otmaximus Posted January 19, 2016 Share Posted January 19, 2016 I hate that little screw cap over the rear caliper pin. I totally butchered that thing and now I can't change my rear pads. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted January 19, 2016 Member Contributer Share Posted January 19, 2016 You may have to drill it out. The thread is a very fine (and unusual) M10 x 1.0, so try not to bugger the threads! Later Hondas like my ST1300 used a little rubber plug instead of a metal screw-in plug. You can get them from Honda: Ciao, Link to comment Share on other sites More sharing options...
otmaximus Posted January 19, 2016 Author Share Posted January 19, 2016 Thanks for the tip (and the PN!). I was thinking about replacing it with a plug, good to know an OEM part is there. I'm going to replace them on all the bikes with the next pad change. Paul Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted January 19, 2016 Member Contributer Share Posted January 19, 2016 take a small punch or chisel and a hammer and try to get it loose.. smacking the thing at the end of the grove , counter clockwise. Link to comment Share on other sites More sharing options...
otmaximus Posted January 21, 2016 Author Share Posted January 21, 2016 I tried tapping it with a hammer and small screwdriver. And I tried liberal amounts of spray penetrant. I even tried my 19.2V impact gun with screw driver bit. It actually broke the bit. I gave up and bought another caliper off eBay. I'm replacing all the screw caps with the rubber plugs mentioned above. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted January 21, 2016 Member Contributer Share Posted January 21, 2016 wow , thats a shame. you could have just drilled the caliper ,just on the side of the plug. popping the plug out.. Link to comment Share on other sites More sharing options...
otmaximus Posted January 23, 2016 Author Share Posted January 23, 2016 Yep, tried that too. At the edge of the drill hole, the cap just got mangled into the threads. I'm sure someone with more patience and skill probably could have done it. Lesson learned... Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted January 23, 2016 Member Contributer Share Posted January 23, 2016 thats the point! to hell with the treads. you drill from the side .. through the brake into the button destroying the button. then pop it out. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 23, 2016 Member Contributer Share Posted January 23, 2016 Left handed drill bit at low r.p.m.'s. Link to comment Share on other sites More sharing options...
otmaximus Posted January 23, 2016 Author Share Posted January 23, 2016 I forgot about the left hand drill bit trick. Anyway moot point now. I got the new caliper on, and I put a new disc on too. I noticed some rust dust on the axle, it looks like the seal/bearing is dried out on the sprocket hub. The main drive bearing assembly looked fine. So I'm going to stop at the local MC shop to see about pressing in a new seal/bearing. This bike only has about 50k miles. My 94 lasted well over 100k before that's bearing gave out. Paul in SoCal Link to comment Share on other sites More sharing options...
