Hi all, while reading up on the RC51 front end onto 6th gen swap it seems like a couple links to the threads are broken so a few questions -
With the new front end the brakes must be completely delinked. For the front its best to use the RC51hardware - calipers, m/c, brake lines, etc. Correct?
For the rear, best to re-use the stock m/c, caliper and line then a bridge line to the other outer caliper piston? Center piston can be plugged with a crush washer and an M10 set screw
The proportioning valves and associated hoses, etc can all be removed
The RC51 front end won't work with the ABS system so the front ABS components can be removed. Does that include the front modulator?
What about the rear ABS? Remove all that hardware (including the rear modulator) as well?
Question
jim v
Any info/insight would be a huge help
6 answers to this question
