Member Contributer FJ12Ryder Posted April 26, 2015 Member Contributer Share Posted April 26, 2015 I don't understand how I could do that with this strap since the part of it that attaches to my truck has a loop to grab onto on one end & nothing on the other. The hook of it is attached to the cam buckle part. I finally went out and under the deck to recheck how I attached the strap to the ramp. It's just tied on, nothing else, just a knot. I thought it had some kind of attachment. Guess not. Sorry. Link to comment Share on other sites More sharing options...
LookingHard Posted April 26, 2015 Share Posted April 26, 2015 MysteryRider246, Regardless of the system you end up with couldn't you test your method/materials with a bicycle? If you need to step on something like a box or whatever as you push the bike up the ramp wouldn't it be easier with a 20 pound bicycle than with a 500 pound motorcycle? Good luck, LookingHard Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted April 26, 2015 Author Member Contributer Share Posted April 26, 2015 I intend to test it with my XR. And I'm not planning to use anything else to step on since the ramp is 34" wide. Thanks for the input though. Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted April 26, 2015 Author Member Contributer Share Posted April 26, 2015 I don't understand how I could do that with this strap since the part of it that attaches to my truck has a loop to grab onto on one end & nothing on the other. The hook of it is attached to the cam buckle part. Buy a different tiedown......... This is what Titan Ramps had to say: "If you see there is a loop on the other side of the strap. Take the hook though the loop (around the ramp) then connect the other end to your bumper and tighten the strap." I suppose it would have cost more if the strap provided had 2 hooks . Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted April 26, 2015 Member Contributer Share Posted April 26, 2015 Yeah, that sounds about right. I looked at mine at it looked like it was just tied, but I do seem to recall that I just looped the strap through a loop. Pretty low rent, but it does work. Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 26, 2015 Share Posted April 26, 2015 Low rent, and possibly stronger than a cheap hook Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted April 27, 2015 Member Contributer Share Posted April 27, 2015 Yeah, you could be right there. Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted May 2, 2015 Member Contributer Share Posted May 2, 2015 I don't understand how I could do that with this strap since the part of it that attaches to my truck has a loop to grab onto on one end & nothing on the other. The hook of it is attached to the cam buckle part. Buy a different tiedown......... This is what Titan Ramps had to say: "If you see there is a loop on the other side of the strap. Take the hook though the loop (around the ramp) then connect the other end to your bumper and tighten the strap." I suppose it would have cost more if the strap provided had 2 hooks . You don't want two hooks. The loop does exactly what it should - keeps the strap in place permanently. Link to comment Share on other sites More sharing options...
