Aparator Posted January 28, 2020 Posted January 28, 2020 Last time I got her to start was Christmas. It was a little wet out so not sure if that had any impact. Tried starting it up a week or so after, it fired but then quickly died and wouldn't start again. Today I think it's an electrical issue as it won't start with the air filter off and starting fluid. What's the process of trouble shooting this issue? Thanks Quote
Member Contributer Thumbs Posted January 28, 2020 Member Contributer Posted January 28, 2020 Which bike? Quote
Aparator Posted January 28, 2020 Author Posted January 28, 2020 Hard reset the power commander 3 and it turned over and is idling now 1 Quote
Aparator Posted January 28, 2020 Author Posted January 28, 2020 It seems as though I have some electrical ghosts. I let it idle and warm up but the radiator fan didn't turn on. The fan switch is new and is set to 180. Any ideas? Quote
squirrelman Posted January 29, 2020 Posted January 29, 2020 check when cool that fluid is fully topped up. what was temp when u expected fan to start ? touch wire on thermoswitch to ground and see if fan runs then (key on ). 1 Quote
Member Contributer Cogswell Posted January 29, 2020 Member Contributer Posted January 29, 2020 6 hours ago, Aparator said: Last time I got her to start was Christmas. It was a little wet out so not sure if that had any impact. Tried starting it up a week or so after, it fired but then quickly died and wouldn't start again. Today I think it's an electrical issue as it won't start with the air filter off and starting fluid. What's the process of trouble shooting this issue? Thanks Download the FSM here https://www.vfrdiscussion.com/index.php?/files/file/246-98-01-vfr-service-manual/ and follow the troubleshooting procedures. One often overlooked item on bikes that sit is a weak battery - it should hold around 10.5 v while cranking. If it's more than a few years old and in doubt, always good maintenance to replace with a fresh unit. Quote
Member Contributer Grum Posted January 29, 2020 Member Contributer Posted January 29, 2020 Agree with Squirrelbrains to test your fan simply take the Fan Black wire and Ground it, or if easier, just use a clip lead to ground and touch the other end to the Black wire at the Thermoswitch, the fan should run with Ignition On. Also check your Fan Fuse E 10amp. 1 Quote
Member Contributer Cogswell Posted January 29, 2020 Member Contributer Posted January 29, 2020 Be sure the rad is completely full. If not, coolant wil not cover the switch and it will not work. Bleed the system with the bike on the sidestand to ensure the cap is the highest point in the system. 1 Quote
