Just finishing up the last few bits on this build, figured it was time to share here. This will be a long multi-segment post, so keep checking in till the finished pics pop up.
The (rough) design brief... CBR1000RR tail, F4i RSU fork swap, handlebar and riser conversion, round headlight, front mount radiator, custom exhaust header with low/underbelly muffler and exit, powdercoat lots of parts. Overall, the usual crisp, clean, loaded-with-details build with a P51 Mustang - airplane inspired theme.
Starting with a reasonably clean albeit slightly higher mileage '99 model:
Coolant drained, rads off, brakes (mostly) bled out, rear axle nut cracked loose. On track for fork swap by weeks end
Washer fluid bottle makes a good drain catch for coolant streaming from the drain at the pump
Not much, but at least it looks a bit lighter with the side rads gone.
More disassembly.
Removed hand controls, linked brake system, clutch slave, pair system, other misc stuff.
She's pretty grungy, got my work cut out for me to make it clean and shiny again.
Always gets worse before it gets better...
Found a broken airbox lid
Fitted the F4i forks and triples, and a set of brake calipers. The VFR wheel fits almost perfectly.
I did have to cut off the F4i steering lock stops to fit the lower, will make new ones later.
Then I offered up the CBR tail
I'm happy with how the shapes will blend. With the right blend panels and paint, it will look factory.
Share this post
Here's something you don't hear every day  (video)
Head bearings will need replacing. The saloon door action ain't gonna cut it! (video)
th_20161105_214625_zpsssyp9xpk.mp4
Here's most of the stuff that's come off...
Gas tank drained & off
Wiring harness (a lot of it!!) out
Fairing stay tab removed, still need to remove the other one
Quick mock up with oem tank and Hornet headlight
Same but with a 2002 VFR tank
Going to use the 02 tank as it looks much better with the tail, and the seat fit is just about perfect.
Did a little test fit of the front mount radiator, should work out real nice
Other side
Handlebar and risers on the way, hope they improve the look of the headlight!
Share this post
The 2002 tank is not a direct fit, the tank hits the airbox lid before it touches the mount. Also, the hole pattern is different on the rear flange (front is a direct bolt-on though)
I figured out that a 1/2" aluminum adapter would suffice, and made one.
Next up, Taking a little more material off the frame so I can get the subframe positioned just right, then make the mounts for that.
Share this post
Risers in
Adaptors rigged up
Shock swapped for 954 unit
Now "sittable"
Swapped in some CBR1k stick coils
And started on the front upper rad mount
Share this post
Test fitted VFR800 fan to the 750 rad, looks like it will work just fine with new mounts
Made some temporary hangers to sort the rad position
Not bad for a first guess
Need to order a 750 left side rad hose, finalize 3 brackets and mount fan, overflow to finish out cooling system.
Share this post
Polished gas cap (Thanks Bill!)
Made & welded mounts for rad fan
All done
Also mounted the risers to the upper triple. The risers hung over the edges of the triple a little and I didn't like that, so decided to fill the gaps with weld. This is in addition to bolting them on, powdercoat should finish the blend on the unwelded sections.
Headlight mounts almost done, pics coming
Share this post
There's an F4i shock in there now. Had to switch due to reservoir interference with my subframe mounts, now have to make a res bracket, no biggie. I think it'll mount horizontally across the bike and be hidden from the back by the upcoming license plate bracket.
Bought a bottle of simple green and tested a few spots on the motor and wheels, looking good with a little help from an old toothbrush. Hoping all the crud comes off pretty easily, I hate cleaning motors! Breaking down for powder soon so will find out soon enough I guess.
As promised, headlight brackets done save for powdercoat. Light bucket is nice and tight to the frame, once I finish cleaning the old fairing bracket mounts off it will sit lower to give space for ignition and fly screen.
Good start to the undertail/tray thing
Nice little spot for dzus clips on the subbie
Trimmed the sheet and the shut line till I liked it
Then pinned it in place and welded the rear to the cross bar
Both sides
Need a bend at the bottom... no press brake... make do with suitable implements
Tada
Share this post
A buddy polished my gas cap years ago after he got himself a polishing wheel. Kept it for a while, but gave up on it 'cause it was too bright! But it wasn't a show bike.
