5th gen sprocket questions
gig
Im changing my sprockets, I guess I've never payed attention but the front sprocket has some play against the 14mm retaining bolt is that normal?
i have wear on the outside facing portion of both the front and rear sprocket none on the inside facing. Curious if that seems normal or an alignment issue?
78C633A3-4A60-41EE-A20F-DCE5816080B9.heic
DB6ACF97-2333-4372-AF28-440CC5B99731.heic
mice made a home in my swing arm, what a mess, i had to tear the whole back end down and take the swingarm off
BEA96D28-6086-497E-ABC9-4921A1E34320.heic
19A72695-03D0-4E1C-929E-C981CCFE80C3.heic
No slop in front sprocket that I recall but not been in there since 2019 due to lack of use. IIRC the Yamaha R1 uses the same splines as our VFR's so I used a lightweight steel front sprocket for R1. You can always use a spacer to ensure a snug fit.
Is the play between the shaft and the front sprocket or internal to the transmission (no movement shaft to sprocket)?
Not internal or splines, its between the sprocket and retaining bolt and washer. I use a lighter weight front without the attached rubber. I think I will add and additional washer as a spacer.
ISTR the front sprocket is supposed to be able to move somewhat.  How much is another question.  But if Honda meant it to be rigidly attached to the output shaft, it probably wouldn't have been designed like that.
Ciao,
JZH
I was thinking the last time I had my countershaft sprocket off, there was a certain amount of lateral play. No rotary
movement on the shaft, but the sprocket was free to move a tad on the shaft sideways. We're talking basically just
enough movement to feel, and the nut/washer tightened to the shaft, not the sprocket.
