VFR800 TURN SIGNALS MOD
VFR750F3
Had to drill a hole through the opposite side where the wire runs through because I flipped it so the mirror base fits perfectly.20240218_123759.thumb.jpg.4f85bbe5e9247b0ec41f2328a4ae9cbd.jpg
Does this make the blinkers more or less visible to other drivers?
Not my intent for visibility nevertheless they are bright.  I only purchased due to removing front turn signals and installing projector headlights.
I like that idea....... can you share where you bought them??
Edit add:  As an alternative, on my 5th Gen I got new signal lights from AliExpress, and they are a clearer amber and let more light through than the OEM's.  One caution, their sonic welds are poor, so remove the lenses and silicone them in place.  I then converted the bulbs to LED, and am quite impressed with the additional brightness and conspicuity of the running lights, and of course the signals are much brighter as well.  I got the bulbs at SuperbrightLED's.  Changed the flasher to LED compatible.
I found them on Amazon and AliExpress.  They're called Mirror Block-off Plates, and they're not really designed to be used with mirrors, but that's a good adaptation!  Regardless of whether they're used with mirrors or without, it doesn't look like the LEDs are really pointed in the right direction for signaling, but it still might work okay.
Which other Hondas have the same mirror mounts as VFRs?  The ones you used appear to have a 40mm bolt-spacing, and they are listed by "SMT MOTO" as being suitable for:
1999-2000 CBR 600 F4
2001-2006 CBR 600 F4i
2003-2011 CBR 600 RR / CBR600RR
2000-2001 CBR 900 RR 929 / CBR900RR
2002-2003 CBR 900 RR 954 / CBR900RR
2004-2007 CBR 1000RR / CBR1000RR / Fireblade
(But I would never trust a listing--always measure things yourself!)
Ciao,
JZH
The spacing is correct.  Mirrors afterwards have a different spacing and a wider mounting surface for example my CBR1000RR-R w integrated turn signals which I tried.  I wanted integrated ones but I wanted the stock look.  Also mounting these extend your mirrors without having to purchase mirror extenders.
