So the basic instructions from Barnett is to soak the disc and install them as per the manual. Long story short there is only one disc that is different than the others in the Barnett kit but the manual says there are two that are different disc that go on each end, so being that there is only one that is different, would it make sense that this goes in first or last?
Again the Barnet instructions say that one or more disc might be different and that you should follow the manufacturers instructions. Anyone install this kit and if so, which position does the odd disc go in, first, closest to engine or last, closest to the case?
For the record this is for the 2001, which appears to be the same kit for all VFRs 2000-2009.
Question
Duc2V4
8 answers to this question
