Clint Posted September 10, 2013 Share Posted September 10, 2013 Does any one have any idea how I could modify a Z-bomb with an on off switch, to effectively turn it on and off at will? I have a Z-Bomb installed and plan to buy another to modify, the plan would be to put a switch on the dash or under the seat I know a poster used a switch after splicing wires to turn the restrictions on and off, perhaps this could be applied to a Z-Bomb? Link to comment Share on other sites More sharing options...
vfrflanders Posted September 10, 2013 Share Posted September 10, 2013 I also wanted to do this, because I didn't want to cut into the bikes wiring harnass. I you want to remove it, it doesn't give any hassle, because all the extra wiring is done on the Z-bomb. The problem is that the Z-Bomb only has 4 wires on one plug (3th,4th, 5th and 6th gear). I tried to identify the copper connectors to make 2 extra wires, but so far I wasn't able to find some. Once you have them, you only need the scheme Dutchgixxer made. I think to have a switch is a good idea ("normal" gear (less torque in 1th and 2nd) on wet days and driving through cities) Link to comment Share on other sites More sharing options...
Clint Posted September 10, 2013 Author Share Posted September 10, 2013 I think to have a switch is a good idea ("normal" gear (less torque in 1th and 2nd) on wet days and driving through cities) ^this i have found the bike less enjoyable to ride in urban environments, however love the zbomb when out on the open road. A switch would be great! and like you said modifying a zbomb would make it easily removable/reversible. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 10, 2013 Member Contributer Share Posted September 10, 2013 Oh yeh just in case you let the neighbor ride it. Open the switch. Link to comment Share on other sites More sharing options...
Member Contributer spinalator Posted September 10, 2013 Member Contributer Share Posted September 10, 2013 Let us know how the wiring goes! Link to comment Share on other sites More sharing options...
Volfy Posted September 11, 2013 Share Posted September 11, 2013 You could easily hook up a DPDT switch, and you don't even need the Z-bomb. All the Z-bomb does is take the 2 wires that normally feed into 1st and 2nd gear lines from the gear position indicator, and tie them into the 3rd gear line. If you want a "remote" switch at the handlbar, you could use a DPDT relay instead and use a ON/OFF switch to pull the coil of the relay. Link to comment Share on other sites More sharing options...
Clint Posted September 11, 2013 Author Share Posted September 11, 2013 You could easily hook up a DPDT switch, and you don't even need the Z-bomb. All the Z-bomb does is take the 2 wires that normally feed into 1st and 2nd gear lines from the gear position indicator, and tie them into the 3rd gear line. If you want a "remote" switch at the handlbar, you could use a DPDT relay instead and use a ON/OFF switch to pull the coil of the relay. the Idea behind modding the z-bomb is in order to not modify the bikes wiring at all. I found the post from the stickied thread where a DPDT switch was used when splicing the wires directly on the harness, I'm going to order another z-Bomb and have a go at applying the same mod. I'll post my results Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 11, 2013 Member Contributer Share Posted September 11, 2013 Radioshack Hobby & Do-It-Yourself Component parts Relays & transformers 12VDC Coil DPDT Miniature PC Relay accessories manual in the box 12VDC Coil DPDT Miniature PC Relay Model: 275-249 | Catalog #: 275-249 $6.49 $6.49 (4 reviews) Read 4 Reviews Write a Review Free Ground Shipping on orders over $50(DETAILS) BUY ONLINE In stock Usually ships in 1 - 2 Bang .. Link to comment Share on other sites More sharing options...
Volfy Posted September 12, 2013 Share Posted September 12, 2013 Yep, that'll work. Or if you don't want to mess with soldering and packaging, you can get a pre-canned DPDT board like this one commonly used in home alarm systems: http://www.smarthome.com/7277/ELK-924-High-Sensitivity-DPDT-Relay-Board/p.aspx Slip a large heat shrink tubing over whatever you end up with and it's good to go. Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted September 12, 2013 Forum CEO Share Posted September 12, 2013 Shoot I was so happy with the feel of the bike afterward I dont think I could ever go back to that muted throttle response. Link to comment Share on other sites More sharing options...
crakerjac Posted September 12, 2013 Share Posted September 12, 2013 ^^ This. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 12, 2013 Member Contributer Share Posted September 12, 2013 Yep, that'll work. Or if you don't want to mess with soldering and packaging, you can get a pre-canned DPDT board like this one commonly used in home alarm systems: http://www.smarthome.com/7277/ELK-924-High-Sensitivity-DPDT-Relay-Board/p.aspx Slip a large heat shrink tubing over whatever you end up with and it's good to go. Yeh use to install those same one's when I owned my own Security Alarm business. Used them turn on 120VAC siren's . Link to comment Share on other sites More sharing options...
crakerjac Posted September 13, 2013 Share Posted September 13, 2013 Yep, that'll work. Or if you don't want to mess with soldering and packaging, you can get a pre-canned DPDT board like this one commonly used in home alarm systems: http://www.smarthome.com/7277/ELK-924-High-Sensitivity-DPDT-Relay-Board/p.aspx Slip a large heat shrink tubing over whatever you end up with and it's good to go. This actually gave me a great idea on how to use the existing GPS sensor to both fool the ECU into thinking it's in 3rd gear for 1st and 2nd yet allow a secondary micro detect the ACTUAL gear. My thought is that this secondary micro would push the correct gear position out to the display over the serial bus. I've looked at the schematic for the ECU to instrument cluster and the gear display is updated by a one way communication serial bus. From looking at the schematic, it looks like every dash function has its own pin on the connector... This makes me think that the only thing on the serial bus is the gear indicator... And possibly MIL codes. Link to comment Share on other sites More sharing options...
deancol1 Posted October 9, 2017 Share Posted October 9, 2017 Hey Clint, Were you able to figure out how to rewire the ZBomb for switching on and off? Link to comment Share on other sites More sharing options...
