Member Contributer apexandy Posted October 13, 2012 Member Contributer Share Posted October 13, 2012 Flooding carbs can mean debris in the needle valve seat of the carb (I think I got the terminology right)... Even the tiniest speck can cause issues. Just a thought. Good Luck! Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2012 Share Posted October 15, 2012 Thankfully it's not flooding anymore. I need to figure out a brake side retarder solution, neither te VFR one or 900rr seem like they're going to be easy. Anyways, I'm still waiting on my muffler packing and ytz10s battery to arrive and I should at a minimum be able to get a test ride around the block. In the meantime here's a pic: Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2012 Share Posted October 15, 2012 Muffler packing and battery arrived. Really need to figure out what's up with carbs, first off the old fuel pump was as full of stalagmites as the original tank and carbs were, so I'm running it off gravity right now so it could be as simple as I need to put a pump inline, second could be needs synced, or maybe it just needs ran? It will fire up just fine from cold, but seems to cycle between bogging/starving an running real good. I've gotten it up tonoperating temp once an if I left it idling for long it stalls and wants to bog/starve. Anyways, thoughts from the crowd? Link to comment Share on other sites More sharing options...
SEBSPEED Posted October 15, 2012 Share Posted October 15, 2012 Clean your jets Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2012 Share Posted October 15, 2012 When i opened the float bowls I pulled a random jet and it was open and really clean inside. So, Not a huge need for the fuel pump unless it drops below a certain level? Also I found a line off the carbs that looks like maybe some sort of vacuum line or return? I didn't think carb'ed bikes had return.... Link to comment Share on other sites More sharing options...
NakedViffer Posted October 15, 2012 Share Posted October 15, 2012 Nope, no return on these fuel systems, maybe post a pic and someone can identify. You can run gravity feed indefinitely, just don't run the tank dry, as it can be a pain to get the carbs primed without the pump. I've been running gravity feed on my bike for well over a year with no problems whatsoever Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2012 Share Posted October 15, 2012 Yah I should have thought to snag a pic when the tank was off this morn. If it helps, it's a fuel line sized hose higher and slightly to the right if the fuel tee. Haha, I really don't think it's another fuel line, it's firing on all four the minute or so it runs right Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2012 Share Posted October 15, 2012 i just remembered I had the old carbs this thing came with, the hose I'm talking about is off the angled four way connection. I have the biggest one and both fuel Lines connected, just need to know where the other goes and hopefully it's the source of my problems! Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2012 Share Posted October 16, 2012 Is the ~45 degree fitting off that 4-way connecting to the rest of the carbs a vent line? If so, to the tank or air box or atmosphere? Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2012 Share Posted October 16, 2012 It was the plugged vent hose causing the inconsistency. Runs much more reliably now, can tell they need synced, probably incorrectly jetted too. Now I need to figure out why it's stalling when shifted into first. It rolls around fine in gear with the clutch pulled. Side stand switch perhaps? Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2012 Share Posted October 16, 2012 It was the plugged vent hose causing the inconsistency. Runs much more reliably now, can tell they need synced, probably incorrectly jetted too. I just rode around the block on it I went with 16/43 but first gear seems too low. Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2012 Share Posted October 16, 2012 Wanted to post a pic of the headers from the underside. Link to comment Share on other sites More sharing options...
Guest Posted October 20, 2012 Share Posted October 20, 2012 Thinking I should go all black on the tank front fairing and front fender. Also probably going to try and drop the subframe by 1/2 to 3/4 inch if possible. Link to comment Share on other sites More sharing options...
Guest Posted October 20, 2012 Share Posted October 20, 2012 Also swapped out to 15t front and shortened the chain by a link. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted October 21, 2012 Share Posted October 21, 2012 I thought you said first gear was too low? Dropping a tooth on the front is only going to make that worse. Glad you got the bike together, can't wait to see it painted. BTW, black has been done to death. Crash bike, paint black, done. That's why I went with something different for mine, white/black/grey/red. Link to comment Share on other sites More sharing options...
SEBSPEED Posted October 21, 2012 Share Posted October 21, 2012 Paint the small parts a light color and the big parts a dark color - the VFR is a big bike and the tank always looks out of place on the Frankenviffers. Link to comment Share on other sites More sharing options...
Guest Posted October 21, 2012 Share Posted October 21, 2012 haha, why did i say low when i meant high? 15/43 is what it needed....exactly what i was thinking seb... Link to comment Share on other sites More sharing options...
Guest Posted November 16, 2012 Share Posted November 16, 2012 Rode it around a little today, had to bleed the clutch a couple times while out, it kept pumping up for some reason? Also I think the R/R fried, it started stumbling like low fuel or low battery, and the R/R was wayyyy hot. Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 17, 2012 Share Posted November 17, 2012 Looks good so far! Download the Electrosport flow chart for troubleshooting your charging system. Link to comment Share on other sites More sharing options...
Guest Posted November 17, 2012 Share Posted November 17, 2012 thanks and yes, i defo need to do that! Link to comment Share on other sites More sharing options...
keny Posted November 17, 2012 Share Posted November 17, 2012 Quit a project to have while finnishing the house! You will have a stunning bike I think. I do think its funny, the 900rr guys put VFRsssa on thir RR´s, and we take their there RR swings and put them on VFR´s. How mutch does the wheelbase differ whit the RR swingarm? Link to comment Share on other sites More sharing options...
