dirtrider Posted June 13, 2017 Share Posted June 13, 2017 Prepping my dad's 86 750 for a start up after sitting a couple of decades in a shed, discovered a huge hole in the corner of the radiator and this in the water pump.... Sent from my R1 HD using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted June 13, 2017 Member Contributer Share Posted June 13, 2017 WOW! You may want to try flush out the engine, if that was in the cooling system, who knows what's in the cylinder cooling jackets, that's pretty nasty stuff there! Link to comment Share on other sites More sharing options...
VFR4Lee Posted June 14, 2017 Share Posted June 14, 2017 Looks like you have a lot of work before you can try to start it. Link to comment Share on other sites More sharing options...
dirtrider Posted June 14, 2017 Author Share Posted June 14, 2017 Yeah I was and I noticed no water was coming out of the water pump area, so I pulled off the coolant rail and the whole pipe was clogged, and it still it I wasn't able yet to clear itSent from my R1 HD using Tapatalk Link to comment Share on other sites More sharing options...
vegaquark Posted June 15, 2017 Share Posted June 15, 2017 Jeeesus! Link to comment Share on other sites More sharing options...
vegaquark Posted June 15, 2017 Share Posted June 15, 2017 You coud try to bypass the rad and water pump with a external water pump or directly water from a hoose... That engine should be nasty inside. Link to comment Share on other sites More sharing options...
dirtrider Posted June 15, 2017 Author Share Posted June 15, 2017 How do I replace the impeller on the water pump? Is it pressed on?Sent from my R1 HD using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted June 15, 2017 Member Contributer Share Posted June 15, 2017 According to the service manual it is suggested that the water pump is replaced as a unit. The part 19200-ML7-692 is listed for $119 on Partzilla. The cooling system on my ST1100 was going the same way after 10 years standing; the thermostat was the worst (basically it was dissolving), but I had a couple of pinholes on the radiator as well. fortunately they've sealed and held up fine for 20,000km using some cold weld goop. Once I had a sealed system, I ran some radiator flush suitable for aluminium parts through the bike for an hour, then dumped that and replaced with coolant. Link to comment Share on other sites More sharing options...
nicholas042416 Posted June 17, 2017 Share Posted June 17, 2017 Man, throw some WD-40 on that and move down the road . Good luck to you my friend...it'll be a journey for sure!Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted June 17, 2017 Member Contributer Share Posted June 17, 2017 11 hours ago, nicholas042416 said: Man, throw some WD-40 on that and move down the road . Good luck to you my friend...it'll be a journey for sure! Sent from my iPhone using Tapatalk Seafoam! Cures anything... Link to comment Share on other sites More sharing options...
nicholas042416 Posted June 19, 2017 Share Posted June 19, 2017 Seafoam! Cures anything... Silly me, of course a little sea foam and it's ready for a 2000 mile road trip! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
dirtrider Posted June 19, 2017 Author Share Posted June 19, 2017 Lol why don't I put it together now and do a cross country road trip Sent from my R1 HD using Tapatalk Link to comment Share on other sites More sharing options...
nicholas042416 Posted June 19, 2017 Share Posted June 19, 2017 Lol why don't I put it together now and do a cross country road trip Sent from my R1 HD using Tapatalk Water pumps are overrated anyways...Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
dirtrider Posted June 19, 2017 Author Share Posted June 19, 2017 Basically, just added weightSent from my R1 HD using Tapatalk Link to comment Share on other sites More sharing options...
nicholas042416 Posted June 20, 2017 Share Posted June 20, 2017 Basically, just added weightSent from my R1 HD using Tapatalk Keep us updated on this restore, looks fun. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
