Member Contributer Blackened Posted September 4, 2020 Member Contributer Share Posted September 4, 2020 I've been doing some general maintenance and minor electrical work (Adding a secondary gauge bracket) on my VFR for the last few days. While I was working on it I noticed the fork seals were showing some signs of leakage and the front brake pads were starting to look a little thin. I ordered my fork seal kit (Go AllBalls!) but have some conflicting information on the brake pads I wanted to clarify on. Since I am doing this I figure i'll do both front and rear. Per a parts diagram if I replace all three brakes There are three separate part numbers: Front left: 06455-MCC-06 Front right: 06456-MCC-06 Rear: 06435-MAT-006 with a second option of 06435-MAT-016 My question here is, does this really require three different parts?? While I get front and rear might be different, It seems silly to me that Honda wouldn't just use the same pads for both fronts. Here is a pic of the three different parts (Right/Left/Rear😞 R/L certainly look the same... Also (Hopefully I don't spark some great debate here...) What pads have you had good luck with? I'm looking at EBC Double H sintered brake pads which seem to be very well reviewed everywhere I look. I'm also debating replacing the rotors. They brake smoothly at this point so I probably wont but That is dependent on further inspection. Link to comment Share on other sites More sharing options...
TimC Posted September 4, 2020 Share Posted September 4, 2020 I've always used the EBC HH sintered pads. They fit perfectly, stop the bike very well, wear pretty long, and they're affordable. And if memory serves, 6th gens take the same pads on all three calipers. Link to comment Share on other sites More sharing options...
Member Contributer Blackened Posted September 4, 2020 Author Member Contributer Share Posted September 4, 2020 2 hours ago, TimC said: I've always used the EBC HH sintered pads. They fit perfectly, stop the bike very well, wear pretty long, and they're affordable. And if memory serves, 6th gens take the same pads on all three calipers. Agreed on the price. Seemed pretty reasonable to me. Weird that they would give all three sets of brake pads different part numbers. 😳 Link to comment Share on other sites More sharing options...
TimC Posted September 4, 2020 Share Posted September 4, 2020 7 minutes ago, Blackened said: Agreed on the price. Seemed pretty reasonable to me. Weird that they would give all three sets of brake pads different part numbers. 😳 Making things more complicated than they need to be is the Honda motorcycle way. 😕 Also, just in case you've not changed motorcycle brake pads before (sorry, not making any assumptions either way here), make sure not to lose track of the little spring clips which hold the pads in place. Link to comment Share on other sites More sharing options...
squirrelman Posted September 4, 2020 Share Posted September 4, 2020 fix any fork seal leaks b4 replacing brake pads. Link to comment Share on other sites More sharing options...
Member Contributer TriumphTraitor Posted September 4, 2020 Member Contributer Share Posted September 4, 2020 From what I understand, the front left and right are the same, however depending on the year the front calipers may take different pads than the rear. Mine is 09 and I needed a different set for the rear than the front Link to comment Share on other sites More sharing options...
Member Contributer Blackened Posted September 6, 2020 Author Member Contributer Share Posted September 6, 2020 On 9/4/2020 at 3:15 PM, TimC said: Making things more complicated than they need to be is the Honda motorcycle way. 😕 Also, just in case you've not changed motorcycle brake pads before (sorry, not making any assumptions either way here), make sure not to lose track of the little spring clips which hold the pads in place. LOL. Just my luck! No worries. I've changed plenty of brakes before just not on a VFR. I'm going to work one at a time but will be sure to make sure nothing gets lost. On 9/4/2020 at 5:18 PM, TriumphTraitor said: From what I understand, the front left and right are the same, however depending on the year the front calipers may take different pads than the rear. Mine is 09 and I needed a different set for the rear than the front Ah... Figures. I'm still trying to figure out why they have two separate part numbers for the same part!! On 9/4/2020 at 4:03 PM, squirrelman said: fix any fork seal leaks b4 replacing brake pads. Wouldn't have it any other way. Last thing I need is pads tainted with Fork oil. Link to comment Share on other sites More sharing options...
Member Contributer TriumphTraitor Posted September 6, 2020 Member Contributer Share Posted September 6, 2020 10 hours ago, Blackened said: Ah... Figures. I'm still trying to figure out why they have two separate part numbers for the same part!! My guess is Honda most likely has a different backer spacer on the pads from left to right - meaning they would be a different skew number in the system but the actual pad might be the same Link to comment Share on other sites More sharing options...
Member Contributer TriumphTraitor Posted September 6, 2020 Member Contributer Share Posted September 6, 2020 I did some googling and found this You can see the only difference is the Stainless steel backers are given for one of the pads in each kit. The pads themselves are identical. Why Honda would do this is beyond me Link to comment Share on other sites More sharing options...
Member Contributer wiremanjon Posted September 8, 2020 Member Contributer Share Posted September 8, 2020 I went with the Ebc hh’s. They’re similar to the stock pads. The stock pads are very good in my opinion. I think I actually like the feel of less bite better, easier to control the nuanced way I use the brakes lightly. Link to comment Share on other sites More sharing options...
OttawaPat Posted January 17, 2021 Share Posted January 17, 2021 There was an excellent interview on AdventureRider Radio podcast about pads. They interviewed a motorcycle brake pad scientist (I think from DP Brakes but not 100% sure). It's the Aug 27, 2020 episode "Choosing Motorcycle Brake Pads--What is Brake Fade". Very good episode. Check it out. I changed my rear pads last year (about 55,000 kms then) and left the caliper attached to the bike. I remember it being awkward. The manual said something about making sure that spring stays in place. I had to really look to find the spring. No problem, I thought, I won't touch it then all of a sudden PTWAAANNNNGGG as it flew across the garage!! It took me half an hour to find it...then another half an hour to figure out how to put it back in place...ugghh... Link to comment Share on other sites More sharing options...
