tinyminds Posted February 8, 2007 Share Posted February 8, 2007 Was raising my forks up the way I had them before I took the bike in for warranty work on throttle cables, figured I would do How-To in case anyone was interested that was unsure what to do. Enjoy! Cover tank before you start, in case you drop a wrench or something. I've learned from experience. Edit: Forgot to mention, raise the front of the bike up before you start. The bike will come crashing down from the weight when you loosen the 4 triple clamp bolts if you don't. I put mine on the center stand and pulled the back down with a tie-strap. 1 Quote Link to comment Share on other sites More sharing options...
Guest 767fixer Posted February 8, 2007 Share Posted February 8, 2007 id be cautious loosening both legs at same time. seen one person due that with weight on the front and soon as he loosened the second legs lower pintch bolt the both legs went sliding up and a crushed up fender was the outcome. Quote Link to comment Share on other sites More sharing options...
tinyminds Posted February 8, 2007 Author Share Posted February 8, 2007 id be cautious loosening both legs at same time. seen one person due that with weight on the front and soon as he loosened the second legs lower pintch bolt the both legs went sliding up and a crushed up fender was the outcome. Owe yeah, lift the front off the ground first, edited first post to add that. I just put it up on center stand and tie-strapped the back down to lift the front up. Quote Link to comment Share on other sites More sharing options...
Darth Bling Posted February 8, 2007 Share Posted February 8, 2007 Nice pictures tinyminds! :thumbsup: Quote Link to comment Share on other sites More sharing options...
Member Contributer skuuter Posted February 8, 2007 Member Contributer Share Posted February 8, 2007 id be cautious loosening both legs at same time. seen one person due that with weight on the front and soon as he loosened the second legs lower pintch bolt the both legs went sliding up and a crushed up fender was the outcome. Put hose clamps around the tubes under the lower tree to catch the tube for safety from this........can use them to set the amount lowered also................................... :beer: Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted February 8, 2007 Member Contributer Share Posted February 8, 2007 Good write up, reminds me to buy a proper gauge... (I used the good ol' measuring stick and one crooked eye....) :goofy: on doing one by one, I was surprised how heavy a single fork is. Since I had nothing to strap the rear wheel down on, I placed the bike on the centre stand and placed a carjack under the exhaust headers. Not purrfect but a man has to do what a man has to do... It is ofcourse NOT rock steady this way.... Quote Link to comment Share on other sites More sharing options...
Guest SondanXX Posted February 8, 2007 Share Posted February 8, 2007 Good write up, reminds me to buy a proper gauge... (I used the good ol' measuring stick and one crooked eye....) Nice post Jason, and now I see your "secret"... mount the tubes higher in the gen mars... ahhhh... I'm with Dutchy, must go buy a proper gauge... I too use a MM measuring tape and contact lens corrected eyesight with 1.50 magnifying glasses over top of that... real accurate and precise... :rolleyes: Quote Link to comment Share on other sites More sharing options...
Member Contributer skuuter Posted February 8, 2007 Member Contributer Share Posted February 8, 2007 Great pictures and instructions........ :thumbsup: ....after flipping the triangle(damn, sometimes being short has it's aggravations), I kept lowering the forks until the ride/ handling suited me again. I just realized Tuesday I had room for a "double-stack" of Gen Mar risers under my stock bars. I rode them just clamped this height for a coupla' days and loved the comfort before I purchased the second set. Now I have the non-swivel safety pegs back in use......turned out great........................... :thumbsup: Quote Link to comment Share on other sites More sharing options...
tinyminds Posted February 8, 2007 Author Share Posted February 8, 2007 I just realized Tuesday I had room for a "double-stack" of Gen Mar risers under my stock bars. Wow, thats a lot lol. Suprised you don't have ground clearance problems with that. I'm contemplating investing in an Ohlins rear shock, I've just never been able to get the suspension setup the way I want on the rear. Gotta wait til after TMac because that will be a 2 week trip for me so need to save $$$ til then. Quote Link to comment Share on other sites More sharing options...
