Member Contributer thereisnospoon Posted November 11, 2007 Member Contributer Share Posted November 11, 2007 I see the part numbers are different and I haven't been able to compare the two but I was curious if anyone knows if the 5th and 6th (2003) front calipers are the same/interchangeable? Thanks! Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted November 11, 2007 Share Posted November 11, 2007 They may quite possibly be physically interchangeable, meaning you could bolt them on, but IIRC, the 6th gens have different brake piston sizes to match the more aggressive LBS proportioning which gives more front brake bias than the 5th gens Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted November 11, 2007 Member Contributer Share Posted November 11, 2007 They may quite possibly be physically interchangeable, meaning you could bolt them on, but IIRC, the 6th gens have different brake piston sizes to match the more aggressive LBS proportioning which gives more front brake bias than the 5th gens Brake caliper piston sizes are found in the Honda Workshop Manuals for each bike. It is usually a good idea to re-calculate the master/slave ratio when swapping brake components to make sure you're not giving yourself WORSE brakes than before... Ciao, Link to comment Share on other sites More sharing options...
Member Contributer vfrjim2002 Posted November 11, 2007 Member Contributer Share Posted November 11, 2007 They may quite possibly be physically interchangeable, meaning you could bolt them on, but IIRC, the 6th gens have different brake piston sizes to match the more aggressive LBS proportioning which gives more front brake bias than the 5th gens They are also plumbed differently. 5th gens have LBS lines from the rear MC going to both front calipers. On 6th gens only the left front caliper is the beneficiary of that feature. Link to comment Share on other sites More sharing options...
spud786 Posted November 11, 2007 Share Posted November 11, 2007 I see the part numbers are different and I haven't been able to compare the two but I was curious if anyone knows if the 5th and 6th (2003) front calipers are the same/interchangeable?Thanks! The only difference between a 5th gen and 6th gen is the VTEcH, I'm just kidding, but theres alot more past that brick wall Link to comment Share on other sites More sharing options...
Member Contributer thereisnospoon Posted November 24, 2007 Author Member Contributer Share Posted November 24, 2007 I'm hoping that someone that has done a front caliper seal replacement can verify if I am reading the fiche correctly for the following parts. I assume by "set" Honda means that it's the fluid seal and the "dust" seal. By the way the fiche is written, it appears the following are required: 06431-MA3-405 x 1 (set) 06451-GE2-405 x 2 (sets) 06451-MZ2-405 x 3 (sets) Is this correct to replace all 6 piston seals? Thanks... Link to comment Share on other sites More sharing options...
Member Contributer thereisnospoon Posted November 25, 2007 Author Member Contributer Share Posted November 25, 2007 I'm hoping that someone that has done a front caliper seal replacement can verify if I am reading the fiche correctly for the following parts. I assume by "set" Honda means that it's the fluid seal and the "dust" seal. By the way the fiche is written, it appears the following are required:06431-MA3-405 x 1 (set) 06451-GE2-405 x 2 (sets) 06451-MZ2-405 x 3 (sets) Is this correct to replace all 6 piston seals? Thanks... selfish self bump... anyone done these replacements recently? Link to comment Share on other sites More sharing options...
Question
thereisnospoon
Thanks!
6 answers to this question
