marco Posted September 14, 2021 Share Posted September 14, 2021 Hi bike had a couple issues been to bike shop carbs off stripped all new jets float valves balanced...now choke works now which it did,nt but only running on 3 cylinders front right bangs into life if choke pulled on but push choke off back to 3 cylinders?? ive tried 2 different plugs one new as others if i leave plug in and a spare plug in lead it sparks good as i know ive had a few shocks!! any iders? rode it home from shop went really well so maybe on the throttle fuel is getting to plug??blocked jet ?? Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted September 14, 2021 Member Contributer Share Posted September 14, 2021 The shop didn't do its job. The work, the running evaluation, or the test ride. Something is still blocked. It can't be ignition if applying "choke" helps. If it seems better/ok at quarter throttle or more, perhaps a slow speed circuit is still blocked. I can count the number of people I trust to do a proper V4 clean on my bikes on one hand. And the first 3 fingers are me, myself and I. Link to comment Share on other sites More sharing options...
marco Posted September 14, 2021 Author Share Posted September 14, 2021 ye i thought it has to be fuel problem ill look into it again ill contact shop first, cheers. Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted September 15, 2021 Member Contributer Share Posted September 15, 2021 Not likely shop has +60yr old who actually knows how to refurbish carbs. Most likely they just sprayed some useless carb-cleaner through and didn’t bother to disassemble down to every last nut, bolt and individual component. Much less do any scrubbing, ultrasonic soaking or micro soda-blasting. Send then to Gordon @ http://customcarbservices.com and bike will run like brand-new off showroom floor! Think of carbs as garden-hose with sprayer at end. Most people focus on jets, jets, jets!!! Can clean that sprayer all you want, but what about the 20 golf balls stuck in hose along way? Doesn’t matter one bit how clean you get jets, if secret hidden passageways before & afterwards haven’t been restored to factory-fresh clean, bike won’t run. Link to comment Share on other sites More sharing options...
squirrelman Posted September 16, 2021 Share Posted September 16, 2021 i'm sure that guy is very good, but.......... i do carb cleaning/rebuilding too, charge less than that guy, and i just finished cleaning and fuel tube O-ring replacement on 2 gen 3 bikes................ unless people are seriously OCD, they don't need their carbs totally stripped down to each nut and O-ring as very often only one or 2 small jets need cleaning and the bike will run fine. i do alot of carb work, and most need very simple cleaning of idle jets and maybe new float needles, and that's all. i could make more money if i insisted on a total a stripdown of every carb that came in, but i just do what's necessary (and a couple of preventative things) to get my riders going again as quickly and as economically as possible. Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted September 19, 2021 Member Contributer Share Posted September 19, 2021 either way, marco you need a carb pro to do your carbs. There's NO ONE at that shop that can properly clean carbs! Don't give them 2nd chance to screw up your bike again! Send them to Gordon or squirrelman. Link to comment Share on other sites More sharing options...
