Rebuilding the GPR, it's getting a color change too
Triples and GPR mount painted, starting bar assembly
Color scheme teaser
Added supports to the lower sub mounts, prevent any pivoting. they key off the nubs I welded in earlier.
Picked up this NIB Hotbodies undertray for a song
Needs a little work to close this gap
Chain cleaned and back on
At the other end, flyscreen progress
Share this post
Airbox lid modded to keep mice out, removed flapper and snorkel
Doing a little templating
It makes measuring for CAD entry easier
Repurposed a Duc carbon reservoir bracket for the rear res
Drew up some parts to hold the Antigravity battery
It uses the CBR tank mount locations
Welding thin to thick was fun
Still fits, proceed
Little strip of velcro to hold'er steady
And a bit of foam underneath for a little anti-vibe
Painted the headlight ring for that P51 look. Thinking about black checkering also.
Share this post
Made and welded this threaded bung here (welding .500" to .040"... fun again)
Which allows me to secure the undertray
And I got started on the mount for the gauge
Continuing w the gauge mount... some templating again... "CAD"... cardboard aided design 😄
Carve that little guy outta there and glue him on. Space .125" on 1 side to center the .250" gusset on the .5" rod...
To get this
In case you forgot it goes here
Share this post
Skipping a bit of wiring harness junk... This is the seat cowl release. I like to shave the lock from the CBR tail cowl, so it needs a new method of opening.
It's made from a spare release cable (from the pile, not sure what it came from anymore), a spent .45ACP case, stainless 10mm cap screw and a piece of 1/2" AL rod. I had to modify the oem latch a bit to get the cable pulling in the right spot.
Case was cut down in the lathe and the cable end cast in epoxy inside the shell.
Share this post
Skipping harness stuff again, show a little paint work. Doing a helmet to match the bike theme.
The plan is brushed silver with a riveted panel look, topped with pearl green and a yellow pinstripe to give it the old warbird look.
Taping the helmet was a pain, scuffing new paint is easy though!
Sealer
Fine silver base
I took all the parts home with no clear on, then scuffed the areas that were staying silver with a fine white scotch brite pad to give a brushed metal look. Then started laying pencil lines guided by pinstripe tape (nerve wracking on the contoured stuff!).
Then laid out a few hundred custom rivet decals I had made ( @throttlepimp is the man!). They are chrome vinyl dots with shadow crescents printed on them. These were the tools, and the sheets were full when I started!
The brushing doesn't look like much until the clear goes on, and then...
Share this post
Bodywork scuffed and taped for green
Booth shots after green and clear
Share this post
Time for some documentation of the moto-neurosurgery...
The patient on the table with some preliminary excess marked
I had a to add a shelf for the ecu. I welded a plate to the same subframe brace that I attached my undertail to.
I like to work my way from the middle out when rebuilding harnesses, usually from the battery, but in this case it was easier to start at the back from the ecu. I started by taking pics of the connectors and then cutting out a large section of the wires.
New terminals came from cycleterminal.com, highly recommend them.
I had my son remove all the rubber seals so I could reuse them
Reinstalled seals on the shortened wires and crimped the new terminals
Here's a better visual of how much was chopped out
Still have to make all this fit somehow
I had to buy a new oem plastic tray to chop as all the dummies on ebay wanted new price for broken parts, and the one I had was broken. It hides a lot of the wiring nicely
With PC installed
Bit of a squeeze, but everything fits and I retained some "trunk space" under the rear cowl by keeping everything under the seat. That's the rear wiring done save for the taillight plug.
Share this post
Taping all the lines was a bitch, and I get to do it all 1 more time for the yellow pinstripe. But first some pics of it all at home before I scuff it all again...
Prep for yellow and final clear
Share this post
Inside of the undertray painted with satin black and taillight test fitted, it's an integrated signal unit
Really happy with the paint design on the tail, but that black rubber won't do
So cover with leather same as the seat
Finished the helmet but the sun didn't want to cooperate on picture day 😞
Looks a little greener inside
Share this post
Needed some motivation so stuck the tank and seat on for little excitement... it worked :)
Capped the tstat bleed return hose
Replaced the fuel filter
Excess wiring removed to date
The start of Motoscope pro wiring
Adding this tiny 1a fuse for it was a pita... really glad I have crimpers
And it needs a relay for the fuel light to work
86'd the bank angle sensor, wanted to fit it in the headlight housing but no room for it
Finished out the undertray
Installed the tail (Vewy vewy Caewfuwwy!)
Taillight wiring done, ignition wires pulled up into tail where the Mlock will reside
Cleaned up in the shop
Share this post
Powdercoated fender struts satin tex black, painted the radiator tanks and supports rattlecan satin tex black
Turned up a couple of these
Because I didn't like the 90 deg mounts. Couple clamps and done, had to make a retainer plate for the clutch side as the CBR1000RR res was integrated previously
Wiring... ugh... need to make friends with someone who does my level of work and would trade wiring for welding or machining... heh
Relays and breakout box tucked into headstock area, all attached with sticky back industrial velcro
At long last, the gauge is alive
Share this post
Motogadget likes getting your money, so of course they don't offer a water temp sensor that threads into the oem Honda spot like Koso does. So I made this
Had to unwrap the harness to pull a couple more leads and grounds and integrate the motoscope gauge wiring
Forgot the left side, but here's the right side pass-thru hole for the Rizoma bar end signals
Airbox snugged down and wiring tucked in
Time to drop the tank on, add a bit of gas and check for leaks
All good there, need a coolant overflow still. Didn't feel like hanging anything off the motor on the right side,  opted to make this tube tank and mount it low on the left, off what was a fairing bracket mount tab.
Hose come off the rad, crosses over the front head behind the radiator, drops down the left side to the inlet/pickup tube
Share this post
Needs paint and loctite, then I can mount the sensor in the correct proximity to register the speedo impulses. :)
Damper stem base... if it looks familiar, it's because I used the same program to cut the fidget spinner for the speedo pickup.
Chucked the blank in the mill and finished the holes (I don't normally chuck cutters in drill chucks, btw...)
I forgot to take a pic of the op, but I did have to ball mill a clearance groove to clear the tank flange
Then turned up a stem from 5/8 stock
Had to do a little trimming in the lathe to fix the length, all good now. Stem is drilled & tapped for a small cross bolt because I'm a dumbass and drilled through instead of doing a deep counterbore for the stem, should have been drilled and tapped for a bolt in the bottom but it's stable enough as it is, save my spare for another time.
Share this post
Speed sensor reed switch installed
Pulled front wheel to scrub it and the rotors clean, also pulled both tires and installed Ariete angled stems then re-balanced both.
I found an issue with the clutch reservoir, the piece I made holds the nipple unevenly and allows fluid to leak, will need to address that pretty quick
That didn't stop me from rolling it outside for pics though :)
More pics and vids when photobucket stops being a bum
Share this post
So glad you finally put this up here. Bloody brilliant, mate.
Share this post
Level: GOD.
Share this post
slacker
Seeing a SEB project come to life is like watching Marquez save the front with his elbow. Sure wish I could do that!
Share this post
M-lock install pics...
I had a handful of videos of the bike running and revving, loaded them to photobucket, said upload complete so I deleted them and now they are nowhere to be found. I did upload 1 of them to my FB and Instagram pages, so I'll see if I can link it over.
Share this post
Craftsmen and genius all in one, a very rare combination. What planet did you come from?? Thanks for sharing such an incredible build. Would LOVE to hear and see some video of the finished project, wheels in motion!
Cheers.
Share this post
