easy due to trying to line it up but it can be done........ Drill a new hole ! The levers are going to stop rotating down because the reservoirs will hit the risers... It's the button clusters that need the holes drilled for. Quote
Member Contributer realistdreamer Posted June 27, 2012 Member Contributer Posted June 27, 2012 I have this same issue on my 5th Gen. Will Heli's help with this angle issue? Would a shop be able to drill the holes for a "reasonable" cost? Quote
Member Contributer vfrcapn Posted June 28, 2012 Member Contributer Posted June 28, 2012 As Monk said, it's the switchgear that is fixed by the drilled hole. You can rotate the levers until they hit something. Quote
Member Contributer kgsmotorcycles Posted July 2, 2012 Member Contributer Posted July 2, 2012 Thanks, handy tips..... Now adjusted.... Quote
timmythecop Posted July 2, 2012 Posted July 2, 2012 the brake line elbows are stopped by the forks. I think each and every fifth gen guy wants to rotate the levers a few degrees down to make them better fitting. My Pazzo shortie sorta fixes this problem. Quote
Member Contributer Muff Posted July 3, 2012 Member Contributer Posted July 3, 2012 Ok. I adjusted the levers and now the fluid level looks low. Do I "top it off"? Quote
Member Contributer kgsmotorcycles Posted July 3, 2012 Member Contributer Posted July 3, 2012 So long as there is plenty of fluid in your res to cover the little hole in operation you should be ok... i removed the fluid res from handle bar with a new small plate on top yoke bolt and a new pipe to connect. Race style... Mind you, also using a cbr radial caliper for the now 929/954 forks.... Quote