Share this post
I picked up a set of the stock CBR seat filler panels, but forgot a pic. They are one of those things that ebay sellers charge $30 for, even though they only cost $10 new. Always pays to check these things!
I did take pics of the CBR1k masters, and the new Delkevic header. I chose the header specifically for its poor design. The workmanship is adequate, but the many pieces and hokey collector are not what I would consider ideal for flow for performance or stock replacement. However, it makes a nice starting point for a one-off design as all the tubes are already separated.
New rad brackets
CXRacing oil cooler (thanks for finding this little guy Robbo!) with XRP TiTech fittings
Wanting bare aluminum look on masters, so disassembled them and dropped them in a bucket of old brake fluid. I don't see why it won't take the finish off nice and easy? (SPOILER: it didn't work!)
Need to make parts for this oil cooler mount tonight, I'm excited that it fits where I wanted it to!
Simple Green to the rescue on these gnarly parts
This was the start of the new rearset adapters. I'm fitting 954 Sato bling to this old girl
Initial sketches turned into a paper template that did fit, but didn't please me
So I adjusted
I think it was the right choice
I have a couple machining ops left to complete on them, and a couple spacers to make, but I like them so far. Peg location is stock in lowest, forward-most position, and gets racier from there.
I'm also just about ready to hang the oil cooler. I chopped the factory cooler lines to rob the pan fittings, and tig brazed steel -6 AN adapters on with silicon bronze wire.
Took a few measurements for top mount brackets for the cooler, work those next. Once I get a big list of oem gaskets and other parts on order I'll break down for powder, clean the motor, mount the new tires, etc...
Share this post
This oil cooler mount is almost done. I picked a slightly better spot which will require moving the cooler to change the oil filter. Only 2 bolts, I've seen worse on factory bikes.
Started with these to test the theory
Sketched out some changes
Drilled these unused holes out to 10mm from 9mm
Which allows me to hang the cooler with stainless bolts
Nice clearance all around, should work well.
The brake fluid soak didn't work too well, so I bead blasted the clutch master. I'll probably end up brushing it, but I'm considering a primer to lend to the airplane style control appearance.
Picture of mystery part to keep you guessing
Oil cooler mockup done, made 2 hoses to mate to my custom fittings
Left side
Right side
Also painted the masters with a green self-etching primer that fits into the theme nicely
Masters done
Blasted and painted the perch clamps, fitted stainless bolts, fitted new fluid nipple to clutch master
And began the reshaping of the front sprocket cover
Share this post
That weird lookin part I posted a while back... it goes here
And it serves to mount this on top of the risers
Yes it sits tall, making a stanchion that doesn't look goofy won't be easy... let's make it less tall first
Mill the riser caps down
That's better
Mocked up with mirrors, masters
The front brakes needed some help, queue up new seals, pads, brake cleaner, toothbrush, brass brush, metal polish... etc. And time. Lots of time.
T45 torx, in case anyone is curious...
Halfway
Some time later... a pretty pair of nuggets
Extraordinary golden glow courtesy of my scrubbing and an instagram filter
I actually bead blasted the pad springs and bolt heads, then rubbed them down with maroon scotchbrite to shine them back up a little.
Need to make this less ugly
Share this post
Tires on... Diablo rain Race... because airplane theme...
Samco hoses for the radiator inlet/outlet... standard 99 replacement on the right, 94-97 VFR750 hose for the left
Small hose in the pic is wrong, Racebikebitz mixed up the part numbers, they're sending the correct one gratis. Takes 4-5 weeks though...
Finished up the rearset adapters by adding the last counterbores
After midnight things get a little fuzzy
Let the lunacy begin...
Steel bolt welded itself into the aluminum... so I welded another bolt to it and spun it out
Finished cleaning up the front fairing mounts
Found the robotic O face a bit disturbing... so welded it up along with the coil mount holes on the sides... swapping to stick coils so don't need the originals.
Then smoothed those out
Also buzzed in a couple sections of rod stock, to be utilized at a later date
60k miles has done us no favors in the cleanliness department, the swingarm is the filthiest part of the whole bike. Well, except for the front sprocket area
That's the arm disassembled, with a couple reference pics for later. All these bearings and the ones in the axle cassette are being replaced with new.