Member Contributer skuuter Posted February 8, 2007 Member Contributer Share Posted February 8, 2007 I just realized Tuesday I had room for a "double-stack" of Gen Mar risers under my stock bars. Wow, thats a lot lol. Suprised you don't have ground clearance problems with that. I'm contemplating investing in an Ohlins rear shock, I've just never been able to get the suspension setup the way I want on the rear. Gotta wait til after TMac because that will be a 2 week trip for me so need to save $$$ til then. With me sitting on it, my bike is "only" 7/8" lower than stock. When you "flip" the triangle, the bike runs up hill to the front. My bike basically has "stock" pitch angle again with the fork lowered to this point. I rode it stock height for 2 1/2 months before lowering it. Backing into parking spaces, low dips in roads at stops, parking lots etc., turned into real issues sometimes. Ya' gotta' do what ya' gotta' do sometime. Besides...not likely to "drag" at my pace......probably have been close sometime riding 2-up, but I factor in all the variables then and ride accordingly.......................................... :rolleyes: :thumbsup: :beer: Quote Link to comment Share on other sites More sharing options...
Trace Posted February 8, 2007 Share Posted February 8, 2007 Just an FYI on fork tube height [top of cap to top of yoke], since this hasn't been discussed here lately: Raising the tubes in the yokes (from the OEM setting) gives better turn-in and snappier handling. Lowering the the tubes does just the opposite, making the bike want to go straighter. It's kinda like the caster angle settings on a car. Casters want to go straight, like a shopping cart's front wheels. (except when one of 'em wiggles...what's up with that? I HATE that and always go get another cart so I can be railin' the aisles at Food World....) But the limit to raising the tubes is the point of instability and headshake, since you don't ever get sumpin' fer nuttin'. I set my tubes to 49mm. I went to 52 as an experiment, but got a wee bit of shake :goofy: under full power once, so I returned to 49. Depending on what manual you read and/or what Gen you have, OEM height is either 39 or 44, and there's always much controversy about that number!! But 49 worky niiiiice. Quote Link to comment Share on other sites More sharing options...
Bruckner Posted May 5, 2007 Share Posted May 5, 2007 (edited) What's the best way to support the front while undoing these triple clamp bolts? I'm thinking the headers aren't an ideal support, I can't find anything else under there.. what if I stack up sand bags on the passenger seat? How much weight is needed? I'm not sure I understand the "tie-strap" technique? Regards, Bruckner Edited May 5, 2007 by Bruckner Quote Link to comment Share on other sites More sharing options...
Rogue Posted May 6, 2007 Share Posted May 6, 2007 What's the best way to support the front while undoing these triple clamp bolts? I'm thinking the headers aren't an ideal support, I can't find anything else under there.. what if I stack up sand bags on the passenger seat? How much weight is needed? I'm not sure I understand the "tie-strap" technique?Regards, Bruckner The headers are plenty strong enough as long as they are generally in sound condition - plus the most obvious point : DO ONE FORK LEG AT A TIME! :rolleyes: Rod Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 6, 2007 Member Contributer Share Posted May 6, 2007 What's the best way to support the front while undoing these triple clamp bolts? I'm thinking the headers aren't an ideal support, I can't find anything else under there.. what if I stack up sand bags on the passenger seat? How much weight is needed? I'm not sure I understand the "tie-strap" technique?Regards, Bruckner The headers are plenty strong enough as long as they are generally in sound condition - :rolleyes: and having an allmost empty fuel tank saves 20 kilo's of pressure... Quote Link to comment Share on other sites More sharing options...
Bruckner Posted May 8, 2007 Share Posted May 8, 2007 (edited) DO ONE FORK LEG AT A TIME! I'm not sure that's so obvious.. since fork legs are perfectly parallel, wouldn't pulling on a single unbolted fork while the other is bolted tight risk damaging the whole thing??? Things may look more obvious when I get down to it but seems like sliding the entire assembly up and down is the only way to go; now of course measuring the proper height and tightening clam bolts will be done ONE FORK LEG AT A TIME, I hope that's what you meant??!?! As for the headers, hmmm, is there a better solution? Regards, Bruckner Edited May 8, 2007 by Bruckner Quote Link to comment Share on other sites More sharing options...
Rogue Posted May 8, 2007 Share Posted May 8, 2007 DO ONE FORK LEG AT A TIME!I'm not sure that's so obvious.. since fork legs are perfectly parallel, wouldn't pulling on a single unbolted fork while the other is bolted tight risk damaging the whole thing??? Things may look more obvious when I get down to it but seems like sliding the entire assembly up and down is the only way to go; now of course measuring the proper height and tightening clam bolts will be done ONE FORK LEG AT A TIME, I hope that's what you meant??!?! As for the headers, hmmm, is there a better solution? Regards, Bruckner Seems perfectly obvious to me. Pulling on it ?... one fork leg will be unbolted in the yokes and will move in parallel through the yokes - hey it's a spring! It will extend through the yoke by it's own unless it is stuck..the other fork will still be tight and will support the bike. Rod Quote Link to comment Share on other sites More sharing options...
