Member Contributer spotthedogg Posted October 24, 2014 Member Contributer Posted October 24, 2014 Yeah the YR-502P is what people use a lot, I think it's from an Acura Vigor, 1991 Acura Legend etc. I guess the follow up question is does anyone know a similarly close auto color to Spencer Blue? I may use Honda Belize Blue although it's not as deep as I'd like. I am painting my race plastics not trying to color match any panels. Quote
Member Contributer spotthedogg Posted October 24, 2014 Member Contributer Posted October 24, 2014 I think I will use Blue Sensation Pearl B-548P After more digging around I found in the old rear hugger thread someone stated that Ford KM 6479 is very close. I don't know about having a Ford color on my bike though Quote
Member Contributer gmtech94 Posted May 2, 2015 Member Contributer Posted May 2, 2015 Most collision shops have a digital camera that will transfer the colour through into a paint mix formula that will give a perfect match for any paint colour . Quote
Member Contributer NorthernVFRDave Posted June 13, 2015 Member Contributer Posted June 13, 2015 Anyone know the paint code for the 6th gen engine? More so the clutch cover. Mine is a little rashed up and I planning on sending it to Seb at some point for window install. But would like to try and clean it up a little until then. Quote
Member Contributer RC51Nick Posted June 13, 2015 Member Contributer Posted June 13, 2015 I ended up using Black metallic VHT high heat engine paint. I would say it is a 99% match to the stocker. Needed some for the same reason as you. I really can't tell the difference. Quote
Member Contributer NorthernVFRDave Posted June 13, 2015 Member Contributer Posted June 13, 2015 I ended up using Black metallic VHT high heat engine paint. I would say it is a 99% match to the stocker. Needed some for the same reason as you. I really can't tell the difference. Thanks I'll take a look and see what I find... a little off shade is ok. Will look better then the bare scraped aluminum look I'm rocking now ;) Quote
Member Contributer Switchblade Posted July 9, 2015 Member Contributer Posted July 9, 2015 Most collision shops have a digital camera that will transfer the colour through into a paint mix formula that will give a perfect match for any paint colour . Boy I am way behind , good info . Quote
WGREGT Posted July 9, 2015 Posted July 9, 2015 I'm still looking to match the wheel color on my 07 r/w/b anniversary edition. It's black to me, but....not to people with normal color vision. I'm told it's bronze something or other. Anyone know the name? Then I could look it up in that long-ass list you guys posted. Quote
SlimWhitey Posted April 1, 2018 Posted April 1, 2018 On 10/24/2014 at 10:07 AM, Veefer800Canuck said: Again, as far as I had checked last, Honda does not release their exact motorcycle paint formulations to aftermarket paint companies like DuPont, PPG, or others to match by referencing the paint code under the seat. Automotive paint, yes, motorcycle paint, no. Partly this is due to how motorcycles and autos are repaired. Dent your 2014 Civic, and the new bumper and fender arrive unpainted at the Honda car dealership, and they paint and install the parts at their own bodyshop owned by the dealership. Dent your 2014 CBR1000, and the fairings arrive prepainted from Japan and are simply swapped at the Honda motorcycle dealership. Also, I had read that the paint formulations they use in Japan for the motorcycles have high levels of lead and VOC's that would not pass EPA regs here in North America. (at least they used to, that may have changed recently) So basically, any paint that you may find here is probably the result of someone scanning a body panel with one of those high-tech scanners, and using the formulation that the scanner spits out. That method may or may not result in a match, depending on numerous factors, not the least of which is the humidity and temperature during painting, air gun pressure, spray pattern, application technique of that particular painter, etc. Short story long, matching existing MC paint is a 'Good Luck Chuck' endeavour. I'll be testing this theory soon enough. I have to redo the tank of my 00 VFR, and I'll be heading into Walkers for G-161P, Pearl Conifer Green. We'll see how it goes. Quote
KStroh21 Posted June 23, 2019 Posted June 23, 2019 On 12/30/2008 at 3:31 PM, AB-Oz said: After a quick google looking for the black Klingon paint code, I found this, thanks to the Blackbird forum on the Irish bikers site: Code Color A-01 Semi glazed black A-03 Silver (labels) A-07 Specified blue A-73 Gold (labels) B-100M-U Cosmo black metallic B-104 Percian blue B-143M Calypso blue metallic B-175M Artico blue metallic B-183M Petrol blue metallic G-1 Smoke green G-20 Papaw green G-31 Mighty green G-38M-S Muscat green metallic G-142M Tasmania green metallic G-156P Pearl sierra green GA-1 Tomasek green GY-102 Mint lime green GY-120M Bud green metallic GY-126 Matt uranium G-142M Tasmania green metallic G-177M Cyber green metallic G-182M Sardegna green metallic NH-1 Black NH-1L Black NH-1R Black NH-1Z Black-Z NH-2M Metallic silver NH-4 Elephant gray NH-10M Dark silver NH-19M Dark gray metallic NH-24 Ceramic white NH-35M Cloud silver metallic NH-42M-C Custom silver metallic NH-43 Phantom black NH-53L Spacy gray NH-57 Excel black NH-67L Dew gray NH-101L Princess gray NH-101M-U