Amazing what simple green, Wd40, brake cleaner, and a scrub brush will get you
Prep that for powder
Always a sad moment for some reason...
Frame and arm ready
Swingarm/kickstand cushion thing also
In the past, I've had parts messed up by coaters. The worst was when one of them masked front rotor mount surfaces on one side of a bike wheel, and not on the other. And didn't plug any of the holes for blasting. It was a real "can't fix stupid" moment. By masking off the parts myself, I'm in control of 1 extra part of their process, so 1 less thing that can go wrong.
My tape is removed and replaced by a temp resistant type after blasting. I also take lots of pics of the individual parts to share with the coater, and also for my records in case something does go wrong. On top of that, I flag areas on the masking to indicate no blast/no powder, or blast ok/no powder. I use a good heavy masking tape, so you'd have to be doing something wrong to blast through it and ruin edges under normal circumstances. The edge definition of the powder comes from the job the coater does with the high temp stuff.
I've done a bunch of sandblasting, but now just have a medium size cabinet at home for glass bead which is good for paint prep and light cleaning on things like bolts and brake rotors.
Disassembled the hub, sprocket bolts were not tight... which reminded me the axle nut was not tight either... good thing she's being gone through. Cush rubbers were hard, cracked, and basically shot. Already have new ones on hand
Finished shaping the lightened sprocket cover/clutch slave holder and cleaned it, this will get powder too
Trying to figure out how much of this rats nest can be ditched... so many vacuum lines... so much dirt... lol
Share this post
Made adjustable steering stops, drilled and tapped the existing dimpled locations and bolted them on.
The motor was really grungy, 60kmi worth. I soaked the block all over with alternating rounds of wd40 and simple green for about a week, which helped a lot.
In between scrubbing sessions, I picked this up from the powdercoater:
I popped most of it on the block so I could get on with deep cleaning
That's about 8 hours of scrubbing there. Worth it to see a nice clean lump, especially because it will be pretty visible.
I have more stainless bolts on order to finish out the side covers.
I also reassembled the cush drive hub with new rubbers.
Blasted and painted rear master, rearset assembly preview
Share this post
Seat!
New PBI 15T front sprocket. Was going to install the slave, but I forgot that some of the dowel pins were rusted and junk, so had to buy a handful.
Time to do something with these
First up, fit new bearings to the arm. The radial bearings popped right in as expected
The needle roller bearing... well that one was a bit more difficult... I had to get a little creative.
Detail line on the socket made a nice easy visual for setting depth to the required 6mm...
Then it was time to move this lump off the cleaning cart and back to the table
Add the spacers to the arm and have a fit check
Then pop in the pivot bolt and rearset
Finished up installing all the engine covers 100%, they all got new paper and rubber gaskets. Last thing was to put a finish on the clutch pressure plate.
Same green primer I used on some other parts
Then some fancy tape work to lay out a USAF-looking star
After a shot of gloss white, I busted out the Kafka #1 for some shaky line action...
The yellow zinc coating on the factory clutch bolts was just right for an ammunition effect
Then finished cleaning the axle/rotor by glass bead blasting, replaced the bearings in the cassette, cleaned the caliper hanger, chain slider, and lower guard and all the bolts for those and put all that stuff together.
Stuck the triangles in to hold the arm up
Then heaved the wheel in for a look
Share this post
Next up the rear caliper rebuild. This thing was dirty just like the rest of the bike, you'll have to take my word for it as I forgot the before pic. For those that don't know, the 98+ VFR's have front and rear linked brakes. Since I'm using a conventional unlinked front end, I have to modify the rear caliper to keep it. I swapped the rear master out for a CBR600 unit to improve the pressure ratio, and drilled the caliper to connect the large center piston to the smaller outer pistons.