Bruckner Posted May 9, 2007 Share Posted May 9, 2007 (edited) OK job's almost done but ran into a bunch of problems. I lowered the front about 20mm (back was lowered roughly 22mm using a longer 'dog bone'), when all was tightened up to spec (good thing I had a long torque meter handy, access isn't great), I wanted to remove the handles to slide spacers to raise the bars, with the forks now protruding the clutch line prevents me from lifting the handle high enough, I didn't want to risk damaging anything so I undid the triple clam bolts to set the fork at factory height again, then removed the handles and noted that one of the spacers I bought wasn't large enough to fit around the fork tube.. the other spacer fits fine but the difference in diameter is visible so I brought both pieces to a machinist to enlarge the opening of the smallest one hoping it'll work. Unless I'm doing something terribly wrong, the handles and spacers must be installed on the fork at factory height then sliding the fork up, unless there's a way to get enough slack in the lines to lift the handle up an extra 20mm (or whatever extra height is dialed in). Thoughts? Regards, Bruckner Edited May 9, 2007 by Bruckner Quote Link to comment Share on other sites More sharing options...
Member Contributer crepitus Posted May 9, 2007 Member Contributer Share Posted May 9, 2007 What's the best way to support the front while undoing these triple clamp bolts? I'm thinking the headers aren't an ideal support, I can't find anything else under there.. what if I stack up sand bags on the passenger seat? How much weight is needed? I'm not sure I understand the "tie-strap" technique?Regards, Bruckner If you're only working with the forks, a rear/head stand combo is perfect for this. If you have to work on the triples themselves, then a rear stand/floor jack works better. Quote Link to comment Share on other sites More sharing options...
Rogue Posted May 13, 2007 Share Posted May 13, 2007 (edited) OK job's almost done but ran into a bunch of problems. I lowered the front about 20mm (back was lowered roughly 22mm using a longer 'dog bone'), when all was tightened up to spec (good thing I had a long torque meter handy, access isn't great), I wanted to remove the handles to slide spacers to raise the bars, with the forks now protruding the clutch line prevents me from lifting the handle high enough, I didn't want to risk damaging anything so I undid the triple clam bolts to set the fork at factory height again, then removed the handles and noted that one of the spacers I bought wasn't large enough to fit around the fork tube.. the other spacer fits fine but the difference in diameter is visible so I brought both pieces to a machinist to enlarge the opening of the smallest one hoping it'll work.Unless I'm doing something terribly wrong, the handles and spacers must be installed on the fork at factory height then sliding the fork up, unless there's a way to get enough slack in the lines to lift the handle up an extra 20mm (or whatever extra height is dialed in). Thoughts? Regards, Bruckner The normal amount of "adjustment" in order to sharpen up the steering is between 5-10mm, so the answer is that you have raised the forks too much to lift the bar over the top of the fork leg, as you have said. I realise that this has been done to lower the bike. You could have simply unbolted the clutch assembly (2 bolts) and the switchgear from the bar.. further thoughts - it also helps a lot if you loosen / undo all the cable ties / clips which hold the wiring / throttle cables etc.. You should have bought properly designed and manufactured Risers... :salesman: Rod Edited May 13, 2007 by Rogue Quote Link to comment Share on other sites More sharing options...
Member Contributer filterfool Posted March 24, 2008 Member Contributer Share Posted March 24, 2008 To clarify; do you have to remove the front wheel to do the fork adjustment? With the headers secure on a jack, can you place a shim or lever under the front wheel to get the desired fork rise? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
SLO97VFR Posted March 24, 2008 Share Posted March 24, 2008 To clarify; do you have to remove the front wheel to do the fork adjustment? With the headers secure on a jack, can you place a shim or lever under the front wheel to get the desired fork rise?Thanks in advance. If it is your first time its probably be easier for you to remove the wheel and do one fork at a time .... Be careful not to pull, twist, yank or pound to hard while its on the jack Quote Link to comment Share on other sites More sharing options...
