Welcome to VFRDiscussion
Tyy
What can you tell me about my VF500?
64 posts in this topic
Interesting, so the '86 engine will work on my '84 without modification? What differences would a later engine have?
Share this post
Google is your friend.
Loads of small but significant differences but it as far as I know, an 86 engine will fit in a 84/85 frame. It better, because I will be trying it this summer.
Share this post
Out in the shed right now having issues with my throttle cables. The snap when I release is nowhere near as fast as it want it. Also something really dangerous is afoot. When I turn full lock to the right the throttle sticks. This is screaming disaster at me. I think it may have something to do with where the cables are routed now. I put mine in between the forks and past the right hand side of the steering neck. I don't know if they are getting pinched or something. Does anyone have a close up picture of where youve routed your cables?
Share this post
You probably just need to add some slack using the adjuster on one of the cables right near the right switch assy.  The adjuster is 8mm with a 10mm lock nut.  Adjust to where the the throttle will still return at full lock both directions.
Share this post
I found that out when I was half way through tearing it apart to oil the cables. I also learned to keep tension on the cables when they are out of the tube. One of my cables went too far slack an came out of the carb. I decided I could put it back on without removing the carburetor, which turned out to be very hard. With one hand pulling the throttle open, another using improvised chop-sticks, and a screw driver in my teeth. I managed to put it back. In hind sight, I would have exerted a lot less effort removing the carbs. Never the less I feel like I have achieved something... I will accept my trophy of stubbornness now.
Share this post
2 people like this
Share this post
I got the bike off of my makeshift motorcycle lift today. I ought to know before I choose what to do next, if you can remove the rear cylinder head without taking the engine out. If I can indeed do that, it would save me an enormous amount of time and effort. I'd like to hear from somebody who has possibly tried this.
Share this post
Send pm to The Dutchy if he does not chime in today :-)
Share this post
If you can get the collector box off, taking the engine out is very easy on the 500. The extra access it gives is invaluable IME.
Share this post
*IF* you get it off yes....   :-)
Share this post
Hmm... I will test how securely my Henkel pipe is attached in case I do need to remove the whole engine. Actually yeah I need to clean that thing anyways. Just a side note; what have you guys used for surface rust? I bought CLR Metal Cleaner.
Share this post
As far as i know, you can´t get the rear head removed with the engine in the frame..
Allthough the 500 does have bolts on the outer corners of the cilinderhead, instead of studs like the VF750 and VF1000, the timing chain guides  cause trouble. You can´t raise the head far enough to clear these guides..
1 person likes this
Share this post
Hello all, I have silently been working on the VF500 for awhile. I got everything sorted out except the engine. It runs and drives, but it does indeed lack power on the high end. I assume the power issues are only because of the 4th cylinder not making compression. Recently though, on a ride to the shop to get it inspected, a loud rattle developed in the right side crank case, near the clutch. With the surmounting engine problems I want to swap the engine. This leads me to my current predicament, VF500's in my area have been either too expensive or pillaged for parts. There is however a VF1000 for a fair price. Would an engine swap be possible from the 1000? How similar are the bikes(both are '84s)?
Share this post
Sorry man, way too big for your frame. Won't even fit into 750 frame. Rebuild or wait for something.
Sent from my HTC_PN071 using Tapatalk
Share this post
Create an account
Register a new account
Sign in
Sign In Now
