Member Contributer rhoderage Posted August 19, 2014 Member Contributer Share Posted August 19, 2014 Is it normal on an '02 VFR800 for the frame to be hot after a ride? Ie the side portion that is visible between the tank and fairings. Bike did not overheat or anything weird; maybe I've just never touched the frame after a ride but I was surprised to find it quite hot to the touch. Link to comment Share on other sites More sharing options...
Member Contributer MadScientist Posted August 19, 2014 Member Contributer Share Posted August 19, 2014 Granted the plastics are a little different, but my 5th gen frame gets pretty warm also. Not hot enough to burn you instantly, but uncomfortable to touch for more than 10 sec. Definitely less than 140F (temp of my hot water heater), which will burn you pretty quick. Anyone got one of those fancy IR cameras or thermometers? Link to comment Share on other sites More sharing options...
Member Contributer Belfry Posted August 19, 2014 Member Contributer Share Posted August 19, 2014 I just did an 1,800+ mile round trip to Lake Tahoe. If you have a side wind, the air blowing out through the space above the two rear cylinders is pretty toasty. At speed you don't notice it (I suppose it's blown toward the back), but at slow speeds (traffic, construction) your inner thigh on the lee side can get a little toasty. While I haven't done it, I suppose if you stopped at that point and touched the section of the frame of which you speak it would be hot too. I wouldn't worry--as long as you're wearing pants. Link to comment Share on other sites More sharing options...
GadiantonRob Posted August 19, 2014 Share Posted August 19, 2014 Yes the frame get real hot. Did on my 4th gen, and my 6th is hot as well. Like, don't touch hot. Link to comment Share on other sites More sharing options...
Member Contributer rhoderage Posted August 19, 2014 Author Member Contributer Share Posted August 19, 2014 Very relieving, thanks! Link to comment Share on other sites More sharing options...
raoufhakam Posted August 20, 2014 Share Posted August 20, 2014 thats normal, my frame ('00 5th gen) gets pretty hot after long ride (highway, backroads, traffic) and stays warm for quite a while after. Link to comment Share on other sites More sharing options...
marriedman Posted August 20, 2014 Share Posted August 20, 2014 The engine is mounted to the frame, so there is going to be a transfer of heat to it. But it should dissipate fairly quickly. Link to comment Share on other sites More sharing options...
BRad704 Posted August 20, 2014 Share Posted August 20, 2014 I was told that it's a trait of the SSSA. Maybe due to the exhaust routing around the right side? Dunno, but one gets damn hot also. Link to comment Share on other sites More sharing options...
marriedman Posted August 20, 2014 Share Posted August 20, 2014 Hmmm... I can understand the SSSA being hot since it is mounted to the engine using it as a stress member, but the exhaust shouldn't factor into it. The exhaust never touches the frame nor swingarm. And even if it did, it would be cooler than the engine block I would imagine. Link to comment Share on other sites More sharing options...
BRad704 Posted August 20, 2014 Share Posted August 20, 2014 Any other ideas why only the right side is notoriously hot on Vfrs? Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted August 20, 2014 Member Contributer Share Posted August 20, 2014 Any other ideas why only the right side is notoriously hot on Vfrs? That's where the rectifier/regulator lives on most VFRs. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 20, 2014 Member Contributer Share Posted August 20, 2014 Any other ideas why only the right side is notoriously hot on Vfrs? That's where the rectifier/regulator lives on most VFRs. 5th gen R/R are on the left side rear subframe... right calf gets cooked because that is where the rear exhuast downtubes exit. Most of the metal spacers on the engine mounts are on the left side so that may isolate the engine heat transfer on that side. Right side directly contacts the engine. Link to comment Share on other sites More sharing options...
marriedman Posted August 20, 2014 Share Posted August 20, 2014 Any other ideas why only the right side is notoriously hot on Vfrs? Oh I completely agree the right side air temp hot! My point is that the frame/swingarm should be relatively uniform in heat because of the engine being mounted to it. If we are talking about rider comfort in relation to ambient temp, then you get some of the heat from the side rads blowing on you or emanating heat from the exhaust routing to the right of the bike. Link to comment Share on other sites More sharing options...
BRad704 Posted August 20, 2014 Share Posted August 20, 2014 I'm in a diff situation, being on a gen 3. But I also have right side frame sizzle. That's why I thought it was related to the SSSA or something g inherent to the vfr. Link to comment Share on other sites More sharing options...