Perseus silver metallic NH-104M-U Pleiadis silver metallic NH-105 Matt black (#15-#20) NH-106 Heatproof black NH-110M-U Magnum silver (gray) metallic NH-111 Cortina white NH-118M-U Sterling silver metallic NH-119M-U Tempest gray metallic NH-121P Pearl shell white NH-121P-A Pearl shell white A NH-123L Midnight gray NH-125M-U Nimbus gray metallic NH-129M Max gray metallic NH-131M Starlight silver metallic NH-132M Max silver metallic NH-138 Shasta white NH-139P-A Pearl crescent white A NH-142M-U Meteor gray metallic NH-146M Accurate silver metallic NH-154R Tasman gray NH-167M-U Iron nail silver metallic NH-182M Intellignet silver metallic NH-193P Pearl crystal white NH-193P-A Pearl ctystal white A NH-196 Ross white NH-206M Medium gray metallic NH-211M Frame alumite silver metallic B NH-217M Checker black metallic NH-236M Sparkle frost silver metallic NH-237P Pure black NH-242MU Reddish gray metallic NH-249 Mat works gray NH-254M Blitz gray metallic NH-259M Accurate seed silver metallic NH-280 Armor black NH-280R Armor black NH-295M Sparkling silver metallic NH-326P Pearl glacier white NH-341 Pearl white NH-347R Works gray NH-359M Mute black metallic NH-403M Brittany silver metallic NH-411M Force silver metallic NH-418P Pearl prism black NH-431 Metallic silver NH-436 Asphalt NH-463M Darkness black metallic NH-478M Tower silver metallic NH-480M Shield silver metallic NH-A12M Interstellar black metallic NH-A13M Excalibur gray metallic NH-A30M Digital silver metallic NH-A32M Mat blac gray metallic P-44 Illusion blue PB-1 Dark blue PB-2 Columbia blue PB-2C-S Candy blue green PB-3 Maruem blue PB-3C-C Candy sapphire blue PB-3c-F Flake sapphire blue PB-5 Royal blue PB-6C-S Candy sirius blue PB-7C Candy sword blue PB-11L Cabaret blue PB-22B Dionysus blue PB-31 Angel blue PB-36L Reykjavic blue PB-101 Matt blue PB-106 Peppermint blue PB-102C-S Candy grandeur blue special PB-103C-C Candy radiant blue custom PB-107C-U Candy tanzanight blue PB-109 Neptune blue PB-115C-U Candy flair blue PB-117C-U Candy enpire blue PB-120C-A Candy pearl blue PB-123PA Pearl siren blue-A PB-127C-U Candy Aleutian blue PB-151C-U Candy mistral blue PB-161C-U Candy wave blue PB-164 Victory blue PB-166 Wisteria blue PB-171M-U Traditional blue metallic PB-174P Pearl diana blue PB-182 Florida blue PB-184M-U Granite blue metallic PB-186 Seychelle night blue PB-200 Dakar blue PB-215C Candy tahitian blue PB-221M Cyclon blue metallic PB-230M Sensitive blue metallic PB-255P Pearl coronado (colorado) blue PB-256M Northern light blue metallic PB-257M Lapis blue metallic PB-262P Pearl great blue PB-284C Candy phoenix blue PB-296M Moody blue metallic PB-297M Sevilla blue metallic PB-324C Candy xenon blue PB-332P Pearl heron blue PB-341P Pearl breezy blue PB-342M North pole blue metallic PB-346 Pearl blue PB-351P Pearl montana blue PN-299M Ice blue metallic PN-342M North pole blue metallic R-2 Scarlet R-2C-F Flake sunrise orange R-3C Candy red R-4C Candy ruby red R-6C-S Candy antares red R-7C-C Candy ltd maroon R-8 Bright red R-8C-S Candy presto red R-9C-S Candy alpha red R-23 Tahitian red R-33 Helios red R-101C-U Candy glory red R-103L Burning red R-104C-U Candy muse red R-107C-U Candy bourgogne red R-109 Passion red R-110 Monza red R-112L Factory red R-114 Candy dark red R-114C-U Candy wineberry red R-116 Stream red R-117C-A Candy pearl red R-119 Flash red R-120 Blaze red R-124C-U Candy Alamoana red R-127 Sparkling red R-131C-U Candy andromeda red R-134 Fighting red R-151C-U Candy graceful red R-157 Italian red R-158P Pearl pure red R-147P Pearl rasberry black R-167 Furious red R-175 NR red R-176C Candy spectra red R-201 Magna red R-247M Pennant red metallic R-255M Rich red metallic R-257C Candy ambassador red R-258 Winning red R-277C Candy calcutta red R-287 Candy black cherry R-296M Carnelian red metallic RP-138M Mauritania violet metallic RP-147P Pearl rasberry black RP-152M British gold metallic RP-166 Magenta metallic Y-1 Ivory yellow Y-31 Parakeet yellow Y-124P Pearl shining yellow Y-158M Siena gold metallic Y-161M Navona beige metallic Y-163 Yellow Y-170M Cyber gold Y-181 Titanium YR-3C Candy kent brown YR-26 Shiny orange YR-129M Summer blond metallic YR-147M Max brown metallic YR-183M Titanium metallic YR-196C Candy Orange YR-217M Elegant beige metallic YR-234M Exotic brown metallic Quote
Jorno Posted June 2, 2020 Posted June 2, 2020 Hi everyone, I know this is an ancient topic, but since many years have passed now, does anybody have the PPG, DuPont or any code other than the Honda code for HRC gold wheels? It is not the YR502P or Golden Glow Pearl, which is also a car color, as spotthedogg said, but it is a little more yellow than the HRC color. The right Honda code is YR-159 M 0129 or 'Magtec Gold Metallic'. It was used, besides on the HRC bikes, on the wheels of the blue ST 1100 (European model) from 1999 to 2002, I'm not sure if it was used in the US on this particular bike. Oh yes, it was also used on the bottom half of the forks of the Honda X8R 50cc scooter, again around the year 2000, and that's about all I could find. The paint store I contacted had never heard of this code (now I know why) and asked me if I could provide them with a sample, which I can't, because it is such a rare color. Any push in the right direction will be greatly appreciated as I've been searching myself silly, trying to find any information. Cheers, Jorno Quote