Auspanglish Posted March 24, 2008 Share Posted March 24, 2008 (edited) To clarify; do you have to remove the front wheel to do the fork adjustment? With the headers secure on a jack, can you place a shim or lever under the front wheel to get the desired fork rise?Thanks in advance. If it is your first time its probably be easier for you to remove the wheel and do one fork at a time .... Be careful not to pull, twist, yank or pound to hard while its on the jack I beg to disagree. If it's his first time he is more prone to error. Leaving the wheel on means everything will stay in alinement better. Don't be afraid people. The headers will support your bike fine. But like Dutchy says, doing it with an almost empty tank is common sense. It weighs much less that way. You can use the car jack to slowly drop the whole assembly in a perfectly parallel manner and once you've dropped the front by the desired distance, you will most likely find that the distance is the same on both sides, unless you've got the bike on uneven ground or haven't placed the jack centrally. Although the scissor jack that Duthy uses can be a bugger to adjust, there are smoother operating jacks around for like 15 bucks. I use one under the headers to do the fork oil change or change the front tyre... works a treat!! I'll be doing this mod over the next couple of days as I've got this odd instability in straight line trajectories... and I'm starting to suspect that the rear shockie I swapped out on my 5th gen is a 6th gen model and apparently a few mm shorter... I will document the procedure. Edited March 24, 2008 by Auspañol Quote Link to comment Share on other sites More sharing options...
Member Contributer rctwentyfour Posted March 25, 2008 Member Contributer Share Posted March 25, 2008 (edited) Hello, All: I just thought I'd "weigh-in" on this topic a bit. The "how to" aside, keep in mind that what is REALLY happening with this modification is that you are changing the trail within the steering geometry. There are a couple of ways to change the trail; increase the offset with in the triple trees (no easy task, but it is a sure-fire way to reduce the trail), or reduce the fork length by dropping the forks within the triple trees (which is being discussed herein). Wanna see what is REALLY happening when you do this mod? Okay, use this calculator, then you will have accurate information: http://www.papkegroup.com/superbikeengco/s...inematics1.html By the way, here is a front end stand, which fits into/lifts the front end from the steering stem. This particular stand would make this modification less hazardous. It takes the weight off the forks, suspending the bike by the steering stem: http://www.moto911.com/product_info.php?cP...products_id=414 I hope this is helpful to this discussion. rctwentyfour Edited March 30, 2008 by rctwentyfour Quote Link to comment Share on other sites More sharing options...
SLO97VFR Posted March 25, 2008 Share Posted March 25, 2008 To clarify; do you have to remove the front wheel to do the fork adjustment? With the headers secure on a jack, can you place a shim or lever under the front wheel to get the desired fork rise?Thanks in advance. If it is your first time its probably be easier for you to remove the wheel and do one fork at a time .... Be careful not to pull, twist, yank or pound to hard while its on the jack I beg to disagree. If it's his first time he is more prone to error. Leaving the wheel on means everything will stay in alinement better. Don't be afraid people. The headers will support your bike fine. But like Dutchy says, doing it with an almost empty tank is common sense. It weighs much less that way. You can use the car jack to slowly drop the whole assembly in a perfectly parallel manner and once you've dropped the front by the desired distance, you will most likely find that the distance is the same on both sides, unless you've got the bike on uneven ground or haven't placed the jack centrally. Although the scissor jack that Duthy uses can be a bugger to adjust, there are smoother operating jacks around for like 15 bucks. I use one under the headers to do the fork oil change or change the front tyre... works a treat!! I'll be doing this mod over the next couple of days as I've got this odd instability in straight line trajectories... and I'm starting to suspect that the rear shockie I swapped out on my 5th gen is a 6th gen model and apparently a few mm shorter... I will document the procedure. Are you keeping the front wheel on while you do this mod?? Please post up on your results.... Quote Link to comment Share on other sites More sharing options...
Member Contributer filterfool Posted March 25, 2008 Member Contributer Share Posted March 25, 2008 I would like to keep the front wheel on to reduce the amount of dis-assembl/re-assembly and to keep the front axle in alignment. Since there seem to be no VFR riders in my area (NM FL, Pensacola) I have to work by myself and I am nervious about doing anything that will screw up the bike. Thanks for the comments so far. Quote Link to comment Share on other sites More sharing options...
