Vf Oil Mod Question
keny
I am looking to fit a louder claxon to my bike over the weekend and just noted a difference between Keny's and my VF500F2.
I recall seeing that on Keny's bike the claxon was fitted inside a white horizontal panel.
Mine doesnot have that; nor is is on the parts fiches (which are for the US models with top half fairing).
So I am wondering that that horizontal panel on Keny's also serves to guide/direct the airflow towards the radiator?
Like the 4th gen has this black plastic panel underneath the headlights.
No panel here....
Using an ebay IR-thermometer, I have measured the temperature of the black oil filter and engine. Once after a ride and once after a bit more sane ride...
Measurement was taken a few minutes after returning home with the engine off
I measured some 105C after the ride with high and prolonged revving
After the ride in the fashion I usually ride, 95Celcius
The rear cilinders (measured just under the silver heads; the meter wants black surface) I got some 108celcius
This pic you did take of my bike Dutchy, shows the (bep bep) horn, same Place as yours
Mounting bracket a tad diffrent as you look closer
in your picture I see the plastic panel around/over the claxon. Yours sounded less strong,
I suspect my PO fitted a different one.
Begs the question what the purpose/benefit of this little panel is....
to stop sound bouncing back up?
Swiss law ?
I will look closer on mine from the under side later today
Dutchy, what parts schem did you use, 1985 on CMSNL? The 1986 schem has it! part #9
honda-vf500f-500-interceptor-1984-usa-st
Looks more and more you have a 1985 spec bike and I have a 1986 spec bike, what I´m currius to know is if you have a fule pump behind the left side cover under seat or not?
UIsing th e fiches I downloaded somewhere.................
never thought of checking cmsnl.. :wacko:
No fuel pump afaik....
the fuel line from the petcock goes straight forward to a T-piece and then the the carbs.
Nothing like this
Yo Timmay!!!!
This part #9 on any of your junkyard biatches?????
It's a wind deflector, goes with the ones on the side of the fairly to increase the air pressure to the rad. The VF500 is effectively a factory overbored VF400. But runs a similar sized rad as no room for more, so they added the wind deflectors to increase air through the rad. I removed the side ones & fitted a rounded infill to the fairing edge & fitted an air horn to the rear fender & taped over the original horn hole. Worked fine no over heating but the weather is never that hot in the UK. YMMV
Fitted an airhorn to the rear fender?? Any picture?
I have a Stebel look-a-like in my shed but so far not found a place up front for it on the VF
Yo Timmay!!!!
9
$19.96
Roll On ..
No longer available.
Holy cow!!!!
32celcius/90fahrenheit today.
atgatt still, but with the Macna cooling vest is was very pleasant.
Measured engine temperatures when I parked up.
oil filter 105c, front cilinder head 85c,
rear cilinder 107c
And cows, holy or not are not dumb....