You can see the hole I drilled at 3 o'clock in the center piston bore. If you look close, you can see how it connects to the port passing between the 2 outers
Polished pistons
The old banjo bolt hole for the center piston will be blocked off by the bolt in the pic. A single line will feed all 3 bores from the CBR master. Also, caliper connecting bracket before cleaning:
Bracket after cleaning + new parts
Pistons in
All together
And installed
Share this post
Then I swapped out the old oil filter for a new Bosch 3300, and installed the oil cooler with a sticker on top
Next up, this dirty thing needed a refurb
Original 60k tstat??
Tstat housing after bead blast and a bit of refining
Much better
And back together with new tstat, o ring, and hoses.
Frame prepped out. All threads cleaned and new tapered roller bearing races banged in.
Share this post
Sometimes it pays to have a lot of experience with one kind of bike... helps to know what to look for... like these baked out coolant joint o rings
Look at those crusty things on the table, they were already failing. Quick bead blast brought the joints back to life though
New o rings and a bit of scotch brite scrubbing on the mating surfaces finishes out that chore
Rinse and repeat for the side joints, these weren't as bad, not baked in the heat of the vee.
Then I dropped the frame on for a bit of scenery while I got going on cleaning the throttle bodies.
Theme check...
Spitfire%20D-FEUR%202010-10-301_zpsucbbe
The top shock mount needed to be made longer to accommodate the 1/2" spacer I added to raise the rear. Accomplished by replacing the factory bolt with a longer one. Cut the old bolt, punched the spot welded head out, turned down the head of the new screw, tack weld that in place then a coat of paint.
It's in place here. I added the horizontal shock reservoir mount, but forgot to take pics along the way. I have the res mounted to it now, but need to trim the hose clamps before I take a pic of that.
Paint samples
Fine silver brushed with white, green, and gray scotch brite pads before and after clear. I tried drawing a few different styles of rivets in pencil before clear.
Share this post
New All Balls tapered bearings in the frame and triple, front end back on
Pipe ideas...
I've got some of these on the way for the paint
This is a sample of the paint. It's really hard to get a pic of the colors. The greens are both Toyota colors, Spruce Green and Army Green. The Spruce almost looks black until the light hits it just right.
Share this post
Brake lines were once again an easy 15min phone call and less than a week's wait from Core Moto. Translucent orange hose, polished stainless banjos, gray tags.
Core Moto has a great selection of colors and fitting styles. I was able to pick just the right bends for all the banjos so the hoses flow smoothly everywhere they need to, and the hardware they supply is super nice too.
Share this post
Puzzle pieces
Kickstand is back on too
Baffles
Slip fits made possible by hacking this shit apart
Share this post
Damn! Nice work Seb. The only thing that frightens me more than your talent, is the K&N oil filter on the motor!
  • Like 4
Share this post
Final assembly on the cans.
Brushed the tubes with 100grit paper
Then trimmed the perfed cores to length
Tacked on inlet reducers
Wrapped the cores with SS wool
Inserted cores
Tacked in my connector spacer things
Inlets are a little funky, unequal length to make tying in the tubes easier. I used silicon bronze for something different, and to build up a bit of material at the joint.
On the shorter one, I actually had to resize an oem inlet to fit the 2" tube. A few slices and a squeeze and GTG.
All done.
Share this post
Keep looking, it was taken care of! LOL
I run Bosch filters
Share this post
Next up, I had to firm some things up to allow me to run the joiner tubes properly. Can't have a bunch of play when trying to do precision work!
First I tacked the rear down tubes. The clamped joints will be welded solid, the slip fit will move to the merge collector.
Next needed to hang the cans. Got lucky and was able to re use another piece of the Delkevic donor header. The bracket that was the bump-stop for the (now non-existant) centerstand became the hanger for the cans.
It did need a small filler piece added, but what's another weld at this point?
Now I can start adding joiner sections. Front bank routing will be pretty easy
Rear bank not so much
Just a little slicing and dicing...
Think I got'er
On to the front bank... would have like to do this just a bit different, but I cut myself a little short on material and didn't want to wait another week for one more section of bend to show up in the mail. So I reused another Delkevic piece, the one I cut the bracket off of. I'll clean that up later.
I was able to fuse most of the pieces in place, but as I don't have any fancy tubing clamps, the pieces move a bit when tacking and I ended up taking it off so I could tweak the pieces back by hand before fusing them up for good.
Exhaust done :)
Share this post
