I whipped up this little spread sheet last night so you can actually see what effects the changes in either the front and/or rear sprocket make. I included the final gear ratios for each gear so you can see how one set-up compares to another. For example, going to a 15/45 set-up makes your 6th gear pretty close to being equal to 5th gear with the stock sprockets. The columns are arranged in descending order from left to right.
Question
Guest Pete McCrary
24 answers to this question
